LJ Trailing arm diff mounts
No replies to this topic
#1 _THUG LJ_
_THUG LJ_
Posted 07 September 2014 - 01:13 PM
Hi guys,
I am currently searching for information as to the best position to mount my trailing arms to my diff. Both upper and lower.
my plan is to try and make it as good as possible without changing the mounts on the body/chassis, as per the APSA X275 rules.
so if I wanted the front of the lower trailing arm to be higher id just lower the back of it instead.
the main reason i ask is that i am moving to heim joints so i might as well make the mounts to suit rather than use aluminium bushes on the old mounts.
any info on what angles (as viewed from the side) you guys can lend would be greatly appreciated.
  • Attached File  1.JPG   140.39K   5 downloads
  • Attached File  photo.JPG   127.52K   4 downloads
