Chrome Plating Fibreglass
bumpers
10 replies to this topic
#1 dattoman
  • 16,487 posts
Posted 02 June 2014 - 12:55 PM
Stealing this from a closed hotrod forum so can't link directly
I found this quite fascinating and could be helpful for some
Also answers questions in this thread http://www.gmh-toran...rglass-bumpers/
have just been thru the process of chrome plating fiberglass parts , heres how it was done , firstly ive always wanted my window garnish moulds chromed , so i searched the net and found out where to get the copper conductive paint , from caswell plating in melb , its called silvaspray,
, a pure siver paint which is highly conductive and very expensive this can be applied to any non metalic item and then you can get it copper plated
, first up was to prep my garnish moulds bog / sand prime sand and finish in 800 wet n dry ,
Attached File  026 (2).jpg   62.42K   10 downloads
once ready they were sprayed with silver spray all over making sure every mm was covered front and back , this paint is very thin almont transperent , i gave it a few coats to be sure
Attached File  034-1.jpg   49.72K   10 downloads
once painted and dry , a thin copper wire was wrapped around the outer edge a few time so it can be hanged in the tanks , also so the electric current can pass thru it, then it was wired up ready to hang in the baths
Attached File  041-1.jpg   57.69K   9 downloads
first stage was to go thru the cleaning 4 tanks , they were dipped briefly to make sure no residue was left on them
Attached File  043-1.jpg   75.87K   8 downloads
Attached File  044.jpg   70.22K   8 downloads
Attached File  045-Copy-Copy.jpg   63.96K   9 downloadsAttached File  047.jpg   61.98K   7 downloads
next they went into the acid copper tank for 1 hour , this gives the copper coating
Attached File  049-Copy.jpg   64.77K   7 downloads
was done i gave the moulds a light rub with 800 wet and dry to smooth any little imperfections , this process was done twice as to get a thicker copper coat to fill up any little markes / scratches
Attached File  048-Copy.jpg   82.89K   8 downloads
Attached File  053.jpg   82.05K   8 downloads
next was to go into the nickel tank for 20 min ,
Attached File  055-Copy.jpg   88.63K   9 downloads
after the nickel tank it get washed in water tanks before going into the chrome tank for a few minutes ,
Attached File  065-Copy.jpg   90.68K   7 downloads
have the finished product
Attached File  066-1.jpg   61.08K   7 downloads
Attached File  067-1.jpg   55.18K   7 downloads
all the plating process was done by Vinci Chrome in Perth big thanks to Charlie and Mike
Attached File  068-1.jpg   72.21K   7 downloads
#2 _LS1 Hatch_
_LS1 Hatch_
Posted 02 June 2014 - 01:04 PM
More on similar stuff here...
http://www.tested.co...0-endoskeleton/
#3 _LXSS350_
_LXSS350_
Posted 02 June 2014 - 02:41 PM
Excellent stuff.
#4 _LS1 Hatch_
_LS1 Hatch_
Posted 02 June 2014 - 02:57 PM
Carbon fiber bumpers that are chrome plated....Hmmmmm... (Of course painted bars look better, but still...)
#5 _LXSS350_
_LXSS350_
Posted 02 June 2014 - 03:43 PM
I had looked at many versions of the chrome paint but the UV kills it for bumpers with direct sunlight. I am a chrome no rubber guy (on bumpers) even though from new the SS had painted bars the A9X however had chrome. I just relate chrome bumpers to the 70's and earlier style. Spent a lot of time polishing chrome.
Edited by LXSS350, 02 June 2014 - 03:45 PM.
#6 _Viper_
_Viper_
Posted 02 June 2014 - 08:44 PM
There is also the option of Spectra-Chrome
http://www.sprayonchrome.com/
I noticed my steel bumpers that I had "professionally" rechromed about 4 years ago have started peeling and rusting in places! so fibreglass bumpers and spectra chrome might be on the cars for me soon.
#7 dattoman
  • 16,487 posts
Posted 02 June 2014 - 10:15 PM
Will you be buying the equipment and gearing up to do this Clint ?
#8 _LXSS350_
_LXSS350_
Posted 02 June 2014 - 11:04 PM
Dave at Gas 78 Industries in Malaga has an expensive set-up for spray chrome but like everyone I have seen its fine if you keep your car in the dark and out of the sun  ........ or else you have to re-do them often.
After bumpers get new spray on chrome.
Once they get 6 months of sun the above bar ends up like this with chrome paint.
I have looked at all the Chrome paint systems in the world and this stuff doesn't like prolonged sunlight which is why they use Vinyl Wrap for those Chrome Cars like the Lexus LFA they did in QLD.
Edited by LXSS350, 02 June 2014 - 11:06 PM.
#9 _Viper_
_Viper_
Posted 02 June 2014 - 11:09 PM
Dave's actually in Wangara and im pretty sure he is using Spectra-Chrome, Nah had not thought about getting the gear for it Neil... too much on our plate already. If thats really how it looks after 6months in the sun tho (as in the above pics) I think ill be avoiding it.
#10 N/A-PWR
  • 9,639 posts
Posted 02 June 2014 - 11:10 PM
Nice,
also in WA, there is no regulation of paint types or reflectiveness, because I checked.
may have changed since.
#11 _LXSS350_
_LXSS350_
Posted 03 June 2014 - 12:49 AM
Sorry Wangarra, its the only Gas78 in perth as far as I know (he had a black torana a while back) I thought it was Mirra Chrome equipment he had ?..... but it was a while ago. Whichever system it was he told me it cost some silly amount to buy the set-up from the USA.
I am in the same boat as everyone else (with chrome bumpers) its silly expensive and the 2014 process is flawed. Chrome plating is certainly not done well like we used to be able to get in Perth back in the 70's. I have long been dubious of claims about the second coming of Christ ..... and thus about Chrome Paint systems as seen at SEMA and on flashy You tube video's. Sure it had me curious but full of questions and doubt. I have done all the emails, put questions on USA forums and done the phone around, its pretty well back to real chrome plating and for carbon-fibre bumpers the above process at Vinci's.
I like Datto's above solution and for our new superior composite parts its the most ideal of solutions on exposed car parts.
Also tagged with one or more of these keywords: bumpers
