* * * * * 1 votes
69 LC RAT Concept Build
69 LC RAT Concept Build Willow Bullet Dynamic Compression Ratio
148 replies to this topic
Poll: IMAGE SPLITTING (23 member(s) have cast votes)
Does the Split Image look aligned enough
  1. Voted YES (6 votes [26.09%])
    Percentage of vote: 26.09%
  2. Voted Almost (3 votes [13.04%])
    Percentage of vote: 13.04%
  3. Voted NO (14 votes [60.87%])
    Percentage of vote: 60.87%
Would you consider having a Image split for linking Threads
  1. Voted YES (7 votes [30.43%])
    Percentage of vote: 30.43%
  2. Voted NO (16 votes [69.57%])
    Percentage of vote: 69.57%
How would you Rate this Image method
  1. Voted 10 Excellent (3 votes [13.04%])
  2. Voted 5 Average (7 votes [30.43%])
  3. Voted 1 Waste of Time (13 votes [56.52%])
    Percentage of vote: 56.52%
Vote Guests cannot vote
#76 rodomo
  • 18,041 posts
Posted 12 November 2014 - 09:52 PM
  ZZZZZZzzzzzzzzzzzzzz
#77 N/A-PWR
  • 9,639 posts
Posted 10 July 2015 - 07:51 PM
Slow process, but have some Magic Inner Sills made by Mike Catts now:-
Attached File  IMG_6838.JPG   39.7K   1 downloads
Attached File  IMG_6840.JPG   32K   0 downloadsAttached File  IMG_6839.JPG   37.65K   1 downloads
#78 rodomo
  • 18,041 posts
Posted 22 August 2015 - 12:15 AM
@ NA-PWR : (21 August 2015 - 11:09 PM) I love the rain, but a Shed is good, tell you what, I will do an hour on the RAT Sunday
#79 Ice
  • 15,204 posts
Posted 22 August 2015 - 12:32 AM
He needs to do more than an hour
#80 N/A-PWR
  • 9,639 posts
Posted 23 August 2015 - 07:04 PM
Ok Rob,
I did 2.5 hours cleaning up the shed,  :D
1.5 hours removing the 'K' frame easily,  B)
and here are some photo steps to tilt the body up off the 'K' Frame,
whether the car has full interior or not.
Also, when the gearbox is there, just undo the tail-shaft,
cross-member, clutch, speedo cable and any engine connections:-
Attached File  IMG_6940.JPG   52.55K   0 downloads - before
Attached File  IMG_6941.JPG   47.05K   1 downloads - undo steering knuckle
Attached File  IMG_6942.JPG   56.03K   2 downloads - undo top of 'K' frame bolts
Attached File  IMG_6943.JPG   46.66K   0 downloads - undo rear of 'K' frame bolts
Attached File  IMG_6944.JPG   46.12K   0 downloads - undo front brake line.
Attached File  IMG_6945.JPG   54.09K   0 downloads
Attached File  IMG_6946.JPG   24.29K   0 downloads
Attached File  IMG_6947.JPG   38.45K   0 downloads - jack the centre of diff up.
Attached File  IMG_6948.JPG   42.92K   0 downloads - use the smallest top of car stands for this job.
Attached File  IMG_6950.JPG   40.43K   0 downloads - pivot point is 38mm wide.
Attached File  IMG_6951.JPG   42.56K   2 downloads - cut stands smaller for clearance.
Attached File  IMG_6952.JPG   39.15K   0 downloads - lube the pivot point with grease.
Attached File  IMG_6953.JPG   37.15K   0 downloads - insert stand at front of rear diff leading arm, so the body can pivot here.
Attached File  IMG_6954.JPG   26.38K   0 downloads - lower Torana onto the stands, tapping them around till they seat solid.
Attached File  IMG_6955.JPG   28.83K   0 downloads - put tyres in boot for weight.
