Marty's Aussie Box Build!
84 replies to this topic
#76 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 19 August 2014 - 05:42 PM
Just ordered input XU1 input and cluster, overhaul kit second gear and 4 syncros.
No turning back now.
#77 _CraigA_
_CraigA_
Posted 19 August 2014 - 10:34 PM
I use John at JVR in Blacktown and have just installed his 'race' gearbox. Top bloke and extremely helpful.
He is not AussieFourSpeeds.
All new gears (with 1.38 third) and larger lay shaft mod. $850 exchange.
I had a 1.25 box from John and flogged it at track days and drag meets. Only replaced it as I am doing extra track stuff and after four years thought it was time for a refresh and bonus of better ratio.
Edited by CraigA, 19 August 2014 - 10:34 PM.
#78 TerrA LX
Posted 20 August 2014 - 06:42 AM
Thank you for clarification.
#79 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 27 August 2014 - 09:37 PM
Join me as I unwrap these parcels.
Edited by sibhs, 27 August 2014 - 09:38 PM.
#80 Potta
Posted 27 August 2014 - 09:42 PM
NIce!!!!
Fresh, unbashed and uncrunched gears!
Have you got it back together yet?
haha, just kidding.
Lets hope this is the last time you do this for a while, don't let Gene drive and you should be alright  :spoton:
#81 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 27 August 2014 - 10:03 PM
I'll paint the casing tomorrow and start prepping for assembly.
#82 N/A-PWR
  • 9,636 posts
Posted 27 August 2014 - 10:26 PM
:party: Party Time Marty,
Looking the Goods Mate.  :spoton:
I am not allowed to paint at Home, the Wife is an Artist and say's I leave the bristles in.
#83 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 21 September 2014 - 11:09 PM
Casing all painted. Used epotec etch then a 2k red oxide that was matted down.
With Jonos help he pressed on the bits to main shaft and input shaft. We then assembled Main shaft and cluster but I forgot to fit reverse gear.
Bugger, pull lay shaft, main shaft out and fit forgotten gear.
Another thing to note is the circlip on front bearing in kit is wrong size which keeps front retainer from seating properly.
The selected levers that are fitted to the side cover have worn so are sloppy. I think to fix this I'll have to weld the hole sides then file to fit?
To any beginner considering doing their own rebuild box, it's doable but having help at hand is advisable.
Thanks Jono. :-)
Marty
#84 N/A-PWR
  • 9,636 posts
Posted 22 September 2014 - 01:32 AM
What a Beautiful Set of Gears You have Marty,
let alone the lovely Box to go into.
#85 sibhs
sibhs
  • 2,718 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 23 September 2014 - 09:48 PM
Welded 1st 2nd selector hole and filed that to fit, not recommended, time consuming with a small file.
Dug out some spares but all 6 are different. Decided to cut and weld a good base to the required top.
Bolted them all up, adjusted linkages and tried to get it as pictures.
Just need another curly wirly clip.
That's it.
Piece of piss. ;-)
Marty
