202ing a Beemer
241 replies to this topic
#1 SA EH
SA EH
    Another Holden 6 tragic
  • 1,050 posts
  • Name:Jonesy
Posted 19 August 2014 - 10:10 PM
Hey all,
Finally i've had enough time to hit the keys again to show you what's been happening behind the scenes.
Picked up a cheap 1989 BMW E30 318i that was destined for a life less boring & decided to get busy.
The plan was always to drop my 202 from the EH into it, so while i was using that engine, I got to work on the rest of the car. So far it's copped a complete stripping of trim, a 5 stud rear conversion, new rear shocks, springs & mounts, discs, pads & caliper rebuilds. The front end can wait for now until I know how it will sit with the engine in place.
Diff ratio will be the shortest I can possibly go with the small case E30 diffs, 4.45.
Picked up a couple of 15 x 7 beemer rims that will have some ET Street 235's fitted shortly & the fronts will stay as the 14 x 6 for now too.
Got an RCI racing seat & 5 point harness to bang in, aswell as a line locker.
The idea is to keep things to a minimum, so even the spare wheel tub was cut out, which i will plate with some thin alloy. Also the brake booster has been ditched & the master cylinder will now be mounted on the drivers side on the firewall.
I began to dummy up another engine to check the fit & its pretty good, i think...
With an EH sump fitted, it actually sits on the crossmember at the middle step of the sump and with good clearance to the firewall for the pipes, trans & head etc...
My question is, should i recess it back into the cabin while i have the chance now??
I'm thinking like 6 - 8 inches into the cabin, but then getting to the carbs may be an issue, aswell as everything else that is...
Here's a few shots for you anyway, more to come.
Attached File  040.JPG   226.74K   16 downloads
Attached File  041.JPG   246.02K   10 downloads
Attached File  030.JPG   277.92K   8 downloads
Attached File  033.JPG   216.17K   7 downloads
#2 SA EH
SA EH
  • 1,050 posts
  • Name:Jonesy
Posted 19 August 2014 - 10:14 PM
Here's a few more.
Attached File  034.JPG   244.62K   6 downloads
Attached File  037.JPG   229.21K   6 downloads
Attached File  039.JPG   195.41K   6 downloads
Attached File  070.JPG   328.08K   8 downloads
#3 _Bomber Watson_
Posted 19 August 2014 - 10:15 PM
I used to have an 85 E30 318.
Much as i like what your doing, it was possibly the best handling car i have owned to date.
If your setting it up for drag use, could i suggest you set it up moreso for khanacross or similar type events, if such an event is local to you?
I'd love to get another one and set it up for turny turny racing.
Everything is better with a 202 though.
If i had realized one would fit so nicely in the bay i certainly would have kept it!!!!
Edited by Bomber Watson, 19 August 2014 - 10:16 PM.
#4 SA EH
SA EH
  • 1,050 posts
  • Name:Jonesy
Posted 19 August 2014 - 10:20 PM
An Den...
Attached File  073.JPG   320.88K   6 downloads
Attached File  074.JPG   303.14K   6 downloads
Attached File  075.JPG   328.02K   8 downloads
I thought about it bomber, but i love my drags.
Would be great to turn corners, but i would go the whole hog with coil overs, big brakes, keep it manual. Might aswell call myself a doriffftor...
It'll cop a manual steering rack swap & a rear swaybar which it never had either.
Edited by SA EH, 19 August 2014 - 10:23 PM.
#5 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 19 August 2014 - 10:24 PM
Love yer work.
Recess it now...cut the passenger side of the firewall back as well as the middle to give carb clearance.
You will probably have to do a tunnel as well when you shift it back, or move the original tunnel back with the firewall section still attached to it and fill the gaps.
#6 WhaleOilBeefHooked
WhaleOilBeefHooked
  • 1,671 posts
  • Car:LJ GTR
Actually looks fairly central where you've got it Jonesy and almost made to fit... That'll put the wind up dem beemer boys......
#7 SA EH
SA EH
  • 1,050 posts
  • Name:Jonesy
Posted 19 August 2014 - 10:29 PM
The drama is, i think it actually sits in there too good to cut the firewall back!
 But moving it rearwards was the original plan too.
#8 TerrA LX
Posted 20 August 2014 - 06:44 AM
What does a 202 and a BMW have in common?
#9 warrenm
warrenm
  • 2,117 posts
  • Car:1972 LJ Torana
Posted 20 August 2014 - 07:19 AM
I like it.
Stick car?
It would be nice if it had a solid rear end instead of the IRS, be easier to set the rear up to get it of the line.
#10 SA EH
SA EH
  • 1,050 posts
  • Name:Jonesy
Posted 20 August 2014 - 12:27 PM
Ha ha, NUTHIN!
I guess maybe only coz they're at my house and both awesome😜
Yeah Warren it would be great if it was a solid rear end but you can't have everything, so I'll have to work with it & see how it goes.
And no, not stick. Sorry bud...
#11 TerrA LX
Posted 20 August 2014 - 01:12 PM
Ha ha, NUTHIN!
Any other takers, Wot? Bomber?
#12 _LS1 Taxi_
_LS1 Taxi_
Posted 20 August 2014 - 01:27 PM
Let me guess....
Both not really suited for the intended purpose of the finished product.
