Fitting UPC 287mm Torana stub kit to LX hatch
60 replies to this topic
#26 rexy
rexy
  • 3,738 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 25 November 2014 - 01:14 PM
Having spent some time in the car now it's clear these perform better than the old setup. I am also very pleasantly surprised by how much better the handling is with the Torana stubs back in the car.
#27 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 26 November 2014 - 07:22 AM
I am interested to know if the bigger 330mm will work if you had the rims to suit
#28 rexy
rexy
  • 3,738 posts
  • Name:Rexy
Posted 26 November 2014 - 12:11 PM
You buy the stuff for me (330 kit and new wheels/tyres) and I will find out how well it fits on my hatch...
Let me know!
#29 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 26 November 2014 - 02:43 PM
Yeah that's not what I had in mind .....more like has anyone on here made the 330mm kit work ???
#30 rexy
rexy
  • 3,738 posts
  • Name:Rexy
Posted 26 November 2014 - 07:23 PM
Are you sure? I could do with a sugar daddy.
#31 dattoman
  • 16,487 posts
Posted 26 November 2014 - 08:33 PM
Haven't seen anyone successfully make the 330 kit work no
But there may be exceptions
#32 UC308Hatch
UC308Hatch
  • 119 posts
  • Name:Ron McNab
  • Car:UC Torana Hatch
Posted 24 December 2014 - 07:58 AM
#33 _LS1 Hatch_
_LS1 Hatch_
Posted 24 December 2014 - 12:25 PM
I sure couldn't get the 330 kit to fit without needing to carve out half the control arm and subframe nearly...
Gave up and made my own 360mm kit instead. Used the hubs and the upc rotors and calipers are new and sitting on the shelf for the past bunch of years ever since.
#34 UC308Hatch
UC308Hatch
  • 119 posts
  • Name:Ron McNab
Posted 24 December 2014 - 06:33 PM
Hi all, I brought the UPC 330mm kit off eBay nearly 6 years ago & when I asked about if it was a straight bolt on before purchase the reply was yes! (before I found this site, & all the negative feedback).
My car has been a long build 6.5 years so far - nearly done. I tried fitting the kit up to the car before its strip down, it became very obvious this was not the case. Front or rear mount!
Ok, so I made a frame ( attached the k- frame to it using the chassis rail bolts) to mount a spare unsprung & unshocked front end on (UC), so that I could easily test for any binding or loss of full movement through the full range articulation.
As others have said steering lock is almost nonexistent at full droop let alone full compression, mainly due to the caliper hitting the top arm. So I rang Tony ( mr spares - romac upc ) & had a lengthy conversation about the issues I was experiencing.
His response was all you have to do is remove the top arm balljoint & mount it on the bottom side of the top arm with a 25mm spacer between the 2.
I ran this past my mod plate engineer. Although he thought it would pass using the correct grade bolts, I didn't like the idea. So I sourced the correct taper extended length ball joints from a nascar supplier & fitted them in the original position.
With this extended length ball joint installed & a 3mm space tracked to the lower arm steering lock stop, I am able to get full movement up & down left & right without modifying the top arm at all. I did have to grind a radius on the bottom of the caliper main bracket just above the tie rod end, to allow clearance for full movement ( was a right angle, now a 5mm radius).
Ok so I checked how this might effect camber, compared to the std UC Torana setup. I set up the std setup with 1deg negative camber at normal ride height, this decreases with compression of suspension (going positive at full compression). The longer top balljoint setup at std ride height set the same adds more negative camber with compression.
I'm no suspension expert, but I'm going to give it a go. It's all installed & engineered, just waiting on me to complete the hiding of my wiring & a couple of other things, so I can get it registered. Then real world feedback......
#35 dattoman
  • 16,487 posts
Posted 24 December 2014 - 06:42 PM
And pics and part # of that upper BJ
#36 UC308Hatch
UC308Hatch
  • 119 posts
  • Name:Ron McNab
Posted 24 December 2014 - 08:52 PM
No worries Dattoman, give me a day or four, to dig the details out & try to remember how to post pictures.... After I get the festive stuff out of the way..... Happy Christmas!!
#37 _LS1 Hatch_
_LS1 Hatch_
Posted 25 December 2014 - 02:41 AM
Speedway has extended length ball joints..pretty easy find.
#38 _LS1 Hatch_
_LS1 Hatch_
Posted 25 December 2014 - 02:44 AM
For example..
http://www.speedwaym...ngth,35802.html
(don't quote me on that one, it's early still this morning, lol) But have a look around there, they have a ton of different ball joint styles there!)
#39 UC308Hatch
UC308Hatch
  • 119 posts
  • Name:Ron McNab
Posted 26 December 2014 - 02:08 PM
Ok I think I have this figured out, sorry if it doesn't work.
This is where I brought them from http://www.howeracin...fits-k5108.aspx
Yes they are to suit 67-69 Camaro, but they are the same mount & taper as Torana uppers.
I brought the +0.9" longer units
Attached File  ImageUploadedByTapatalk1419566541.267270.jpg   241.88K   34 downloadsAttached File  ImageUploadedByTapatalk1419566564.436745.jpg   256.97K   24 downloads
They bolt into the same holes as the originally riveted top ball joints, with a slight adjustment here & there ( minor drilling & filing)
The only other change I had to make was a droop stopper, so that at full droop the top arm only travelled down as much as the original set up.
