AL or DAVE any pics of this earlier mod,,, would be great to see
cheers gong
Posted 08 August 2014 - 08:08 PM
cheers gong
Posted 08 August 2014 - 08:23 PM
Ah, I got you now.
cheers gong
Posted 08 August 2014 - 08:39 PM
Crikie John the Gong,
Great work, once again Bud
Posted 08 August 2014 - 09:35 PM
cheers gong
Here is a pic Gong.
AL
Posted 09 August 2014 - 02:50 AM
gee and guess what i tossed a set of them away some years ago now they came on a v8 1970 lc xu1 fxxk me i thought they was there to beef them up for the use of the 8,,, just gos to show we can all learn something.
thanks for the pic mate,,, sometimes its hard to get things like that out of some people
the next question is why was this nut inducted into the little torana??? anyone have a theory???
cheers gong
Posted 09 August 2014 - 02:54 AM
gees, and is that a crimped Nut Gong?
like, it binds onto the thread to help with not coming loose?
Posted 09 August 2014 - 03:04 AM
No worries Gong
If you come across them again, you know now what they are, I wonder how many cars were done by the Dealers, great fix up by Harry until they added the better set up.
AL
yes mate they are like the lock nut, see dave before the use of these the cars use to use nut and lock washer if you look at your 69 model you will notice that,,, my theory to this nut is if you delete all the lock washer from a LC/LJ TORANA you would be taking weight from the car, see each year they made these cars go FASTER handle better and more SAFER.
but in sayin all that DAVE it is just my run down on it and sound good to me until someone else can give me better facts
cheers gong
Posted 09 August 2014 - 03:07 AM
AL you can tell your another tassy lad as you are like me and dont seem to sleep
just one more question for you what sort of weld do you think was used on them back in the day???
cheers gong
Posted 09 August 2014 - 03:08 AM
Great Man Gong,
We would never know without you Bud, thank's
or Al for that matter
Here is the 69 RAT nut:-
IMG_5737.JPG 76.72K
4 downloads
Edited by GASPOWER, 09 August 2014 - 03:16 AM.
Posted 09 August 2014 - 03:17 AM
cheers gong
My guess Arc Welding Gong, but I am no expert on welding
Posted 09 August 2014 - 01:47 PM
cheers gong
October 72 GMH issued revised/increased torque specs for the UCA pivot shaft nuts for HQ & LJ. Nuts not maintaining tension on the big washer against the pivot bush inner tube allowing the bush inner tube to spin on the pivot shaft.
In my mind it figures that at the same time the engineers were probably looking for a better solution to implement into production, hence the switch to the self locking oval nuts.
Posted 09 August 2014 - 03:37 PM
The whole shaft, bush & nut look to be HQ. I'd wondered why there were rounded pivot shafts
& my XU1 & the spare K member I had were flat. 1st thought it was XU thing.
John's pic promted me to put the spare arm against 1 in my HQ & look identical..tho I'm unable to
read castings.
We know the LJ shared parts with the HQ but as the Q was released mid 1971, would the pivot
shaft assembly been fitted to LC's that were still in production or would it have been held till the
72 LJ release?
J
Posted 09 August 2014 - 04:28 PM
Didn't some of the LC XU1's and early LJ XU1's on the front end have a bit of round steel welded on each side of the lower wish bone instead of the re-enforcing that was used to strengthen them up.
AL
sorry AL i have never seen this on a factory car.
zodiac GTRwhat is this bracket for ?
this pic was use to show members the difference between the 1970 bracket used to the 71-72-73 one, if you have one of the later cars that use the p/valve set up you will then know the difference.
this pic below is of the PV marked in green and the 1973 front bracket marked with arrow
cheers gong
thanks gong,this is the one i have 2/73
Posted 10 August 2014 - 05:53 AM
spot on for your 73 build mate.
cheers gong
Posted 29 January 2020 - 08:27 AM
Hi sablemet7/73 I know its been 6 years and I sure hope you have not been waiting on me for an answer,,, But no they didn't use them until the 73 cars were in production.
Sorry cheers gong
