STEERING COLUMN BEARINGS
Posted 14 July 2006 - 06:48 PM
Does anyone know if or where I can get new bearings for a lc steering column?
_TUFF_
Posted 14 July 2006 - 07:30 PM
Josh
Posted 14 July 2006 - 10:08 PM
Posted 18 July 2006 - 11:35 PM
Posted 20 July 2006 - 12:57 AM
Its a dodgy plastic bush, mine was worn out and the steering was slopy so i replaced it with a steel bearingAnyone know if it is meant to be a bearing or just a plastic bush?
Posted 20 July 2006 - 01:29 AM
ATM the column & getting the rack recoed is what is holding me back from putting the car back together.
Posted 21 July 2006 - 09:39 PM
I had to machine up an aluminium bearing holder as the bearing was a fraction too small, this is a solid ball bearing and so it dosnt sit straight in the clomn tube but fits in quater way.
To hold it in the column tube i used aluminium flat bar approx 6" log and a hole is drilled in one end of it and is bolted on the same bolt wih holds the column tube to the fire wall. The other end of the flat bar is fork shaped and sits on the bearing which holds it in when the bolt (in the other end previously mentioned) is tightened.
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/DSC00281.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/DSC00282.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f312/toranacar/DSC00286.jpg[/img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage://https://cache.gmh-torana.com.au/i50.photobucket.com/albums/f...img]]My Webpage
Edited by Bart, 21 July 2006 - 09:52 PM.
Posted 21 July 2006 - 09:45 PM
_73LJWhiteSL_
Posted 22 July 2006 - 02:21 PM
Steve
Posted 22 July 2006 - 06:55 PM
If I can get another lc column I will do what Bart has done so that I have something to replace the NLA bush,especially on a v8 conversion.
Bit of a nuisance pulling a column apart on your own & putting back together,very weird set up.
Posted 22 July 2006 - 07:34 PM
Posted 22 July 2006 - 08:21 PM
Bending the bottom of the column i suppose is another alternative i guess. Shouldnt be too hard as its mild steel
Posted 26 July 2006 - 08:37 PM
Put column back to together,bottom bush didn't like extra load of turning 18 by 8 rims & isn't good enough as it has too much wear so I'm going to have to put a bearing in.
Do you have a part number for a bearing place down this way?
Do you think it will work if I just have the bearing sitting on top of the bush inside the tube?
Posted 26 July 2006 - 09:23 PM
What you can do is measure the shaft and column tube and see if they can match it.
If its the same case as mine i can machine up a bearing holder like mine for you.
I got some 6061 aluminium i could use i think, ill have to check.
Linear Bearings, Unit 19, 14 Sheridan Close Milperra Sydney, 97927188
Its hard to say if it will fit on top of the bushing, i wouldnt bother personally, i would just start from scratch by doing the above. Unless you find an original bush.
Come to think of it it may be that my steering column is a little off centre which is why the bearing didnt fit straight on, but get a spherical bearing anyway just in case all the columns are like that, besides a spherical bearing is whats used in hot rods etc so its ok to use.
Edited by Bart, 26 July 2006 - 09:32 PM.
Posted 26 July 2006 - 09:36 PM
Posted 27 July 2006 - 01:03 AM
Just one question, did you cut the column shorter, so the end of the column is closer to the fire wall? This is a mod i think is done when you do a V8 conversion.
Posted 27 July 2006 - 07:19 PM
How did you go with Linear Bearings by the way?
Posted 28 July 2006 - 12:00 AM
On mine I cut the shaft on the rack,put the lh knuckles.Moved the column over but I did bend the plate at the bottom of the column to move it forward a little.
I had a look at an lj column,looks different to my lc one,not sure why though.
Posted 28 July 2006 - 12:13 AM
Hmmm do you have pics of it?
Posted 28 July 2006 - 12:44 AM
I dont know if there is meant to be another bush or cover there,also the lj one I saw looked like it had a longer shaft & stuck out more.
They are either different or something isn't right on my column,the only thing for certain is that the bottom bush is stuffed lol.
#21
Posted 28 July 2006 - 12:49 AM
I can get the part # for you if you like
They are still available from Holden under the genuine #
I think it was $71 from memory
Not sure if they are same as LH-LX though
#22
Posted 28 July 2006 - 03:10 PM
#23
Posted 28 July 2006 - 05:43 PM
I'll give it a go tommorrow after work or maybe Sunday.
Dangerous:I knew about the differences such as different splines,steering wheel,blinker assembly & ign lock.
I was just hoping I could have the same mod done to the base of the column like Bart has done since I can't get the bush.
#24
Posted 28 July 2006 - 07:37 PM
Let me know how it goes
#25
Posted 28 July 2006 - 08:53 PM
Go check one of those out
