yea thanks.. its at a mates place about an hour from me so only do stuff on weekend.. beers and cars love it
my fb
#51
Posted 04 April 2016 - 03:16 PM
#52
Posted 02 May 2016 - 04:01 PM
all going now and goes quite well to about 4000 then starts pinging so cant go to hard. engine man went on holidays so will get him to check out plus have booked in for dyno tune next week. have had a play with timing and backed it of a bit but still doing it any ideas to check.??. every thing new dizzy was graphed by hume so would think be ok?? they said set timing at 18 degrees.. see what happens but cant what to stretch it legs
#53 _Bomber Watson_
Posted 02 May 2016 - 04:24 PM
18 Initial?
Whats your total?
Or is that 18 advance?
#54 _Lightyear_
Posted 02 May 2016 - 06:17 PM
#55
Posted 03 May 2016 - 12:07 PM
bomber. the bit of paper you get with the dizzy it said set at 18 and thats what we did. from there i backed it of little bit at a time till it was pinging more so went back a bit left it there. will get engine man to put timing light on this weekend. carb is straight out of box to.. just thought that timing is usually the cause of pinning its only got 10.5 comp so would not think that would be the problem..
thanks David keep at him
#56
Posted 03 May 2016 - 04:46 PM
plugs are ngk R bpr6efs and 13 under that.. just pulled no 1 out and looks clean border line lean but was after a drive on open road
#57
Posted 03 May 2016 - 04:54 PM
just pulled out to more plugs they are different bp6efs
witch plugs should i run you think
Edited by basicgreen, 03 May 2016 - 04:57 PM.
#58 _duggan208_
Posted 03 May 2016 - 11:38 PM
I think if you have high compression (10.5) you use a colder plug. Very nice well balanced FB.
regards
#59
Posted 04 May 2016 - 07:48 AM
Probably a mix up by spare parts store.
#60
Posted 04 May 2016 - 12:41 PM
thanks Jon.. have just bought same plug so all same now thanks
#61
Posted 21 May 2016 - 02:09 PM
note to self.. no drag racing with some one in the back tail shaft trying to cut hole in floor
#62
Posted 13 December 2019 - 02:55 PM
well cant leave things alone.. have bought a 112 magnuson supercharger carby top mount and getting a kit made now..should have the charger and kit back January.. engine is pulled down taking some comp out of it.. hope to get going again march some time .. will hope to get some pics up then..cheers
#63
Posted 14 December 2019 - 01:17 AM
#64
Posted 14 December 2019 - 04:02 AM
Clay
Sent from my SM-A705YN using Tapatalk
