Hydraulic lifters issue?
_Muzzy_
Posted 06 June 2014 - 07:59 PM
I have my fresh engine built and going now for about 300k, all is fine , my issue is
Some of the lifters are bleeding down overnight, so they clack and carry on for about 5-10 secs when started in the morning
As they were new when I built. The engine is there anything I can do or do I look at warranty
Posted 06 June 2014 - 08:37 PM
Hi Brian,
throw another set in, a different brand maybe, that is the Old kiss and tell method hey.
but Oldjohnno will have more info
Posted 06 June 2014 - 09:08 PM
Nothing wrong with your lifters. A bit of drive train clatter for 5 to 10 seconds at start up after sitting overnight is nothing to worry about.
Posted 06 June 2014 - 09:09 PM
My engine did the same after building it even with qaulity anti pump up lifters...I think it is pretty normal for hydraulic lifters and performance cams...
Posted 06 June 2014 - 09:11 PM
Pretty normal in bog stock engines also.
Posted 06 June 2014 - 09:16 PM
I am Deaf as some know,
which is why I have a different view on things,
but noise bothers me when I can hear it hey.
- like when a tappet is not working, it taps and is noisy
- and when the Big End Goes.
Hope you can get the Lifters sounding good soon.
Posted 06 June 2014 - 09:30 PM
They are made with bigger tolerances so they don't pump up. Makes sense?
I'd be pretty sure most lifters these days are made with bigger tolerances.
Posted 06 June 2014 - 09:35 PM
bet me to it rodomo was getting them put in my ol 6cyl motor years ago and the guy at gorringes told me they rattle on
start up,so decided to go the chilled based lifters.nothing wrong with them just didnt want the rattle noises
Posted 06 June 2014 - 09:44 PM
I used Standard Lifters,
they did the job no worries.
Just so you know
didn't meant I heard anything
Solids that is
_Muzzy_
Posted 07 June 2014 - 08:06 AM
The lifters are branded HT969 on the docket. I didn't think I brought anti pump lifters, but it does make sense, the engine is running a stage one cam, 6 degree increase in valve timing and 1 mm extra lift at the valve
I'm really happy with the performance,
The engine went from 61RWHP to 104 and didn't fall off, I just didn't want to rev it harder than 4200 at this stage
Posted 07 June 2014 - 11:50 AM
Anti pump up lifters are only used to mask a shortfalling somewhere else in the valve train, usually springs not up to standard.
If you dont need them, i'd be getting some proper ones. THat said, im not sure if that PN is for anti pump up or not?
Posted 07 June 2014 - 12:05 PM
AFAIK HT969 are standard lifters.
Did it say 'Anti Pump up' or 'Hi Intensity' on the box?
_Muzzy_
Posted 07 June 2014 - 05:26 PM
No, I brought them from a local spares place $60 trade, I took it out today for a 100k country cruise, very happy, I will see how it goes it the morning
Posted 07 June 2014 - 09:21 PM
It is normal for lifters that are holding valves open to bleed down so don't be surprised if you still have 10 seconds of chatter when you start her up in the morning.
Posted 08 June 2014 - 04:20 PM
Along with the big cams (heavy springs) thing above, Oil thickness and ambient, transient and radiant heat also play a part here.
Example, if you have thick oil in this motor in summer and it is now winter and you live in a freezing area you best switch to a thinner oil, this will also assist in reduced valve train wear and noise at start up.
Other than that, worn lifters and valve train will rattle for a few minutes till they warm up.
FWIW there are some shite lifters on the market these days, they ain't what the used to be, what with all our manufactures closing down etc etc.
_AED262_
Posted 20 June 2014 - 07:07 PM
Been down that road, sometimes it is the oil filter bi pass valve in the oil pump that is leaking and allowing air to enter the system. That's why they clack till they fill up with oil again. Sometimes you cannot fix it no matter what you do. Easy fix, have done it heaps of times, Adjust your rockers down till they are nearly bottomed in their travel, back them up a bit, then when they bleed down overnight, they only have a little bit to take up and bingo, FIXED.
Rod.
_nodster_
Posted 20 June 2014 - 08:18 PM
what cam are you running
Posted 20 June 2014 - 08:27 PM
Rod.
No offense intended, however, that is the stupidest idea I have heard in a long time to solve a non existent issue.
As I have said previously in this topic "It is normal for hydraulic lifters that are holding valves open to bleed down over time". GMH went so far as to advise there service dealers that lifters that took up to 30 seconds to quiet down after start up were within normal operating parameters and should not be replaced.
_Muzzy_
Posted 20 June 2014 - 09:20 PM
To answer some of the questions that got raised
Stage 1 billet cam , new lifters as stated
Oil pump was within specs and relief valve bore and piston polished and new spring fitted
New mains ACL race series
New big ends ACL race series plus 001" this reduced the clearance to 0015
Posted 21 June 2014 - 12:01 AM
Sounds Good Brian.
I only worry when I hear those big noises
and just throw another bottom end in then
#21
_AED262_
Posted 21 June 2014 - 08:32 AM
S pac,
Non existent issue eh!
Try telling that to customers after they complain about a loud ticking when they start their engine in the morning and you HAVE to fix it.
I will just tell them to come and see you .
#22
Posted 21 June 2014 - 08:57 AM
S pac,
That's fine mate, send them and I'll take the time to explain to them why the momentary ticking noise occurs and why it is nothing to be concerned about..
BTW, there are reasons why manufacturers specify maximum adjustment figures, generally in the range of 1.5 to 2 turns from zero lash for hydraulic lifters, and you think it's fine to far exceed the manufacturers recommendations. I'm guessing you are a mechanic and you should know better than to screw the lifters down to almost the full extent of their travel.
#23
_AED262_
Posted 21 June 2014 - 09:11 AM
Spac,
you have no idea how a hydraulic lifter works do you.
No I am not a mechanic, don't work on cars, only engines for a living for the past 44 years.
In the past I was the supervisor of many sections of the largest engine reconditioning plant in Australia at one point up to 100 engines a day.
One of my roles was supervisor of the hydraulic lifter section where 5 women reco'd around 1500 lifters per day. I do know what I am talking about and you obviously do not.
Ever heard about short travel lifters? Explain to me how they work and why and not something out of a book.
#24
_Muzzy_
Posted 21 June 2014 - 09:54 AM
BTW for the record the 173 has bridges with no adjustment, the billet cam has the same inner base circle as the std cam no impact on lifter position or pushrod preload
#25
_Muzzy_
Posted 01 July 2014 - 06:47 PM
I started it today after it sat overnight and had on 1 or 2 clack for about 2 secs, so perhaps better, not so sure
