Great Info John Gong,
So I have the XU1 Disc's, but not the 'K' Frame for the '69 RAT ', hmm:-
69 RAT.JPG 122.2K 7 downloads
Posted 07 August 2014 - 01:21 PM
Posted 07 August 2014 - 02:52 PM
Posted 07 August 2014 - 03:06 PM
Will be replaced with 343mm Disc's Gene.
They look like scrap metal Dave
Question:-
I wonder if I can have the Rear 343mm x 24mm disc's all round,
and remote hand brake caliper for the little LC?
Edited by GASPOWER, 07 August 2014 - 03:16 PM.
Posted 07 August 2014 - 04:19 PM
that pics was for the wheel spacers not the disc dave,,, the disc is not original xu1 it is a after market disc
the original xu1 disc is the same as this but thicker in the wall
cheers gong
Posted 07 August 2014 - 04:35 PM
Thank's Mate.
cheers gong
Now we know
Posted 07 August 2014 - 05:34 PM
Dave, your disc is LH/LX Torana.
Posted 07 August 2014 - 08:36 PM
Didn't some of the LC XU1's and early LJ XU1's on the front end have a bit of round steel welded on each side of the lower wish bone instead of the re-enforcing that was used to strengthen them up.
AL
Posted 07 August 2014 - 11:11 PM
what is this bracket for ?
Edited by zodiac GTR, 07 August 2014 - 11:14 PM.
Posted 07 August 2014 - 11:27 PM
Hold the brake line splitter?
Edited by slr_v8, 07 August 2014 - 11:27 PM.
Posted 08 August 2014 - 05:19 AM
Thank-you Dave,
that's amazing, I would never of thought, this was an upgrade.
Very unusual looking Disc, as I have never seen one hey,
just goes to show how much I only looked at the little Torana's.
Edited by GASPOWER, 08 August 2014 - 05:23 AM.
Posted 08 August 2014 - 07:57 AM
AL
sorry AL i have never seen this on a factory car.
this pic was use to show members the difference between the 1970 bracket used to the 71-72-73 one, if you have one of the later cars that use the p/valve set up you will then know the difference.
this pic below is of the PV marked in green and the 1973 front bracket marked with arrow
cheers gong
Posted 08 August 2014 - 01:50 PM
Love the cut away view Gong......
Posted 08 August 2014 - 02:29 PM
So here is the Bracket on my to be reconditioned,
69RAT 'K' Frame:-
Brake bracket.JPG 101.3K 6 downloads
Posted 08 August 2014 - 04:16 PM
the thing that none of the xu1s had was these plate that are found on all other disc brake models
Wasn't aware of this change. Assume that it is to help braking temperatures in race conditions rather than because of any potential problem with running the wider discs? which setup would people favor for a non concourse car?
Posted 08 August 2014 - 07:01 PM
I believe that they welded in a bit of steel rod on each side to start with, then later on they came up with the re-enforcement bit you weld in, maybe its only on the very first LC XU-1's.
AL
Posted 08 August 2014 - 07:05 PM
Yes, thank's very much Gong.
Posted 08 August 2014 - 07:08 PM
AL
hi AL
the 1970 and early 71 batches of LC XU1S never had the reinforcements it only started with the 71 CK cars, but the reason was they where cracking thats why the change was made so you may well have seen some earlier cars with this part you talk of, its just i have never seen it thats all mate.
cheers gong
Posted 08 August 2014 - 07:10 PM
hi dave could you pick this car for bein a late 72 or early 73 by this pic and if so how???
cheers gong
Posted 08 August 2014 - 07:14 PM
No worries Gong, I think that's what Harry Firth came up with first.
AL
Posted 08 August 2014 - 07:17 PM
Which Dave and Picture John?
cheers gong
Posted 08 August 2014 - 07:20 PM
sorry mate you i was talking too
cheers gong
Posted 08 August 2014 - 07:39 PM
A guess,
type of fitting used on the brake line connection,
other than that, I have never looked into this,
and will from now on.
Posted 08 August 2014 - 07:46 PM
AL
Hi AL,
March 1971 is when the Dealers were advised it was permissible to arc weld 7/16" reinforcement rods on either side of the LCA's of XU1 used in arduous conditions or competition.
Posted 08 August 2014 - 08:04 PM
Thanks for that Dave, so the Dealers got the Nod to do it, makes sense as the Factory would not of had the time, Harry and the HDT Boys came up with 7/16 steel rod fix, I wonder how many cars got it done.
AL
