Fitting UPC 287mm Torana stub kit to LX hatch
Posted 04 October 2014 - 09:49 PM
Looking through my pile of H series calipers it seems unlikely any of the others offer any better clearance.
Considering my options of cutting a relieving "eyebrow" for clearance, refitting the originals or using an aftermarket option I chose to explore the latter.
Hoppers were sort of helpful over the phone. Couldn't tell me which wheels would clear their kit. Sent me a template via email and left me to work out myself whether they would clear. They wanted $1495 plus delivery for their kit.
UPC were happy to say the 287 kit would clear nearly any 15 inch wheel I was likely to use bar the good Ol dodgy Simmons. They list their kit on eBay at two prices, $895 and $995. They ask do a weekly $1 start auction and watching these for a while I saw them go as cheap as $612. After a few weeks of patience I got mine for $700. Picked it up from their factory which I travel near most weeks.
Opening it up the hubs and adaptor dogbones look well made.
Got it fitted up without any drama of significance. Had to minor clearance one end of the stub/dogbone on one side. Looking at the stubs there was a bit of variance in the thickness in this location. I can't read the cast numbers as they are too faint so not sure wether it's an original stub or not. Took 10 min of file work.
Took it for a drive and all works fine. Tried the usual parking manoeuvres etc and all seems to clear fine.
So no problems here.
I have taken a step by step set of pics if anyone is interested.
Posted 05 October 2014 - 03:45 AM
When you say you was running HQ style brakes and stubs what side of the stub did you have the calipers front or rear of stub ???
I found in the past that Hoppers said there smaller kit 287mm would fit the Simmons wheels
and as for UPC for get it .....the guy wouldn't even return my calls and I rang 3 times over a week and the lady said she would get him to return my call as he was busy ....mmm must be still busy
and yes we are all interested .....( pics )....in how it fits and works
Thanks Kevin
Posted 05 October 2014 - 07:57 AM
I will be fitting them in the next few weeks and I'll be adding some pics here to.
Posted 05 October 2014 - 10:08 AM
Cheers, Nig.
Posted 05 October 2014 - 10:18 AM
I have said many times here that I have bought them and fitted them to one of my torana's. They are defintely good bang for buck. I now have Hoppers on my new car and I honestly can't pick the difference in perfomance between the two brands. With a little filing and mechanical experience they are easy to fit up. I would certainly buy them again.
Posted 05 October 2014 - 04:51 PM
The current set up was HX tonner stubs with the original Torana LX caliper bodies with the longer HX slides. As above it touched on extremes of lock. Not a disaster and potentially fixed for nothing with a stop or relief notching but I viewed it as an opportunity to do this.
You will need:
A basic socket set.
Some larger spanners won't hurt.
A flat blade screwdriver.
Pliers.
New split pins.
High temp bearing grease.
Two jacks.
Two hammers or similar.
Gloves and rags.
File.
A modicum of patience.
My fitment is a little longer than if you have standard brakes as I had to change back to Torana stubs.
The first thing I did was dummy assemble one side onto the Torana stub to see if it would clear the wheels.
This is what the inside of an original 15X7 Hotwire looks like. Assembly seems to clear fine.
Edited by rexy, 05 October 2014 - 04:52 PM.
Posted 05 October 2014 - 05:08 PM
With the wheel off its time to put the second Jack under the lower control arm at the shock mount.
Unbolt the caliper and hang it up out of the way. (Spanner and hex key required for the alloy LX caliper)
Remove dust cap from rotor (flat blade screwdriver)
Undo split pin and remove castellated nut.
Remove disc. Don't lose the dust cap , castellated nut and bearing retaining washer, you will need them for reinstall.
Things should now look like this.
Do not undo the brake lines yet. You will make a big mess of brake fluid as the system drains itself. More on that later.
Edited by rexy, 05 October 2014 - 05:11 PM.
Posted 05 October 2014 - 05:23 PM
Undo the two bolts holding the steering arm on. Move it gently to safety.
Remove the split pins from the castellated nuts on the upper and lower ball joints. You may have nyloc nuts in which case you may like to source new ones for reassembly.
Unwind the nuts a few turns. Not too far though.
Should look like this now.
There a quite a few theories on how to separate ball joints. I am a fan of tapping both sides of the stub adjacent to the ball joint insertion. This leaves the ball joint intact for re-use. Patience grasshopper.
Like this but with a hammer in each hand obviously.
Keep a close eye on the castellated nuts as they will spin while you are tapping and you don't want one to come off. You can reinstall a split pin for safety while you do this if you like. The Jack under the lower control arm should be let down so it is no longer supporting it. Leave it about a cm below.
Edited by rexy, 05 October 2014 - 05:28 PM.
Posted 05 October 2014 - 05:54 PM
Remove the castellated nuts. Obviously keep them for reinstall.
You can now lift the upper control arm off the stub axle like this.
