Loosing coolant via overflow
15 replies to this topic
#1 _aussie too_
_aussie too_
Posted 21 July 2014 - 07:38 AM
Could anybody shed some light as to why every now and then , the motor spits a heap of coolant out the radiator overflow pipe.
Motor is a mild 308, alloy radiator with thermo fans , never gets hot and has a cleanable filter in the top hose.
Was driving it all day yesterday and it did it once, then not again for the rest of the day.
#2 _trna76hb_
_trna76hb_
Posted 21 July 2014 - 01:16 PM
Do you a have recovery radiator cap fitted  for over flow system?
Ian
#3 N/A-PWR
  • 9,639 posts
Posted 21 July 2014 - 01:22 PM
so when the Motor cools down again, the overflow bottle allows the coolant to go back into the Engine.
#4 _steve253_
_steve253_
Posted 21 July 2014 - 05:07 PM
My 253 use to do this. It just started doing it one day a few years ago. I bought a holden header tank from rare spares and fitted it on the overflow hose. Since then I have had no problems and the radiator is always full.
#5 _aussie too_
_aussie too_
Posted 21 July 2014 - 05:35 PM
Ian
Not one hundred percent sure , it's the cap that came with the alloy radiator
#6 N/A-PWR
  • 9,639 posts
Posted 22 July 2014 - 06:59 PM
Hi Wayne,
Pulled mine apart to show the bit's and pieces,
now the main part is the centre nipple/valve which opens and closes,
depending on the engine's coolant expansion or contraction:-
Attached File  IMG_5672.JPG   93.02K   4 downloads
Attached File  IMG_5673.JPG   105.9K   4 downloads
Attached File  IMG_5675.JPG   68.7K   5 downloads
so the main big seal opens to let out the pressure, and the little one allows the coolant back in.
last picture is depressed to open the little one
#7 _oldjohnno_
_oldjohnno_
Posted 23 July 2014 - 07:41 AM
There's a good chance that there isn't anything wrong at all. Most of the time, if the radiator has been completely filled, the engine will spit out a cupful or two once it gets hot enough. If you keep replacing this excess water it'll keep spitting it out. Next time it does it don't top it up but monitor the level after each drive. If it keeps losing water you have a problem but if it stays the same it was probably just overfull.
#8 _J.A.W._
_J.A.W._
Posted 23 July 2014 - 01:30 PM
Does it occur when driving?
Or only due to heat soak after switch off & when stopped?
Can you hear it boiling in the above listed situation?
In what temp range does your thermostat operate?
AFAIR, when the ADR 27 emission controls included hotter thermostats, a coolant overflow/catch tank was usually fitted..
#9 76lxhatch
  • 7,208 posts
Posted 23 July 2014 - 03:35 PM
Exactly. As the coolant heats up it expands, and you (should) have a radiator cap that is rated to a certain pressure. Once the expanding coolant exceeds this pressure, the cap releases excess which either goes to the overflow bottle when fitted, or on the ground. When it cools again it contracts back - if you have a suitable recovery cap it has a secondary valve allowing return of coolant from a suitable recovery overflow bottle. If the overflow is mounted too low or does not have a hose below the coolant level then it won't work and your radiator will not refill itself as the coolant cools.
Without a (working) recovery system its not unusual for the top tank to be half empty, and this is not a problem for vehicles like Toranas whose cooling systems were designed this way. Bear in mind that an overflow/catch bottle is not necessarily a recovery system.
#10 N/A-PWR
  • 9,639 posts
Posted 23 July 2014 - 04:33 PM
I would agree with a non-overflow system have some coolant missing all the time and stay's at that level, thank's. +1 ^ ^^
#11 _aussie too_
_aussie too_
Posted 27 July 2014 - 01:06 PM
Thanks for all the great info, it appear that the radiator has been supplied with a recovery style cap.
Went and brought a none recovery cap , but the rubber seal is just a fraction to small.
Bit stumped now as to what cap will fit
#12 _J.A.W._
_J.A.W._
Posted 27 July 2014 - 01:13 PM
If the rad is designed for a coolant overflow recovery system, maybe you should fit one?
#13 _J.A.W._
_J.A.W._
Posted 27 July 2014 - 01:27 PM
Are you near any 1/2 decent Repco-type place with a helpful/knowledgeable old bloke behind the counter?
Could take your cap in & ask him to do you a suitable non-recovery cap replacement..
#14 _aussie too_
_aussie too_
Posted 27 July 2014 - 05:55 PM
Hahahahahah.......... My local Repco has 17 year old girls behind the counter that wouldn't know shit from clay
#15 EunUCh
EunUCh
  • 2,769 posts
  • Car:japos
Posted 27 July 2014 - 06:32 PM
:lol: ..unless they stood in it then trimmed the toe nails with the teeth..
#16 _J.A.W._
_J.A.W._
Posted 27 July 2014 - 07:30 PM
Unlees.. ..they are assk-to-mouth exponents, & that IS something they know all about.. L.O.L..
