Rocket the not so GTR or XU1 !
#326
Posted 16 January 2016 - 06:28 AM
#327
Posted 16 January 2016 - 08:25 AM
#328
Posted 17 January 2016 - 03:41 PM
There is a warnerford triple SU manifold on Ebay at present
link I hope
http://www.ebay.com....d-/262244688951
for that price maybe worth getting for a spare!
peter
#329
Posted 17 January 2016 - 05:12 PM
I think you will find that they are off a Volvo 164/264. They are to suit the ventilated rotors.
This is the set up on my car but I've never known where they originally came from.
#330
_Agent 34_
Posted 17 January 2016 - 07:34 PM
1 more mill !
tip for today - bar coat and paint strait over if it does not fry up after BARCOAT - grant jurd brocks 72
WOT - has welded up the manifold and done a great job - thanks craig much appreciated
finished the engine bay today and put it all back together.
should change my footer to a " a man his dream and a also the biggest splinter in his foot " !
you will see my oil pump pick up in three pieces
I have no idea what the F@#$# i was pointing at in the other photo --- ahh that edit #3 is was the shiitty wallet what my missus bought me for christmas it broke real quick/. must have been trying to pay for the trorana upgrad
Edited by Agent 34, 17 January 2016 - 07:46 PM.
#331
_Agent 34_
Posted 17 January 2016 - 07:51 PM
also put the AF meter in the muffler. its also a lovely black heat painted now
Edited by Agent 34, 17 January 2016 - 07:52 PM.
#332
Posted 17 January 2016 - 08:08 PM
nice shiney blaack....mmmmmmm
#333
Posted 23 January 2016 - 08:05 PM
Ive ordered and paid for a set of those speed bleeders for the front calipers, rear drums and the hydraulic clutch. Not cheap but I wont have to pester wife and/or daughter to help bleed the system aagin.
#334
_Agent 34_
Posted 24 January 2016 - 09:03 PM
ive been doing heaps but im f#ucked and gong to bed.
the diffs out and the new one re build
new dif in tomorow + the front end re assemlbly
G
#335
_Agent 34_
Posted 26 January 2016 - 07:16 PM
diffs in and all the front end re build and back in.
motor back but not in.
still #@$^%& and going to bed after a massive feed of dominos pizza - which should be here in 20mns.
three days 1) one full diff change 1) full suspension change 1) rebuild the front K frame and suspension
1) case of beer , 2 panadol last night. 1 start of a bottle of red wine tonight
photos - I'm to #@$^%& to change over and reduce the size - will do this week.
motor and box in on the weekend.
been 20 days since the start.
never again gh - ( wayne 2 elcs ) that's why i dont have a race car !
G
#336
_2ELCS_
Posted 26 January 2016 - 07:50 PM
You can't say i didn't warn you LOL
#337
_Agent 34_
Posted 26 January 2016 - 08:14 PM
lol.back - too funny
no pizza yet must but a shit load of pissed ausies out there banging up the domino's line.
Edited by Agent 34, 26 January 2016 - 08:15 PM.
#338
_Agent 34_
Posted 30 January 2016 - 07:06 PM
motor and box back in.
sorry for the no photos - ill do some photos and explaining later.
a few this needed to fire the old girl up;
- wheel alignment
- extractors
- carbies
- tail shaft
- bleed brakes
A word of warning on the bolts that hold on the pressure plate - if the have not been replaced the the pressure plate wears the thread off the bolts and hence when you tighten them up they cannot hold the tension without breaking .
another day another issue - removing a snapped off pressure plate bolt from the fly wheel - it came out i prayed to the torana god and a lot of swearing.- easy out was my friend today- back the snapped off bolt from the starter motor side,
what really shits me is when you give your car to a shop and they just don't to the small things like get new bolts - it's a race car FFSS
g
Edited by Agent 34, 30 January 2016 - 07:12 PM.
#339
_Agent 34_
Posted 30 January 2016 - 07:28 PM
anther thing is the comp of the motor. it's an old school motor with a 12.1 comp flat tops and a 46cc chamber.
It made 202 hp at the wheels on 98.
both the engine builder and the dyno bloke " tilleys at brookvale " are saying - run on avgas from here on in.
didn't see this comming with the avgas.
luckly the australia distrubitor to AVGAS is 30 mns away - but u need to buy 200 ltrs
one more lesson
im sick of learning lessons FFS
#340
Posted 30 January 2016 - 07:54 PM
If your runing camshaft theres no reason you should need avgas?
#341
Posted 30 January 2016 - 08:18 PM
Another thing store any drums of Avgas at home off the ground on a pallet or some wooden blocks as the moisture from the concrete can cause problems with water absorption.
#342
Posted 31 January 2016 - 06:08 AM
http://powerplusfuel.com.au/ Try this stuff, they sell unleaded fuels, so no need for a pass book.
#344
Posted 31 January 2016 - 04:28 PM
What all that means in my understanding is that if you are a member of the NSW App J Association you are OK as it is an affialiated club with CAMS.
The Cams log book/pass is a sanctioned identification. It also means that you are probably able to go and buy it at Bankstown or Camden Aerodrome with the CAMS fuel Logbook. Of course ring them first to confirm. Some Aero clubs let you and others dont.
list of authorised suppliers
https://www.environm...lated-feb11.pdf
#345
Posted 31 January 2016 - 04:39 PM
The way I read the regs any CAMS license holder can buy it, which is good for me
#346
_Agent 34_
Posted 31 January 2016 - 07:01 PM
Ok I'll start with the differential;
I swaped put the old CIG welded centre and also the housing - both the bolt arms that hold on the shocks were broken off at some stage and welded back on - who knows how this happened - but the whole housing needed to be replaced.
I skip all the painting stuff as it's boring and a part of the build that i would rather forget. But it allowed me to make modifications to the front K frame to just give the extractors a bit more room.
I drilled the backing plates to give me some more air flow into the brakes, it's got 3/4 inch wheel cylinders - with later model push rods.
the brake shoes are race and riveted.
the diff got some baffles as well.
_Agent 34_
Posted 31 January 2016 - 07:08 PM
Next was the suspension and putting the diff in and setting up. the usual shit with doing the handbrake line and then also the brake lines.
was good to go through the whole suspension out back and tension up all the bolts and check everything.
I put new springs in and also spax double adjustable shocks and ended up with this.
I put the longer wheel studs in as well when i got the axles made.
Next was the front K frame and this also had new bushes and parts.
_Agent 34_
Posted 31 January 2016 - 07:10 PM
WOT179 - manifold repair -
gave it a machine off and a quick touch up and you cannot even see the join where it was welded.
_Agent 34_
Posted 31 January 2016 - 07:15 PM
engine and box in. Also wrapped the pipes to keep the heat down in the engine bay.
did a bit of porting of the intake manifold and also the header gasket to better match the intake and port.
bought some trumpets for the old SU's
you can see were we took some weight off the fly wheel and put in the bigger ARP bolts.
Engine's in and manifolds fitted.
Posted 31 January 2016 - 09:14 PM
Good stuff Grant.
You have sure worked hard over the Christmas break and done an awesome job.
I'm looking forward to seeing the Rocket back at the track.