Now lift the stub off the lower ball joint.
As you can see the lower ball joint rubber is perished. Pair of replacement rubbers was $7 from repco.
Posted 05 October 2014 - 06:15 PM
Re grease ball joints.
Install new ball joint rubber.
From your brake kit install the new inner dust seal onto the stub. Use grease sparingingly to fit.
Install inner bearing, it's the larger of the two. Inner and outer bearings appear to be standard holden sizes.
Grease liberally and work the grease into the bearing by finger.
Fit stub by placing on lower ball joint then lowering upper arm to install upper balljoint.
Install castellated nuts, torque to spec and install new split pins.
Reinstall steering arm.
Grease the smaller outer bearing.
Install your new hub. Install the outer bearing.
Add the old retaining washer. You will note it has a locating tab that fits in the slot in the threaded part of the stub.
Reinstall the castellated nut. Tighten slowly and gently with your large adjustable spanner to seat the bearings. Back it off and now tighten with your fingers. Take it back just enough after it seats to get the split pin in the first available hole.
Edited by rexy, 05 October 2014 - 06:17 PM.
Posted 05 October 2014 - 06:27 PM
I had to take a little material from the stub and also took a little from the dogbone as per the pics. This appears to be due to variation in the stubs. The other side was fine.
It's the area in the pics where the paint is missing.
Little bit off the dogbone.
After this I fitted the dogbone and caliper to the stub to check lock to lock clearance.
Looks like plenty of space.
Edited by rexy, 05 October 2014 - 06:28 PM.
Posted 05 October 2014 - 07:10 PM
Posted 05 October 2014 - 07:11 PM
Undo the line from the old caliper where it joins the hard line in the upper inner wheel arch.
Very quickly attach the new line as the brake fluid attempts to escape.
I found the system gravity bled itself quite nicely.
Top up brake fluid.
Reinstall wheel. You will need new wheel nuts unless your old setup had half inch studs (std holden is 7/16). These cost me $20.
Check you have a brake pedal.
Trundle around the block to test.
Recheck on return for brake fluid level, leaks and check bolt tightness.
Posted 05 October 2014 - 07:23 PM
The front end height had increased as per the before and after pics. It settled about a cm from the after pic with a drive around the block.
Before
After
It's hard to believe there is $800 worth of extra value in the Hoppers kit.
Edited by rexy, 05 October 2014 - 07:25 PM.
Posted 05 October 2014 - 08:46 PM
Looks like they fit like a glove. I trial fitted mine and went together no problem as well. Did you swap stubs left to right?
Stubs are as per factory fitment. No side to side swap.
Posted 05 October 2014 - 09:00 PM
Hey RexyWhen you say you was running HQ style brakes and stubs what side of the stub did you have the calipers front or rear of stub ???I found in the past that Hoppers said there smaller kit 287mm would fit the Simmons wheelsand as for UPC for get it .....the guy wouldn't even return my calls and I rang 3 times over a week and the lady said she would get him to return my call as he was busy ....mmm must be still busyand yes we are all interested .....( pics )....in how it fits and worksThanks Kevin
The HQ setup was calipers on the front.
UPC were off eBay for a littl while. Perhaps there is a simple explanation?
Posted 06 October 2014 - 04:42 AM
what are we missing ???
Posted 06 October 2014 - 06:45 AM
#21
_LS2 Hatch_
Posted 06 October 2014 - 06:52 AM
The guy from Hoppers had a look at my car and thought that it was his set up. When I said it was UPC, he told he knew thy would work fine as they were a direct copy of his.
It's the larger 330mm set up that everyone complains about.
#22
_LHSL308_
Posted 06 October 2014 - 01:01 PM
Good tutorial there Rexy well done. Maybe this could be put up as a sticky.
How much better do you find this brake kit over your old HX calipers? As you know I bought my HX calipers off you and fitted them about 12 months ago, they seem to be a little better than the old standard calipers I had.
As you have HQ stubs I wonder if having the original Torana stubs would make any difference to the fitment?
#23
Posted 06 October 2014 - 03:44 PM
The HX tonner stubs with the same caliper were slightly better again presumably due to leverage effect with the larger diameter disc.
This UPC setup seems at least as good and likely better. It's early days and I am still letting the pads bed in until I give it a good workout.
If I still had the original LX stubs fitted I could have left out the middle bit of the changeover where I swapped the HX stubs out and put the original LX ones back in. Makes it a much shorter job. At least it gave me a chance to replace the perished ball joint rubbers.
#24
Posted 06 October 2014 - 05:30 PM
I am very interested to know ....what is the exact problem with the 330mm kits and I seen on E-bay UPC also have a bigger 383mm I think .....has anyone used these ????I have the big brake set up on my hatch too. Only difference is I went for commodore stud pattern. They fit straight up with very little to no filling needed.
#25
Posted 06 October 2014 - 05:36 PM
