chrome window trim
19 replies to this topic
#1 _Muzzy_
_Muzzy_
Posted 13 September 2014 - 06:03 PM
Hi , Im going to fit Chrome trim around the windows on my LH ( from a UC) along with a LH mirror and some black out
I have 2 questions
1 Are the plastic clips that hold the trim on the same as the sill ones
2 Does anyone have a picture of the location of the clips
#2 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 13 September 2014 - 06:57 PM
I think I remember reading about location of the clips on the doors on a old thread but I could be wrong
#3 a9x868
a9x868
    maurice mead of hatchbacks
  • 1,418 posts
  • Name:facebook dave
Posted 13 September 2014 - 08:41 PM
cmon hanra you know you want to!
#4 hanra
  • 10,975 posts
Posted 13 September 2014 - 08:44 PM
IHahahaha! I can help if you want to fit the LH trims, but the LX trims are another kettle of fish.
#5 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 14 September 2014 - 05:14 AM
So Brad explain ....How
#6 hanra
  • 10,975 posts
Posted 14 September 2014 - 07:58 AM
The LH trim is different to LX/UC so I'm afraid I can't help.
#7 _Muzzy_
_Muzzy_
Posted 14 September 2014 - 07:59 AM
In what way, same doors?
#8 hanra
  • 10,975 posts
Posted 14 September 2014 - 08:41 AM
LH trims fit to the inside of the window frame. LX/UC fit on the outer part of the window/door frame. Totally different setup.
#9 hanra
  • 10,975 posts
Posted 14 September 2014 - 08:45 AM
00000000-0000-0000-0000-000000007289_zps
00000000-0000-0000-0000-000000007283_zps
Edited by hanra, 14 September 2014 - 08:45 AM.
#10 a9x868
a9x868
  • 1,418 posts
Posted 14 September 2014 - 10:39 AM
brad
muzzy i believe has an LH
but may have replaced the doors
still wants LH pics though
and thanks for your timely response
i knew you had pics of the trim fittings on your thread
and you would be helpful as always!
#11 _Muzzy_
_Muzzy_
Posted 14 September 2014 - 11:03 AM
I have a LH, however it's a std S and family plain looking, so I'm fitting LX, UC trim to windows and painting black as well as black under the sills
I'm not worry about concourse.
I have found marking on the trim, this will give me location and the shape pod the clips is the same as the sills ones, so off to eBay and buy heaps as each side takes 21
#12 hanra
  • 10,975 posts
Posted 14 September 2014 - 12:38 PM
The LH trim used these clips. Not sure if the LX trim is the same????
http://www.kingswood...d-lc-lj/BMC1015
#13 Kirk
Kirk
  • 842 posts
  • Name:Kirk
  • Car:LX SS 253
Posted 14 September 2014 - 01:45 PM
Muzzy
If you're interested i have a set of door moulds and clips i took of my car .I wont be using them but i dont have the pop rivets
#14 _Muzzy_
_Muzzy_
Posted 14 September 2014 - 01:50 PM
Muzzy
Thanks, I already have the moulds I got them of a UC and they size up good, just a slight mod where the LH mirror sits, but the piece I cut will give me the 2 little bits needed for the B pillar
I have found clips on flee bay, I will need 42 for the windows and I need some for the sills
#15 _Muzzy_
_Muzzy_
Posted 25 September 2014 - 05:23 PM
Well here is the finished job, I got all the clips from rare spare in packs of 20 the job used 44 clips
The trim is from a UC, I cut and remoulded the trim to fit a left mirror so I have a piece to fit the B pillar, just not sure how this would attach as the total width is less than a plastic clip.
Thanks for the replies and advise
#16 christolx
christolx
  • 184 posts
  • Name:Chris
  • Car:1976 LX SL Coupe
Posted 25 October 2019 - 09:41 PM
Hey, I know this is an old thread I'm just trying to get my head around this before I start drilling holes. I got the screw type instead of the rivet type. If I used the screw type at the tops of the doors I would then see the tip of the screw sticking through on the inner of the door???
#17 Statler
  • 6,317 posts
Posted 26 October 2019 - 09:56 AM
The 'clips' that go at the door openings are different to the rest.
They locate in a hole & screwed on from the inside of the door .
RS sell them.
LH doors don't have the hole for these.
The rest of the clips do NOT have to be in the factory position . Usually the trim piece is bent in places so moving the new clip either side of the factory position will hold the trim inplace better . .
Edit: NONE of the trims are chrome. LH are stainless , LH/UC are annodised aluminium.
#18 christolx
christolx
  • 184 posts
  • Name:Chris
Posted 26 October 2019 - 01:56 PM
ah I see...I think I'm going to use 3M tape and not drill any holes in her. Yeh I'm going to get the trim repaired and re-finished...the aluminium seems tricky. Thanks for the reply Col.
#19 Ricky Bobby
Ricky Bobby
  • 211 posts
  • Name:Harvey
  • Car:LJ 2 door, UC hatch
Posted 03 July 2020 - 08:04 AM
Hi, I have a question. Does anyone sell the short trim piece that is missing in pic 2 of Muzzy car. How did you cover that area?
#20 Toranamat69
Toranamat69
    Forum R&D Officer
  • 2,117 posts
Posted 03 July 2020 - 08:39 AM
https://www.ebay.com...CLK&clp=2334524
