Lj lower control arm
Posted 31 July 2014 - 03:48 PM
The lower control arm on the drivers side has a crack where the ball joint sits. It is on the underside and It looks like it is spot welded on. Any advice is appreciated. Will upload photos asap
Dan
_judgelj_
Posted 01 August 2014 - 12:00 AM
Posted 01 August 2014 - 04:45 AM
_judgelj_
Posted 01 August 2014 - 11:45 AM
Well the control arm essentially has a a big hole and 4 rivet holes for which to fit the ball join in. If it looks like a plate on top, it sounds like the ball joints mounting bracket, in which case i would drill out the rivets, and fit new ball joints in the front. If not, i don't see why you cant weld it closed?
You have to be careful with this one, last thing you want is to pop out a ball joint. Holden front ends try to pry ball joints apart.
Posted 01 August 2014 - 12:17 PM
Upper arms have 4 rivet holes for securing the ball joint, lower arms don't.
_judgelj_
Posted 01 August 2014 - 01:00 PM
Oh shit you are right, im getting my control arms mixed up. The lower is just a press in type, isnt it? Has ribbing all around the side like a coin?
Posted 01 August 2014 - 01:32 PM
Yes and yes, and am I ever wrong?
On second thought don't answer that.
_judgelj_
Posted 01 August 2014 - 01:58 PM
Haha dave i was actually going to mention the fact that you are right, once again. Thought i'd keep it to myself though, dont wanna go inflating egos!
_Hamster_
Posted 01 August 2014 - 02:16 PM
ard to know without a pic but these may help some people remember what what is.
Posted 01 August 2014 - 06:26 PM
just replace it, rather than weld. easy to come by
Posted 02 August 2014 - 11:20 AM
_judgelj_
Posted 03 August 2014 - 05:44 PM
That's just a reinforcement plate. Up to you i suppose, weld it to keep it going then replace it if you find another. Ill guarantee that it wont crack again (in the spot it;s welded)
Posted 03 August 2014 - 07:53 PM
then add these
http://www.xu-1.com....rior_parts.html
Edited by zodiac GTR, 03 August 2014 - 07:54 PM.
_LONA-CK_
Posted 07 August 2014 - 08:02 AM
Hi everyone,
Dan
zodiac GTR
then add these
what you have said is the reason why these were added to the xu1 from the start of the CK xu1 in 1971, this crack and ball joints popping out happend alot in the 1970 bathurst race as the pre 71 bathurst cars never had them.
cheers gong
