Hehe
Rocket the not so GTR or XU1 !
#501
_2ELCS_
Posted 27 August 2016 - 11:21 PM
#502
Posted 28 August 2016 - 01:02 PM
If the thing is throwing belts off then it is most likely an alignment problem between the w/p pulley, the Harmonic balancer and the alternator. The alternator pulley is most likely the culprit.
I tried to load a photo of the bracket but the file is too big have to work out how to make it smaller
Edited by piquet, 28 August 2016 - 01:02 PM.
#503
_Agent 34_
Posted 29 August 2016 - 07:10 PM
thanks - Peter sent you a PM .
Ive googled the part and cannot seem to pin point the item.
g
Col - where did you get those shirts from - 10 bucks r a steal - AT LOWES ? LOL
Edited by Agent 34, 29 August 2016 - 07:11 PM.
#504
Posted 29 August 2016 - 07:43 PM
#505
_Agent 34_
Posted 05 September 2016 - 07:52 PM
No many photos but the following has happened;
- the new consul is wired in and operational - looks pretty trick and happy its wired correctly now and it's all been checked by the auto electrician
- re mounted the ignition coil to a new bracket off the booster bracket so it's not on the engine anymore
- the engine is in but no accessories r on
- got my new 7" inch sprint masters to swap with the 6.5
one more mill, it's going to be one sick sorted machine I cannot wait - it's been a long time between drinks.
g
Edited by Agent 34, 05 September 2016 - 08:01 PM.
#506
_duggan208_
Posted 06 September 2016 - 01:07 AM
A long time between drinks, Yeah, tell me about it, but better and worth it in the end.
Regards
#507
_Agent 34_
Posted 09 September 2016 - 05:44 PM
a few problems as usual;
I have an old style larger romac and the new fandangled larger water pump pulley is hitting it so it's back the GMH standard OEM one
the webber manifolds were a prick to fit and a one piece one may seem easier I'm now not sure as trying to fit the manifold to the extractors and square up is difficult and requires finessing
re did the fuel line in braided metal line and also put in a metal fuel filter
EFing rotor button from repco does not fit the distributor - as i bough a new one and specifically said bosch electronic dissy-
the gear stick needs adjusting and a bend put into it and laid back - it works now but could work better for hand clearance - the new consul is very close
looking for a monday fire up
#508
Posted 09 September 2016 - 06:06 PM
#509
Posted 09 September 2016 - 08:24 PM
Grant, just put the water pump pulley in the lathe and machine the lip that is fouling the balancer. Is only a millimetre of so.
Or sell me the oversize pulley!!
Steve
#510
_duggan208_
Posted 10 September 2016 - 01:04 AM
How do your ports match up with the one piece manifold? I've heard that REPCO stands for rip every poor C off. but I'm sure that's just not true!
Regards
#511
_Agent 34_
Posted 10 September 2016 - 06:51 PM
Jon ,
i have a warneford old style - three piece which was match ported. There pretty good at the moment as it allows some fiddling.
but when there is three things that need to be adjusted - exhaust flange - intake port - intake manifold there has to be of massaging and not the type where there is a happy ending in 15mns !!!
my point was that if you were trying to fit a " one piece intake manifold " then there would be less individual adjustment .- but the " sum of the product equals end result " so my argument is somewhat irrelevant it's just that one may take more time to resolve.
BTW Jon what was the outside diameter of your ATI balancer for interest just to check against my old romac.
Steve the pulley will cost you $15000 bucks and I'll personally deliver tomorrow - LOL - whats doing with the mighty 186 man - will you be on the grid soon
Some say if you don't machine the fuel pump lobe off it'll act like a pump and push oil up that breather rather than allow oil to return to sump.
Arrimar - i was trying to work out what you were referring to but now i get it - I built a baffle on the hole which is part of the block off plate - but it was one of my concerns of keeping the oil away from the breather hole - time will tell on this one.
Looking for a hit out at wakefield spring historics
g
#512
Posted 11 September 2016 - 07:20 PM
Grant, I waited all day with cheque book in hand. Where were you?
The 186 is coming along. Might be back by the end of the year.
Steve
#513
_Agent 34_
Posted 12 September 2016 - 04:29 PM
Ha- nice work Steve good to hear it's been a bit quiet and look forward to catching up. bummer i was going to pay everyone with that money
it's alive with really good oil pressure.
I cannot believe it after 12mths of planning.
lodged my entry to HSRCA spring meeting at wakefield today.
G
#514
Posted 12 September 2016 - 07:57 PM
well done Grant.....good to hear ""it is alive""
#515
_datpsi_
Posted 13 September 2016 - 09:48 PM
#516
_Agent 34_
Posted 14 September 2016 - 05:00 PM
intake runners on today
engine run in this arvo.- once done cut filter and check for nasties
change oil tomorrow morning to normal oil
dyno tune
take filter off and cut again - to check after power tune and power runs for nasties
it idols well and sounds really crisp off idol
fingers cross for a clean bill of health by tomorrow lunch time after the oil filter is checked.
Posted 14 September 2016 - 06:36 PM
but maybe "idle"....or is it really your idol?? Lol.
Regardless...great work..looks much tidier than before...let us know how it goes eh?
#518
Posted 14 September 2016 - 07:16 PM
Lookin' good Grant.
Am keen for dyno run details
#519
_Agent 34_
Posted 14 September 2016 - 08:14 PM
Last time i joked that i sold two kids. this time i had to sell the next door kid plus another one of mine.
I swear that if this goes bang I'm selling the car and asking for a refund on the motor off a few parties.
all will be revealed tomorrow.
#520
Posted 14 September 2016 - 08:31 PM
There is only one thing I could add to your set up and that is to drill and tap the flat bosses on the inlet manifold and bolt a thick piece of Aluminium Flat bar, like 15 x 8 mm onto to those pads and that will stiffen up the individual three piece manifolds. Probaly at some time bget a flt bar welded on and that will esentially convert it into a single piece manifold.
I'd probably also get rid of the little hoses between the manifold parts and screw some brass plugs into the holes. I don't think the balance tubes are really necessary between the carbies.
Ask the Tilleys/Dyno man . they will know for sure.
Edited by piquet, 14 September 2016 - 08:37 PM.
#521
Posted 14 September 2016 - 09:23 PM
There is only one thing I could add to your set up and that is......
Ram tubes?? What's going on in front of the carbs Grant?
#522
_duggan208_
Posted 15 September 2016 - 12:54 AM
I'll measure up the balancer I just need to remember to do it.
regards
#523
_Agent 34_
Posted 15 September 2016 - 11:25 AM
got custom ones made by the dyno guys think we got 170mm on the front
#524
Posted 15 September 2016 - 03:01 PM
I'm looking forward to seeing the dyno results and how close or not we guessed the jetting specs.
#525
Posted 27 September 2016 - 03:48 PM
Hey Grant, a couple of photos of the Rocket from Wakefield. They were taken by a forum member and posted to the Group N Historic Touring Car FB page.
Grant_1.jpg 137.95K
4 downloads
Grant_2.jpg 174.56K
6 downloads
