A9X parts original
14 replies to this topic
#1 _nicka9x_
_nicka9x_
Posted 02 August 2014 - 09:10 PM
I have a LX Torana hatchback that has been sitting in a shed for years. It looks like it was in the process of being turned into an A9X but was never finished. The cars seems to have many parts that look like off an A9X. The only one that I am certain is A9X is the radiator. Photo of 2 radiators together, the one with the number stamped on it is A9X. I have posted photos of the front end, diff and rims. Just want to know if they are A9X and if so, how much are they worth now. The rims are 7 inch with an 1 inch offset but when I removed the tyre there was no stamp inside, just on the outside around the valve,  MI 0 4 14 JS. The steering rack had stamped on it 9940277 which I believe is UC Torana. The LH Steering arm has stamped on it GM5249 which I believe is L34. The stub axle looks similar to an A9X that I have seen in this forum. Is the compression bump stop common to the A9X or to cars with RTS? The diff looks like Salisbury with disc brakes, (discs and calipers not fitted but have). The upper brackets on the car have been modified because A9X had UC floorpan to suit the Salisbury diff. Please feel free to comment if any information I have posted is incorrect.
#2 Shiney005
  • 9,498 posts
  • Car:Toyota Mirai
Posted 03 August 2014 - 01:26 AM
The large square bump stop block is the same as L34. I think A9X had it as well.
#3 ls2lxhatch
  • 5,332 posts
Posted 03 August 2014 - 01:18 PM
A9X stub axles are HZ One Tonner stub axles. They are the same as HQ-WB just made heavier and heat treated.
Left 9943695
Right 9943696
A9X Steering arms
Left 92001894
Right 92001893
Your steering arms are L34.
Left 9935249 (GM5249)
Right 9935250 (GM5250)
The diff does not appear to have the A9X bump stops so it is probably a modified Salisbury from a HQ-HZ sedan.
The A9X did not have a UC floorpan to fit the Salisbury diff, the UC floor pan is completely different to the A9X floor pan. GMH produced a patch section to suit that Salisbury diff in the LX floorpan.
You will find some more information here.http://ls2lxhatch.com/suspension.htm
Edited by ls2lxhatch, 03 August 2014 - 01:20 PM.
#4 yel327
  • 13,589 posts
Posted 03 August 2014 - 01:27 PM
I used to have an LX years ago that I trurned an early LH crossmember into an A9X copy, and also stuck an A9X Salisbury into it, but the mods don't look like mine did.
#5 _nicka9x_
_nicka9x_
Posted 03 August 2014 - 05:08 PM
Thanks ls2lxhatch
I have included another pic diff bump stop
#6 LS1LX
LS1LX
  • 1,931 posts
Posted 03 August 2014 - 06:33 PM
They look like genuine parts to me. They were probably take off a wreck back in the 80's.
We did a sunbird hatch for a customer a couple of years ago (2-3) which had a complete genuine A9X front end on it, those parts were for sale back in the day before the big boom hit
#7 ls2lxhatch
  • 5,332 posts
Posted 03 August 2014 - 08:49 PM
Thanks ls2lxhatch
On this angle it is clear that the bump stops are taller than standard so possibly A9X.
On this angle it was not so obvious.
Edited by ls2lxhatch, 03 August 2014 - 08:50 PM.
#8 VIXL34s
VIXL34s
  • 177 posts
  • Name:jeff
  • Car:2x L34s,+ HZ GTS, A9X HATCH.A9X SEDAN
Posted 03 August 2014 - 10:08 PM
The diff appears as though it may be from a a9x, the numbers on the rims I don't think are correct and they should be 14 x 6 with either 256 or 231 stamped on them. Somebody may be able to tell what those rims of yours are. My a9x has the same number on the radiator
#9 yel327
  • 13,589 posts
Posted 03 August 2014 - 10:16 PM
Could all be bits off a stolen one too.
#10 N/A-PWR
  • 9,635 posts
Posted 04 August 2014 - 04:34 AM
Hi Nick,
Nice lot of parts, and the 5/8 inch thick Coil Springs on the front too.
#11 myss427
myss427
  • 1,636 posts
Posted 04 August 2014 - 08:46 AM
The diff is A9X, it has the bulged tubes that go into the casting, all Salisbury diffs other than A9X were same diametre all length.
#12 VIXL34s
VIXL34s
  • 177 posts
  • Name:jeff
Posted 06 December 2014 - 09:54 PM
would you be interested in selling the radiator, i have gen a9x hatch which i would like to get the corect one for
#13 VIXL34s
VIXL34s
  • 177 posts
  • Name:jeff
Posted 20 April 2016 - 09:50 PM
#14 StephenSLR
StephenSLR
  • 6,714 posts
  • Name:Stephen
  • Car:1976 LX SL/R
Posted 21 April 2016 - 11:36 AM
Was the A9X radiator different to a standard V8 Torana radiator, apart from added thermo fans?
s
Edited by StephenSLR, 21 April 2016 - 11:36 AM.
#15 myss427
myss427
  • 1,636 posts
Posted 21 April 2016 - 01:19 PM
It was a fine 2 core with sender in top tank only, very hard to find the original style core for the real ones.
