does any one know if holden made a bosch electronic conversion kit for a lh 253 torana ? found one listed in a uc torana for a 4 cyl part no m38505 and a 6 cyl part no m38404 ?
_uc9669_
Posted 02 June 2014 - 06:24 PM
Posted 02 June 2014 - 07:03 PM
Posted 02 June 2014 - 07:10 PM
Change cap and rotor button.
There is a thread on here about them I think.
Posted 03 June 2014 - 07:49 AM
GMH didn't make them, Bosch did. You are far better off with a blue motor or black motor dizzy. What you need:
Dizzy.
Coil of the same car as the dizzy or get a new one (now one won't attach like the original, will have to go on the firewall or make a bracket to suit).
XE rotor button.
Plugs (gapped to right width) for a VC-VK or WB V8.
New spark lead for a coil lead. You can use the points dizzy cap and spark leads.
Bridge the pink and yellow wires at the ignition switch.
_uc9669_
Posted 03 June 2014 - 10:09 AM
wished i could use one off a blue motor , but in adelaide the htc said i cant have one if my car is on historic rego can only fit what the dealers would have fitted .
holdens packaged up the bosch kit of the time as a holden item .
_trna76hb_
Posted 03 June 2014 - 10:35 AM
Are serious about the dizzy & historic rego???
That is a bit over the top, not allowing rego due to dizzy
Ian
Posted 03 June 2014 - 03:48 PM
Serious? Who would check this?wished i could use one off a blue motor , but in adelaide the htc said i cant have one if my car is on historic rego can only fit what the dealers would have fitted .
Only visible difference is the module on the rear side of the distributor.
Posted 03 June 2014 - 04:31 PM
Agree, you'd never pick it. Just do it and keep your mouth shut. If it is a problem at inspection just change out the dizzy and coil lead, and have a normal 12V coil handy (not original 9V).
Posted 03 June 2014 - 09:00 PM
You can mount the module wherever you like if you extend the wires. Just needs to be a flat surface so heat can be transferred.Only visible difference is the module on the rear side of the distributor.
I had a 4x4 with a 202 in it and had it mounted on the inner guard in a small Tupperware container to keep the water out.
Posted 03 June 2014 - 09:17 PM
Or tell the idiots that a dealer fitted one off a Bedford, as Bedfords had HEI dizzys on 253 or 308 before VC or WB were released.
Posted 04 June 2014 - 07:56 PM
That's ridiculous, if you applied the same rules the Holden/Bosch EK80 conversion kit wouldn't be allowed either, because it wasn't available when the LH was sold new. They were released in 1978/79.
Are all the SA historic rego inspectors like this or is it just one ?
If they want it to 'look' original, fit a Petronix kit, it's probably the next best thing to the Bosch HEI. It uses the original coil, so you don't get a greater HT voltage, but you do gain dwell extension & the other advantages of going electronic.
Dr Terry
