Harness clips
14 replies to this topic
#1 lx308
lx308
  • 2,843 posts
  • Name:Tony
  • Car:Nuffin. Goin touring.
Posted 21 August 2014 - 08:43 PM
Hi all, any of the clips on the page linked correct for attaching the harness to the inner guards on a LJ?
http://www.rarespare...ISHING PA&pno=0
Mine didn't have any so I have no idea.
#2 S pack
  • 15,727 posts
Posted 21 August 2014 - 11:16 PM
Tony
There are two different sizes used in the LC/LJ engine bay to hold the wiring harness to the wheelhouse panels.
RC0008 and RC0016 are the style. As to whether they are the correct sizes is hard to tell from the pics.
Also the original clips are black phosphate coated not zinc plated as the rares clips appear to be.
#3 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 22 August 2014 - 08:59 AM
Thanks Dave.
#4 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 22 August 2014 - 07:16 PM
I'm assuming the dog leg piece on the clip hooks into the hole in the inner guard?
935d7e2f4d4cc78b04419edc7eadd026_zps92e5
#5 _sunburst73-xu1_
_sunburst73-xu1_
Posted 22 August 2014 - 07:34 PM
That's right Tony and the ones in the pic looks like they only suit the passenger side(short ones)
They can be a bit tricky to clip in.
Edited by sunburst73-xu1, 22 August 2014 - 07:38 PM.
#6 jd lj
jd lj
  • 2,115 posts
  • Name:James D
  • Car:LJ
Posted 22 August 2014 - 07:46 PM
If these are the smaller type of the two, they're also used for holding the windscreen washer hose onto the bonnet. I think on the passenger side the middle one is the larger version of this and the front and rear one's are the small type. The drivers side should use the big ones as it holds the wiring harness and the windscreen washer hose to the inner guard.
#7 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 22 August 2014 - 07:55 PM
Yea, the bigger ones would be the other clips listed.
Have I run the harness through the correct hole? Don't want to be in the shit...
ae33c929b9d26b565adcfc12c3174dc3_zpse3e8
#8 sibhs
sibhs
  • 2,719 posts
  • Name:Martin
  • Car:LJ Coupe S
Posted 22 August 2014 - 08:01 PM
Yep, correct hole. Left one for washer tube.
#9 lx308
lx308
  • 2,843 posts
  • Name:Tony
Posted 22 August 2014 - 08:04 PM
Ahh, I was trying to think wtf was in that one. I was thinking bonnet cable, which I haven't got.
The missus will be happy that we chose the right hole. :)
#10 _macdou_
_macdou_
Posted 23 August 2014 - 09:42 AM
Is there is diagram or pic of the correct under bonnet wiring / washer hose clips anywhere?
#11 _SableMet7/73_
_SableMet7/73_
Posted 24 August 2014 - 12:33 PM
Got a couple of manual pic's I've been cropping/enlarging so's to bring them up to A3....(optics on the blink)
only washer hose stuff tho.
LC/J 6 cylinder:
Attached File  scan0007.jpg   253.24K   47 downloads
Attached File  6bottle.jpg   208.87K   16 downloads
Clip: hose to engine hood(B- B)...SP1905...x2
Clip: hose to front wheel housing(A-A)...SP1779   x2
Clip: hose to RH hood hinge bracket (E-E)...7413370- same as harness clip behind engine/below heater.
The hinge clip(E) in the pic is shown fitted on top, both that I have are fitted to route the hose under the bracket..so?
Cant do photo's as camera U/S & wouldnt say my car is untouched but looking at this, aint too far off.
Clip image "section C-C" is for 4 cylinder.
Cant see anything listed for the LH harness/battery cable & mine look to be as the RH clips...but ?
Can someone fill me in on the washer bottle clip underneathe in the 2nd pic? I know its for supporting the bottle
when full so's not to stress the upper mounting tabs(plastic) when cornering to the right, but havnt seen 1 or seem
to have the hole for it. Was it an LC thing as pic is from LC manual?
Tried 3 times to type capitol bee bee but that bloody smily head with glasses keeps appearing...frocking PC is pulling the piss!
Edited by SableMet7/73, 24 August 2014 - 12:38 PM.
#12 S pack
  • 15,727 posts
Posted 24 August 2014 - 02:38 PM
Never ever seen one of those reservoir retaining clips on a Torana. Mine never had one and no extra hole for one.
#13 Kockum
Kockum
  • 478 posts
Posted 24 August 2014 - 02:47 PM
That reservoir clip is P/N. 7437259.
Only relevant for HK/T/G .
Lazy buggers used above models drawing .
#14 _LC870_
_LC870_
Posted 24 August 2014 - 03:18 PM
That  is  in  correct .
All  1969  and  1970  LC  6  cylinder  models  were  fitted  with  the  washer  bottle  retaining  clip  from  the  factory.
The  clip  was  deleted  for  1971  vehicles  onwards.
Regards  LC870
#15 Kockum
Kockum
  • 478 posts
Posted 24 August 2014 - 05:01 PM
I stand corrected  .