Attached File  IMG_6956.JPG   61.49K   0 downloads
Attached File  IMG_6957.JPG   31.99K   1 downloads
Attached File  IMG_6958.JPG   40.15K   0 downloads
Attached File  IMG_6960.JPG   60.28K   0 downloads
Attached File  IMG_6961.JPG   46.49K   0 downloads
#81 N/A-PWR
  • 9,639 posts
Posted 23 August 2015 - 07:06 PM
Attached File  IMG_6962.JPG   44.77K   2 downloads
Attached File  IMG_6963.JPG   43.85K   3 downloads
Attached File  IMG_6965.JPG   27.22K   3 downloads
Attached File  IMG_6966.JPG   63.06K   3 downloads
Attached File  IMG_6967.JPG   48.42K   2 downloads - present for the RAT from Gene.  :spoton:
#82 RallyRed
  • 8,158 posts
Posted 23 August 2015 - 07:11 PM
love the wheelstand idea!!!  neat.
#83 N/A-PWR
  • 9,639 posts
Posted 23 August 2015 - 07:20 PM
Yes Col, thank-you.
This is how I change out a blown up motor,
and roll in the already ready 'K' frame with short motor on,
and then roll back in after doing the head and cam swap.  :3gears:
takes about 3 to 4 hours.
#84 _Bomber Watson_
Posted 23 August 2015 - 07:33 PM
Never thought to cut the stands down and put them there.
Good idea.
#85 Ice
  • 15,204 posts
Posted 23 August 2015 - 07:39 PM
If your going to work under that i would be wanting you to make a support bar under the very front Dave
saftey first bud
great idea though
Start stripping bro
#86 N/A-PWR
  • 9,639 posts
Posted 23 August 2015 - 07:52 PM
Yes Gene boss,
this method is good for certain v8's,
so you can change the spark plugs.  :D
Was told about this method by a Torana Drag racer DJ, 30 odd years ago.
#87 rodomo
  • 18,041 posts
Posted 23 August 2015 - 08:10 PM
Sadly Dave, as your pics aren't date stamped, it never happened. :tease:
#88 N/A-PWR
  • 9,639 posts
Posted 23 August 2015 - 08:17 PM
But Gene only gave me the Press yesterday.  :banghead:
#89 N/A-PWR
  • 9,639 posts
Posted 23 August 2015 - 08:33 PM
Rob only wanted pictures, and now he has changed his mind,
 and now want's a time stamp in the Photo's, I wish I knew that.  :furious:
#90 N/A-PWR
  • 9,639 posts
Posted 24 August 2015 - 06:44 AM
Ok Rob,
Here is a screen shot of all the Photo dissembling Times:-
Attached File  Untitled.jpg   94.69K   10 downloads
#91 _Bomber Watson_
Posted 24 August 2015 - 07:50 AM
The screenshot isn't timestamped.
#92 N/A-PWR
  • 9,639 posts
Posted 24 August 2015 - 09:33 AM
Ha ha DJ,
Is showing times for reference purposes.
#93 Covert
Covert
  • 1,987 posts
  • Car:LH
Posted 24 August 2015 - 09:53 AM
Well done Dave, it getting the car back down gently a one man job or do you need a mate to help?
#94 N/A-PWR
  • 9,639 posts
Posted 24 August 2015 - 10:05 AM
Almost a perfect balance Mav,
Just only need to add weight to the boot as needed,
as this the way she is,
 is movable up or down with a finger. :driving:
#95 Covert
Covert
  • 1,987 posts
  • Car:LH
Posted 24 August 2015 - 01:11 PM
Cool, I didn't realise it was that easy
#96 N/A-PWR
  • 9,639 posts
Posted 24 August 2015 - 01:56 PM
Yes Mav,
As you can imagine,
you just need to give it a yank,
 to break loose from the 'K' frame.
#97 Covert
Covert
  • 1,987 posts
  • Car:LH
Posted 24 August 2015 - 03:18 PM
Your a man of many talents Dave :)
#98 N/A-PWR
  • 9,639 posts
Posted 24 August 2015 - 03:31 PM
Thank's Mav,
So next job is moving the 'K' frame out of the way,
and tilting the body down at front,
then remove the rear end.
#99 rodomo
  • 18,041 posts
Posted 24 August 2015 - 07:45 PM
Ok Dave, sorry, well done. Just one tech question? Was the grease dilithiumupselfide or clackeraplugside?
#100 N/A-PWR
  • 9,639 posts
Posted 24 August 2015 - 08:31 PM
G'day Rob,
the grease is - LITHPLEX TAC EP2, superior multi purpose high temperture.
Also tagged with one or more of these keywords: 69, LC, RAT, Concept, Build, Willow, Bullet, Dynamic, Compression, Ratio
