Hi guys,
This is wording from the QLD incarnation of NCOP section LA (Engine).
"The mass of the vehicle referred to in Tables LA1, LA2 and LA3 is the original (unmodified) tare mass of the model vehicle fitted with the largest engine available for the model in Australia but without optional accessories (air conditioning, tow bars etc.). The mass of the vehicle, whether it is a sedan, station wagon, utility, etc., should be based on the heaviest sedan version of the model (not station wagon version) sold in Australia."
I'm wondering what is meant by the "the model vehicle fitted with the largest engine available for the model in Australia" part,. e.g. my car is an LC 4 cylinder 2 door 1159 cc, which was approx 812Kg kerb weight. The four door was 838Kg. The 1600s were slightly heaver and the 6 cylinder cars heaver again.
So is a "vehicle model" an LC Torana (including 6 cylinder cars), or a 4 cylinder LC torana (including 1600s), or is it my specific model code, which was a different model code to the 1600 cc engine car that came out later?? Obviously, depending what is meant by "vehicle model" will dictate what base weight can be used for working out max engine capacity. Unsure if anyone knows the answer?
Cheers,
Jules.
