Im just setting up my dissy for the first time and I am trying to find the compression stroke.
I put a balloon on a hose which is screwed into the No1 cylinder. But it seems that every time the piston comes up towards TDC the balloon inflates.
I thought that on every second stroke the balloon should not inflate, because the exhaust valve should be open.
Does this mean I have set something up wrong, I know I set the cam gear and crank gear up so the dots aligned.
Out to the experts….
