202ing a Beemer
#76 _Bomber Watson_
Posted 25 May 2015 - 11:40 AM
#77
Posted 25 May 2015 - 06:54 PM
So do you think there is enough room for a 308 between the towers? That might fix your ride height issue.
#78
Posted 25 May 2015 - 07:06 PM
#79
Posted 26 May 2015 - 07:39 AM
Be a bit congested with a 308 as ballast under the bonnet & a 202.
#80 _Bomber Watson_
Posted 26 May 2015 - 07:55 AM
#81
Posted 26 May 2015 - 08:04 AM
#82
Posted 26 May 2015 - 12:02 PM
Not a fan of 202's but this is an awesome project!
#83
Posted 26 May 2015 - 12:43 PM
looking the goods mate
#84
Posted 27 May 2015 - 02:30 AM
#85
Posted 27 May 2015 - 09:28 AM
#86
Posted 27 May 2015 - 02:18 PM
And you know I've got the 6 banger nats on my bucket list, so will see how I go for this year but if not, it'll happen one day.
#87 _duggan208_
Posted 27 May 2015 - 11:25 PM
yeah, that would make me come out to see that run.
regards
#88 _Agent 34_
Posted 28 May 2015 - 06:32 PM
Mate - i got the GTR badge at work - PM me your address
F yeah go bro go
Haa
#89
Posted 12 August 2015 - 10:15 PM
Winter sucks.
It's been a bit slow going but there's not much in the way of drags happening here anyway so, all good.
Front & rear bumpers are now fitted up with the smallest usable brackets made up.
Filled up a heap of firewall holes.
Match ported the extractors, welded on O2 sensor bung & flange joint.
Fuel cell is mounted up & fuel lines sorted.
Repositioned breather tank as it was getting a bit crowded at the front there...
Coolant overflow tank lifted from the EH fitted nicely on the lhs.
Found & fitted a new alloy radiator which was a heap lighter than the old copper unit, stoked!
Ran a couple of descent earth straps onto the engine too.
Tailshaft has had the hilux rear flange treatment which apparently is a far better & heavy duty alternative than the bmw unit.
Mounted up the trans cooler as close to the trans as I could, made up some metal lines with short hose joiners, so hopefully trouble free.
Just need to whack the tailshaft & diff back in, make up a trans crossmember to get a good tailshaft angle.
Fit up the extractors & inlet manifold.
Probably fitting up a tailshaft loop.
And wiring it all up....
Enjoy!
Posted 12 August 2015 - 10:20 PM
Posted 13 August 2015 - 12:31 PM
looks the goods mate. the more you move the warmer you get.. keep at it
#92
Posted 13 August 2015 - 02:42 PM
What does a 202 and a BMW have in common?
A car the 202 comes in (VB-VK) shares the same wheel stud pattern as a BMW (5 x 120mm)?
Love the concept of this thread too. Would be even better to see someone do an LS1 into one.
Edited by yel327, 13 August 2015 - 02:43 PM.
#93
Posted 13 August 2015 - 07:22 PM
#94 _Bomber Watson_
Posted 13 August 2015 - 08:40 PM
I fail to see how an LS1 could be better.
#95
Posted 13 August 2015 - 08:44 PM
Probably 300HP better
#96 _Bomber Watson_
Posted 13 August 2015 - 08:47 PM
Not likely?
#97
Posted 13 August 2015 - 08:50 PM
Not likely?
Take ya blinkers of DJ
#98 _Bomber Watson_
Posted 13 August 2015 - 08:52 PM
Stock LS1, ~ 300hp.
Stock 202, ~ 150hp.
Cost to get stock LS1 into a car = ~ 300hp from 202 anyway.
Your maths is shit Gene.
Edited by Bomber Watson, 13 August 2015 - 08:52 PM.
#99
Posted 13 August 2015 - 09:29 PM
Lighter, more power, better economy etc etc. Car would be a weapon. Engine itself wouldn't be all that bad cost wise if you got a good used one. It is the transmission where the cost would be unless I guess you left the 4L60E.
300hp is pretty conservative too for an LS1. As it'd need an exhaust made and probably you'd do some sort of cold air intake as well, a stock LS1 with these mods and even a mail order tune will pull 280kW on an auto engine or 300kW with a manual. Something you'll never do with a 202 unless you blow it.
I still love the concept though - I'd love to see a piston engine jammed into an RX7 in a similar way.
#100
Posted 13 August 2015 - 09:37 PM