Attached File  ImageUploadedByTapatalk1419566774.166659.jpg   168.79K   20 downloadsAttached File  ImageUploadedByTapatalk1419566787.033880.jpg   164.18K   21 downloads
Shown next is the steering stop mod, So that the rear of the caliper won't hit k-frame as the pads wear.
Edited by UC308Hatch, 26 December 2014 - 02:22 PM.
#40 UC308Hatch
UC308Hatch
  • 119 posts
  • Name:Ron McNab
Posted 26 December 2014 - 02:13 PM
Attached File  ImageUploadedByTapatalk1419567086.150394.jpg   375.35K   16 downloads
obviously some of these shots were taken before I sandblasted the parts & fitted new components, but I still have the same suspension travel as factory, just with a couple of degrees less full lock. All I did in the above shot was added a 3mm shim to the existing UC lower Arm steering stop.
Edited by UC308Hatch, 26 December 2014 - 02:26 PM.
#41 UC308Hatch
UC308Hatch
  • 119 posts
  • Name:Ron McNab
Posted 26 December 2014 - 02:31 PM
As LS1 Hatch said there would be others available but these are the ones I stumbled upon. I used the steel hat units "22303S Steel Cap" in + .9" length.
Edited by UC308Hatch, 26 December 2014 - 02:39 PM.
#42 _napes_au_
_napes_au_
Posted 02 April 2016 - 05:41 PM
I'm sure it would of been discussed before, just can't seem to find it.... Has anyone got this brake set up with V5 Simmons fitted on an LX Hatch???? Was there any clearance issues????
#43 Kiwi_SLR
Kiwi_SLR
  • 9 posts
  • Car:LH SLR
Posted 01 June 2016 - 03:40 PM
From memory you will have issues with the Simmons wheels.  they do make a machined caliper that will work with 14" wheels now.
#44 Kiwi_SLR
Kiwi_SLR
  • 9 posts
  • Car:LH SLR
Posted 01 June 2016 - 03:48 PM
Hi Rexy,
Great post.  Did you have any issues with the brake hose length?
I was just assembling my kit and it looks too long.  Measures 450mm between connectors
Attached File  torana-37.jpg   79.77K   1 downloads
Now it's time to install the new provided brake line. Make sure you use the provided copper washers. One goes between the head of the bolt and the line, The other between the line and the caliper body.
Undo the line from the old caliper where it joins the hard line in the upper inner wheel arch.
Very quickly attach the new line as the brake fluid attempts to escape.
I found the system gravity bled itself quite nicely.
Top up brake fluid.
Reinstall wheel. You will need new wheel nuts unless your old setup had half inch studs (std holden is 7/16). These cost me $20.
Check you have a brake pedal.
Trundle around the block to test.
Recheck on return for brake fluid level, leaks and check bolt tightness.
#45 rexy
rexy
  • 3,738 posts
  • Name:Rexy
Posted 04 June 2016 - 02:58 PM
They seemed OK. I don't remember what length they were though.
#46 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 13 June 2016 - 04:50 PM
I know it's an old thread but I recently fitted the 287mm kit I bought via eBay years ago.
As above I had to remove a little metal from the stub axle but other than that it was an easy job. Unfortunately the Walkinshaw wheels I was planning on using won't fit but that is the wheel. I can fit a standard 15" Commodore wheel on. The components in the kit look good, happy with the purchase just not my decisions leading up to it. Regarding the length of the brake hosw, it looks long but I did not see it causing any issues, was going to attach it to the original brake hose bracket on the inner guard to keep it out of harms way
I have always liked the Walkinshaw wheel and wanted to use them which is why I went Commodore PCD but now I am not so sure. Might be looking for different wheels or maybe I won't be using the UPC brakes.
Wish I had found the following thread before I tried the Walkinshaw wheels, http://www.gmh-toran...ls-on-my-torry/
Attached File  P1110052.JPG   158.01K   7 downloads
Attached File  P1110053.JPG   153.62K   9 downloads
Attached File  P1110057.JPG   158.9K   9 downloads
#47 tsn007
tsn007
  • 1,019 posts
  • Name:Tony
  • Car:LX hatch, LX sedan
Posted 13 June 2016 - 05:04 PM
i remember reading that the Vl walky wheels do fit over drum brakes as well
#48 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 13 June 2016 - 08:46 PM
Seems they don't fit on many discs or drums
Since it is about the only disc they fit on I will try using the 290mm VL-VN disc to see if I can make it work with a different caliper
#49 rexy
rexy
  • 3,738 posts
  • Name:Rexy
Posted 13 June 2016 - 09:03 PM
Aren't the VL walkinshaw wheels 16 inch? Where do they foul?
Would love to see a picture of the inside of one of them.
#50 neglectedtorana
neglectedtorana
  • 1,040 posts
  • Name:Tom
Posted 13 June 2016 - 09:32 PM
Mine fitted on the car using one of the adapter hubs and a VX disc but no caliper
The gap below the ruler and the mounting face is 12mm so the disc mounting face needs to be smaller in diameter than the AU disc used with the UPC/Hoppers kit and then even if the wheel fits onto the disc mounting face it needs a caliper that does not protrude far outward from the disc face.
Hope the pics help
Attached File  P1110063.JPG   160.22K   10 downloads
Attached File  P1110062.JPG   149.25K   8 downloads
Attached File  P1110061.JPG   156.51K   8 downloads
Attached File  P1110060.JPG   160.66K   8 downloads
