Hatchback front spoiler and flare issues
lx torana hatch flares
14 replies to this topic
#1 _TRRANA_
_TRRANA_
Posted 24 August 2014 - 05:27 PM
A year ago I purchased a complete fibreglass bodykit from spoilertek and today it was time to trial fit it to my lx hatch when I couldnt believe the problems in front of my eyes.
First is the 2 piece front spoiler... it doesnt overlap in the middle...
Am i doing something wrong here??
Attached File  20140824_124735.jpeg   106.52K   15 downloads
Attached File  20140824_124941.jpeg   109.04K   17 downloadsAttached File  20140824_124821.jpeg   97.87K   14 downloadsAttached File  20140824_124949.jpeg   118.49K   13 downloads
Has anyone had this problem with spoilertekreplicas spoilers or other makers??
#2 _TRRANA_
_TRRANA_
Posted 24 August 2014 - 05:39 PM
The rear flares on the inside it curves upwards exposing the bottom rear qtr lip...
Doesnt look right and im not happy
the flares on my 4 door cars don't do this
Attached File  20140824_130040.jpeg   126.82K   14 downloadsAttached File  20140824_130107.jpeg   71.69K   15 downloadsAttached File  20140824_130051.jpeg   89.25K   15 downloadsAttached File  20140824_130030.jpeg   88.11K   17 downloadsAttached File  20140824_132743.jpeg   145.39K   16 downloadsAttached File  20140824_130057.jpeg   91.02K   14 downloads
#3 Tyre biter
Tyre biter
  • 982 posts
  • Car:Should have gone with Palais...
Posted 24 August 2014 - 07:37 PM
Not sure what is going on there but you seem to be right, the rear quarter should not protrude past the rear flares;
And that gap at the front isn't right either;
The side of your front spoiler - the photo makes it look like there is some slack there - is there?
I mean, can you put them firmer against the nosecone/front fender and buy some length by any chance?
You also have to trim them for front flares - your's (like mine) are for a flare-less car hence the need to trim.
I was kindly schooled on this a while back - the schooling was in page 3 of my build thread - there are several posts/photos and so scroll down the entire page - hope this helps better explain: http://www.gmh-toran...-unknown/page-3
In addition, the below photo you can see how the front spoiler on my car is trimmed ahead of the flare;
Not much help sorry, but perhaps this shows you how they are supposed to fit.
Type 'spoilertek' into the forum's search engine and trawl through the posts.
Mixed reviews but most seem to depict there are issues with fit, quality and the like - sorry to be the bringer of bad news :(
Cheers, TB
Edited by Tyre biter, 24 August 2014 - 07:52 PM.
#4 _TRRANA_
_TRRANA_
Posted 24 August 2014 - 08:40 PM
Thanks very much TB...Been doing some searching on here...both positive and negative results on spoilertek. We have tried our best with trying to massage the the spoiler closer together to overlap but it puts the indicators way out of center. When I get time im ringing spoilertek and emailing photos to get an explanation of why these are way off. Paid $730 for a full kit im filthy.
#5 76lxhatch
  • 7,204 posts
Posted 24 August 2014 - 08:52 PM
Pretty typical of most flares these days, you just have to assume that anything you buy will need some modification. You should find that if you play around to find the best starting point in terms of positioning you won't have to do as much work to get it right (sometimes you have to ignore the bits that won't be easily seen).
I agree that it looks like the front spoiler could probably be pulled in a bit tighter at the corners, it may require some tweaking/grinding/cutting to do this.
#6 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 25 August 2014 - 09:08 AM
That front spoiler has to be one of the worst quality things I've seen in a while. Terible
#7 Statler
  • 6,310 posts
Posted 25 August 2014 - 04:12 PM
Tape the front flares on & then try fit the spoiler. It will give you a better idea about what is wrong & where.
#8 UCSLE
UCSLE
  • 705 posts
  • Name:troy
  • Car:Goggomobil
Posted 26 August 2014 - 12:04 AM
where does the bolt sit inside of the brake duct of the spoiler ? . Going by the photo, if it is that far out , the bolts / bolt might not be in the brake duct anymore . It could be a way of telling what side is wrong .
Edited by UCSLE, 26 August 2014 - 12:05 AM.
#9 myss427
myss427
  • 1,636 posts
Posted 26 August 2014 - 09:04 AM
As Red said its a poorly made spoiler, its too short where it should overlap and the shape there at the top where mounting screws attach is terrible. Flairs can be cut and reshaped to work ok, but would start with a better made front spoiler. Too much work to make it fit, and being new, I would through it back at them.
#10 Ruts
Ruts
    How Fast!?
  • 1,118 posts
  • Car:Blown A9X replica, Black SS hatchback, LH SLR5000
Posted 26 August 2014 - 01:11 PM
looks like you'll have to cut and fill it in places.
#11 _TRRANA_
_TRRANA_
Posted 27 August 2014 - 01:08 AM
And have a look at the rear spoiler mounting bolt location.....
I cant drill a hole either left or right into the hatch lid because the bolt would be in a dicky spot on the edge of the bottom channel...
Attached File  20140826_123010.jpeg   90.46K   9 downloadsAttached File  20140826_123005(0).jpeg   96.21K   9 downloadsAttached File  20140826_122756.jpeg   107.44K   8 downloads
ive emailed all the photos to spoilertek to see what sort of a response I will get and then I will ring them for a refund...
I dont want to be cutting, grinding or stretching anything as I dont want to crack the paint etc once painted. I shouldnt have to do that much. Its wasting my time. Plus I dont want it to look shit.
Ive heard about some Wilsons mob for a quality bodykit could anyone shed some light??
#12 REDA9X
REDA9X
    Removed
  • Inactive
  • Pip
  • 0 posts
Posted 27 August 2014 - 09:25 AM
go flareless
#13 Tyre biter
Tyre biter
  • 982 posts
Posted 04 September 2014 - 06:39 PM
How did you go with SpoilerTek Dorzy?
#14 _Tony.p2_
_Tony.p2_
Posted 18 December 2014 - 09:42 PM
Hi Dorzy
I have exactly the same problem with a Spoilertek front spoiler.I bought my spoiler about 8 months ago and only just tried to fit it today only to find that the spoiler dosn't overlap in the middle.Also the spoiler is very thin and which prevents to much manipulation for fear of cracking it. I was going to purchase some flares from Spoilertek but i will source them elsewhere.
Tony
#15 mika03au
mika03au
  • 812 posts
  • Name:Michael
  • Car:LX hatch
Posted 26 December 2014 - 09:12 PM
Really need to send the spoiler back and get your money back. Don't think that will ever fit properly.
Try another brand. With those pics as evidence there should be no issue with a refund.
I think you will find any brand kits will need some massaging to fit.
My rare spares kit cost me close to a full week of manhours to fit up and then there is a few issues not quite right.
(30 hours @ panel shop rates...ouch)