EDIT: Oh and by the way, love the thread and will follow with interest.
Edited by LS1 Taxi, 20 August 2014 - 01:28 PM.
#13 TerrA LX
Posted 20 August 2014 - 01:42 PM
Sorry for the thread steal but I thought it was a fitting bit of useless trivia,  The Bosch Jetronic fuel injection system as used on the 202 in the VK is the same system that was used on both BMW Cars and Motorcycles...
#14 Oversteer
Oversteer
  • 244 posts
  • Car:LH SLR5000
Posted 20 August 2014 - 02:10 PM
Hmm interesting, its not really hard to fit a big 6 in an E30, doing a E46 M3 S54 3.2L into one with a mate at the moment....bolt in with very few mods, and surprisingly cheap to buy the complete wrecked M3, sold off everything except motor, wiring etc and ended up paying less than 2K for what we kept...248Kw @ 7900rpm ITB screamer. Still needs a turbo tho i reckon !
Edited by Oversteer, 20 August 2014 - 02:10 PM.
#15 SA EH
SA EH
  • 1,050 posts
  • Name:Jonesy
Posted 20 August 2014 - 02:29 PM
^^^^Totally.
We work on these things all the time & toy around with ideas on what would work & what wouldn't. That s54 conversion would be the dux guts if work was paying for it, and for punting it around corners.
#16 greens nice
greens nice
  • 1,011 posts
  • Name:Kevin
  • Car:EH Holden
Posted 20 August 2014 - 05:56 PM
Love it!
What do these weigh standard?
If recessing the firewall and moving the engine back makes it easier to work on I wouldn't hesitate to do it now, especially around the rear carb and the harmonic damper when doing turning the engine over for lash adjustments.
The IRS should be more forgiving with an auto.
Edited by greens nice, 20 August 2014 - 05:58 PM.
#17 TempesT
TempesT
  • 493 posts
  • Name:James - JImmy or Jim
  • Car:LX hatch
Posted 20 August 2014 - 09:35 PM
what happened to the interior? carpet, seats, plastic undertray and inner guard plastic.....
I have the same in a m20b20
Edited by TempesT, 20 August 2014 - 09:38 PM.
#18 SA EH
SA EH
  • 1,050 posts
  • Name:Jonesy
Posted 20 August 2014 - 09:40 PM
Out of the factory Kev, about 1065kgs or 2350lbs.
This one will see the weighbridge too, if only to compare it to the EH. Hoping to tip the scales at around 900kgs.
Still not sold on the recessing yet, it looks too good at the moment.
Interior is in the bin Jim, along with anything else that was considered "weight".
#19 _SLEDGE_
_SLEDGE_
Posted 24 August 2014 - 02:59 PM
looks like a fun project!
seriously don't get you 202 tragics, but admire you for your loyalty  :D
#20 _Bomber Watson_
Posted 24 August 2014 - 03:15 PM
If you dont get why, you probably havnt been beaten by one recently :P
#21 SA EH
SA EH
  • 1,050 posts
  • Name:Jonesy
Posted 02 October 2014 - 09:12 PM
Alrighty then, its been a while but here's an update...
After clearancing the tunnel & firewall, the engine sits nicely back as far as practicable. Made up the engine crossmember and had a win with the trans support... I can use the original bracket in the most rearward position, sweet as...
Fab'd up a nice sheet of ally to cover the spare wheel well & made the seat frame with harness attatchments built in.
Had some refreshments...
  • Attached File  024.JPG   41.35K   1 downloads
  • Attached File  015.JPG   62.17K   2 downloads
  • Attached File  016.JPG   68.36K   1 downloads
  • Attached File  010.JPG   75.3K   4 downloads
  • Attached File  011.JPG   75.11K   2 downloads
  • Attached File  014.JPG   64.58K   1 downloads
#22 SA EH
SA EH
  • 1,050 posts
  • Name:Jonesy
Posted 02 October 2014 - 09:19 PM
The master cylinder has been relocated over to the drivers side, with the brake lines modified to suit.
Had to fab a new linkrod off the brake pedal to the master, nothing hard there.
Found some cool headlight protectors on fleebay that will let me get rid of the headlights. Just have to mount them behind the front grilles & paint some eyes on em.
  • Attached File  023.JPG   31.75K   1 downloads
  • Attached File  022.JPG   33.3K   1 downloads
  • Attached File  019.JPG   33.26K   1 downloads
  • Attached File  017.JPG   69.68K   1 downloads
#23 SA EH
SA EH
  • 1,050 posts
  • Name:Jonesy
Posted 02 October 2014 - 09:24 PM
Finally I've made the call to swap the front end over to 5 stud. Using E36 328i front struts/discs/calipers with E30 mounts, should let me put on whatever wheels I want now.
  • Attached File  021.JPG   27.08K   1 downloads
  • Attached File  020.JPG   31.72K   3 downloads
#24 SA EH
SA EH
  • 1,050 posts
  • Name:Jonesy
Posted 02 October 2014 - 09:29 PM
Its still sitting a bit high for its purpose but ill wait until the other engine/trans, radiator, fuel tank etc are in before I set the height.
#25 warrenm
warrenm
  • 2,117 posts
Posted 03 October 2014 - 07:11 AM
Looking good. I see there are a few bottles of "thinking" fluid in the first pic. :spoton:
