LS1/LS2 conversion into a WB Statesman
190 replies to this topic
#101 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 25 February 2015 - 01:46 PM
Fuel pump from the Torana into the Statesman all mounted
Fuel pump now in the Torana
#102 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 12 March 2015 - 08:52 PM
This is probably something for the Commodore guys but should there be an O ring on this fitting? It is one of 2 fittings from the transmission pipe to the radiator. When I tightened it up tonight on the radiator the pipe was still loose. Bit frustrating as it all slowly coming together.
#103 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 28 March 2015 - 03:36 PM
Just wondering in the pic above, those two little radiator outlets go to the commodore overflow as theres two connectors on the commo overflow. The stato has one overflow. Should I just join the two commodore outlets into one?
So far I have connected the high pressure power steering hose, got speedflow fittings from Motorsport connections. Also connected the return line for power steering.
Connected radiator hoses as well. Slowly getting there
Edited by Bart, 28 March 2015 - 03:37 PM.
#104 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 28 March 2015 - 04:22 PM
Some shots of the steering box fitting and steering pump banjo fitting
#105 _1uzbt1_
_1uzbt1_
Posted 30 March 2015 - 02:43 PM
There is supposed to be a oring there but its not a normal oring, its flat and has a steel outer ring. They were at last time of buying about $15 from holden, go to a auto a/c shop and they should have what you are after as they are the same as the late model compressor oring for commodores and come in different sizes.
#106 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 30 March 2015 - 02:49 PM
Thanks mate
How about the two small radiator outlets. I was thinking of block them off all together then use an inline radiator neck with cap and with over flow outlet which can go to over flow bottle. Is this ok??
http://www.jegs.com/.../53098/10002/-1
Edited by Bart, 30 March 2015 - 02:50 PM.
#107 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 30 March 2015 - 04:14 PM
http://www.swishauto...ket-of-2-seals/
http://www.ebay.com....b#ht_1991wt_987
#108 _1uzbt1_
_1uzbt1_
Posted 31 March 2015 - 10:25 AM
that's them although the second link is a set of used ones wtf?
Theres probably a few ways to skin this cat. If you want to use what you have put the fitting that you link into the top hose and the highest point possible and block off one of the two 3/8 fittings on the rad. One goes back to the cross over pipe under the throttle body.
Cleaner again would be to use a VZ rad but you will need new fans and hoses, the vz has the bleed from the engine and a filler neck on the rad. The vz has different fitting layout and doesn't have that stupid crossover hose assy on the bottom
Upto vy use a header tank arrangement which is pressurised and non recovery, vz onwards use a normal style system with a recovery overflow tank.
Edited by 1uzbt1, 31 March 2015 - 10:26 AM.
#109 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 01 April 2015 - 07:44 PM
Thanks mate
#110 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 13 April 2015 - 11:16 PM
The motor is running in the Statesman, this website wont allow me to post the movie clip of it for some reason.
Its a bit loud with the exhaust noise straight out the ports :)
#111 purrlx
purrlx
  • 1,332 posts
  • Name:Danny
  • Car:LX hatch
Posted 14 April 2015 - 08:46 AM
Nice work Bart, always good to fire them up
#112 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 14 April 2015 - 09:11 AM
Sure is
#113 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 14 April 2015 - 09:46 AM
http://vid50.photobu...zpsygccrof5.mp4
#114 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 14 April 2015 - 05:33 PM
Well done Bart .....Now come over and sort out my wiring .....lol
#115 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 14 April 2015 - 08:43 PM
I can help you out with it if you like. Do you have the computer loom?
#116 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 14 April 2015 - 08:56 PM
Are you using factory computer?
#117 _LS1 Hatch_
_LS1 Hatch_
Posted 15 April 2015 - 12:51 AM
I like wiring too... :D
#118 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 15 April 2015 - 06:51 AM
Its all factory ls2 stuff ...but I have been told that I really need to run a ls1 computer
#119 _LS1 Hatch_
_LS1 Hatch_
Posted 15 April 2015 - 08:01 AM
LS1 and LS2 use different count reluctor wheels on the crank, and think the cam sensor was different between the 2 as well?
#120 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 15 April 2015 - 10:15 AM
Not sure about that LS1 to LS2 stuff but I can point out where the 12v and ground goes on LS1 computer and coils etc
Edited by Bart, 15 April 2015 - 10:16 AM.
#121 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 15 April 2015 - 10:38 AM
What year model is the engine out of?
VZ?
#122 Growla
Growla
  • 229 posts
  • Car:LX SL/R LS1 conversion completed July 2010
Posted 15 April 2015 - 02:45 PM
To my understanding the LS2 runs the same computer as an ls1 here in Oz. But the l98 runs the different reluctor.
Mark
#123 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 15 April 2015 - 02:49 PM
My motor is VE L98 6.0LT and yes there is a difference between the two computers not sure what is different but
#124 Bart
Bart
    Shit a brick
  • 2,559 posts
  • Car:LJ Torana
Posted 15 April 2015 - 03:41 PM
Pretty sure they're different
The VE had the smaller more powerful computer
Ill try to find out more about it
#125 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 15 April 2015 - 06:16 PM
Bart what did you do about the fly by wire for the throttle body as I want to run cable
