Towing with Fwd
87 replies to this topic
#76 yel327
  • 13,661 posts
Posted 21 September 2014 - 08:27 PM
Disagree mate, I've got the new 5spd auto D4D, worlds apart to the 4 spd. It does seem to predict throttle behaviour a bit which is annoying... DJ has been in mine at highway speed... ?
IMO, the V6 has terrible commodore like throttle response... Slightest touch and your spinning wheels ... That is terrible.
I drive a V6 auto every day. I test drove a new D4D A750F and took it back after 15 minutes, and said no way. I hated it that much. It has so much throttle lag. They are that bad the aftermarket has a "fix" for it with a new pedal to overcome the issue. It just felt so wierd as the D4D manual is quite good to drive and accelerates quite well for what it is, yet the auto is just wrong. V6 auto drives like a normal car, my only criticism is it runs out of puff up high due to the exhaust hence why i've got a new one to put on.
#77 kiwi-lilj
kiwi-lilj
  • 1,428 posts
  • Name:Blair
  • Car:LIL J
Posted 21 September 2014 - 08:34 PM
Maybe it's time we started a thread for hiluxes so people can dribble on all day about boring every day utes. :-)
#78 RallyRed
  • 8,158 posts
Posted 21 September 2014 - 08:38 PM
..the boys are just fillin' in time until Lakeside drops in with his outcome Re: the FWD Kluger, or not.
#79 _Skapinad_
_Skapinad_
Posted 22 September 2014 - 05:43 AM
ok Yel, the V6 Auto Hilux ute is the ducks nuts...
#80 yel327
  • 13,661 posts
Posted 22 September 2014 - 06:55 AM
Agree Blair. And Skap, no it isn't. But it is the best available driveline in its class. The A750F is 10x better behind the D4D than the old 4spd clunker though, and with exhaust, chip and pedal mod they are probably and OK thing.
If only one of the manufacturers would pull their heads out of their #%$@s and put a 6.0-ishL V8 in this class of vehicle for sale here!
#81 _Skapinad_
_Skapinad_
Posted 22 September 2014 - 07:08 AM
frOcken oath... they would not be able to keep up with the demand !!
#82 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 24 September 2014 - 07:10 PM
Well she ended up buying a Klugger AWD. So I guess we will find out if it's up to it sooner or later. The float reads 900kg on the rego label, her black horse is 500kg and the rest are ponies.
#83 _cool72_
_cool72_
Posted 24 September 2014 - 08:09 PM
Very best of luck, just don't stop on hills in the rain :clappin:  :clappin:
#84 Potta
Posted 25 September 2014 - 12:10 AM
At least its a Toyota and AWD has to be better than FWD.
Good luck.
#85 RallyRed
  • 8,158 posts
Posted 25 September 2014 - 01:55 AM
yeah good one Lakeside....better the AWD than FWD if it is to be a Kluger.
#86 yel327
  • 13,661 posts
Posted 25 September 2014 - 06:57 AM
If she has to pull the float across a slippery surface like grass they should have a transmission lock button that turns it into a proper (albeit high range) 4x4. Tell her not to use it on tar or concrete though, just to get off the slippery stuff. These things are FWD by nature, and with a trailer lifting the front a bit it may upset the AWD system on initial takeoff, before the rear wheels start to work. Might also be worth investing in some load levellers for it to get it to sit flatter so more weight goes to the front wheels (that do most of the work on these).
#87 Rockoz
Rockoz
  • 4,036 posts
  • Name:Rob
Posted 25 September 2014 - 04:04 PM
Seems no one else picked up on it.
Ive been wondering what sort of car Hamster was towing with the Camry
#88 kiwi-lilj
kiwi-lilj
  • 1,428 posts
  • Name:Blair
  • Car:LIL J
Posted 25 September 2014 - 04:17 PM
Probably one of these. I am a Camry owner, it's about all I would tow.
Attached File  image.jpg   13.88K   2 downloads
