Tyre Terminology Rag, Bias Ply, Radial
14 replies to this topic
#1 _LS2 Hatch_
_LS2 Hatch_
Posted 19 May 2014 - 06:01 PM
Hi guys, I know I've had this partially explained, but I need to know what goes with what.
My understanding is,
Rag rear needs a rag front. No metal belts internally, no stability in the sidewall, good for drag cars.
Street Radial on rear allows a standard street tyre on front. Street radial has soft sidewalls, but still gives stability on the street, allowing for use on street, mainly driving to and from track on dry roads.
Now, Mickey Thompson ET Street Slicks, constructed of bias ply.?. Is this similar to the radial slick in allowing you to use a standard street front tyre, just constructed of softer rubber, or is it more like a rag and needs a rag front tyre?
This may be a silly question, as maybe a rag is a bias ply tyre. If that the case, why call it a DOT street slick?
I'm confused and would love to understand it.
Sorry for going into this again.
Cheers and thanks in advance
#2 rexy
rexy
  • 3,740 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 19 May 2014 - 07:47 PM
Mickey Thompson - ET Street
Worlds Fastest D.O.T. Class Race Tire
World's Fastest D.O.T. class race tire. Same great features as our race winning ET Drag with a D.O.T. stamp that meets the rulebook specifications for street tire classes. Tube type for extra sidewall strength, better air retention, and more consistent ET’s.
D.O.T. Approved
Compounded For Maximum Traction
Requires Little or No Burnout
Engineered For Consistent Performance
Acceptable practice for rim width is tread width plus or minus 1''. IMPORTANT: ALL DRAG DRIVE TIRES MUST BE MATCHED TO BE WITHIN 1/2'' ROLL OUT. CAUTION: It is not recommended that radial and non-radial tires be mixed on the same vehicle..
All Mickey Thompson ET Street tires are designed for drag racing use. While Mickey Thompson ET Street tires meet Department of Transportation requirements for marking and performance, they are recommended for DRY PAVEMENT USE ONLY.
ET DRAG® AND ET STREET™
VEHICLE WEIGHT
TIRE SIZE
AIR PRESSURE
UNDER 2,500 POUNDS
UNDER 2,500 POUNDS
UNDER 32" DIAMETER
OVER 32" DIAMETER
7 P.S.I. AND UP
5 P.S.I. AND UP
2,500 TO 3,000 POUNDS
UNDER 30" DIAMETER
30-33” DIAMETER
OVER 33" DIAMETER
10 P.S.I. AND UP
8 P.S.I. AND UP
5.5 P.S.I. AND UP
OVER 3,000 POUNDS
OVER 3,000 POUNDS
OVER 3,000 POUNDS
UNDER 30" DIAMETER
30-33” DIAMETER
OVER 33" DIAMETER
12 P.S.I. AND UP
8 P.S.I. AND UP
6 P.S.I. AND UP
PRO DRAG RADIAL
UNDER 30" DIAMETER
OVER 30" DIAMETER
16 P.S.I. AND UP
8 P.S.I. AND UP
OVER 3,000 POUNDS
OVER 3,000 POUNDS
UNDER 30" DIAMETER
OVER 30" DIAMETER
16 P.S.I. AND UP
12 P.S.I. AND UP
When working with ET Drag Radials use 1 psi adjustments to see change.
A radial will perform quicker the more air you can run.
ET STREET RADIAL
On the racetrack DO NOT use starting pressures below 11 psi.
Recommend pressures for:
P295 and larger sizes: 12-16 psi
P275 and smaller sizes: 14-18 psi
For suggested highway use inflation pressure in Mickey Thompson ET Street Radial tires, contact the Mickey Thompson Tires tech department at (800) 222-9092. Please have your OE specified tire size and OE cold inflation pressure (located on the vehicle’s tire placard), as well as the new tire size available for the tech staff.
A couple of selected bits of advice from the Mickey Thompson website.
Essentially you can think of tyres in two categories for your purposes. Radial and non radial. The ET Street is a non radial and you really should use a non radial up front as well.
The ET street radial is an excellent street tire for everyday use if you don't do too many km or burnouts. I got 5000 km out of my last set before they hit the wear bars ( approx 2.5 mm tread left). They are excellent in the wet even when worn. Certainly much better than any other high performance tyre I have tried.
#3 _Bomber Watson_
Posted 19 May 2014 - 07:57 PM
Yep.
Rag is slang term for Bias Ply.
ET street is a rag tyre. It is DOT approved in america, NOT AUSTRALIA. Must use rag front tyres.
ET street radial is a radial tire, again its DOT approved in america not australia, but i've never seen or heard of anyone being pinged for them.
#4 _LS2 Hatch_
_LS2 Hatch_
Posted 19 May 2014 - 08:27 PM
Thank you!!!
This explains it all and leaves me with no more questions.
I didn't realise that the Street Radials are not Australia legal. I thought DOT approved on the sidewall just made them legal.
Also surprised to hear they are good even in the wet. With the tread patern I would have thought aquaplaning was a given.
Thanks again guys :)
#5 _Bomber Watson_
Posted 19 May 2014 - 08:30 PM
As with most things Australia is #@$^%& in the head with tyres.
Tsingtongtan tyres for $60 each are perfectly legal, but high quality ET street radials arnt.
Go figure.
A bit of civil disobedience is a good thing, just run them.
Edited by Bomber Watson, 19 May 2014 - 08:30 PM.
#6 _LS2 Hatch_
_LS2 Hatch_
Posted 19 May 2014 - 08:36 PM
Out of curiosity, and not that it would overly concern me, but if you had an accident with these tyres on and it was your fault, would the insurance company pay, or could they get out of it?
#7 Potta
Posted 19 May 2014 - 08:43 PM
That's a trick question right?
If they can get out of it, they will.
#8 _Bomber Watson_
Posted 19 May 2014 - 08:44 PM
Sadly, thats probably true.
But Mud tyres like MTZ's are illegal to, and i know a fewl ads who have pranged there fourby's and been payed out.
Best to call your insurance provider and ask? Or put the ET street radials on the policy?
#9 _mello92_
_mello92_
Posted 19 May 2014 - 08:47 PM
We do a fair amount of insurance repairs at work and you would be astounded at what they will repair, and not any insurance mob in particular.
For instance, near new VE ute in at the moment, has had RHF impact with gutter and roundabout due to loss of control, has 2 bald rear tyres, LHR tyre has canvas showing the full circumference of the tyre, and yet we are repairing it.
#10 _mello92_
_mello92_
Posted 19 May 2014 - 08:51 PM
Care to elaborate DJ?
#11 _Bomber Watson_
Posted 19 May 2014 - 08:56 PM
Same deal as ET street radials. Dot approved in the US not Aus, TMK atleast.
Dad got pinged for his a while ago back when the local Cunning Stunts tablry was having a massive crack down on fourby's, obviously a 60 year old driving a jacked and boosted patrol is a massive threat to society.
#12 _mello92_
_mello92_
Posted 19 May 2014 - 09:06 PM
Ah ok cool, thanks.
#13 _Bomber Watson_
Posted 19 May 2014 - 09:21 PM
Im not 100%, we certainly couldnt find anything to prove they WERE legal....
Tyre shop that sold them couldnt help...etc etc etc.
Oh and before you ask, 33x10.5's, so legal size on his car.
Edited by Bomber Watson, 19 May 2014 - 09:21 PM.
#14 rexy
rexy
  • 3,740 posts
  • Name:Rexy
Posted 19 May 2014 - 09:46 PM
The ET street radials are legal. I went to the bother of contacting vicroads on this issue. They directed me to the rim and tyre association as the arbiters.
I discussed the tyre with the president and technical officer who arranged a viewing of the tyre by an authorised representative. The tyre was declared legal for street use in Australia.
#15 _Bomber Watson_
Posted 19 May 2014 - 09:51 PM
Well there ya go.
Disregard all the mindless drivel above posted by me, and feel free to laugh, point and jeer at me at will.
