ben23's '77 LX 2850 - my first Torana
LXTorana 2850 first build rust
136 replies to this topic
#76 _Bomber Watson_
Posted 30 November 2015 - 01:10 PM
Yeah but colom shift is awesome.
#77 yel327
  • 13,633 posts
Posted 30 November 2015 - 03:17 PM
Really want a manual, but really want a bench. Considering dropping 253 or Tri pattern 308 in with a V8 3 speed behind it? anyone got a 3 speed column and a V8 3 speed box? A clutch pedal and cable/linkage setup would be great too :)
V8 3spd box is the same as a 6cyl for all HG-WB other than for input shaft and cover, just like an M20. Uses all the same clutch mech, clutch pedal and bellhousing as a 4spd. HT V8 3spd is a close ratio box, so avoid those.
#78 ben23
ben23
  • 237 posts
  • Name:Ben
  • Car:'77 LX 2850 sedan
Posted 30 November 2015 - 09:23 PM
Yeah i dont just want a 3 speed because its a non floor cutting way of having a manual but that is an important factor, i just like the novelty factor of driving a 3 on the tree and being a weekender its not a big deal to not have overdrive although ill prob eat my words later on haha.
#79 ben23
ben23
  • 237 posts
  • Name:Ben
Posted 10 December 2015 - 08:46 PM
Big brake kit arrived from UPC, 287mm plain disc rather than drilled or slotted, prefer the normal sort of look. These babies should stop a Torana real well :) gonna go for a commodore booster and master cyl. R31 diff is already disc braked so happy days!
#80 ben23
ben23
  • 237 posts
  • Name:Ben
Posted 11 February 2016 - 02:29 PM
Well not a great deal has been happening but I want the car done this year so I better get into it. Bought a set of rust free doors that need minimal panel beating to get right, thinking about getting the body blasted and then epoxy primed and then do my repairs over that. Been practicing on the TIG with some scrap trying to get my skills up, not so bad, mates a welder who TIGs staino day in and out so he is helping a great deal!
#81 ben23
ben23
  • 237 posts
  • Name:Ben
Posted 10 March 2016 - 05:27 PM
Who wants to take this frOcking shitheap
#82 _74LH_
_74LH_
Posted 10 March 2016 - 05:49 PM
What happened? Had enough of it already?
#83 Covert
Covert
  • 1,987 posts
  • Car:LH
Posted 10 March 2016 - 09:25 PM
Don't throw in the towel yet mate, keep practicing your welding skill, the more you do it the better you will get.
#84 _LS1 Taxi_
_LS1 Taxi_
Posted 10 March 2016 - 10:07 PM
LOL
#85 SmacT
SmacT
  • 977 posts
  • Name:Sam
  • Car:LX 4dr 383, TKX, BW
Posted 10 March 2016 - 10:24 PM
Christ, we have all been there. Some more than others, granted... :-)
#86 ben23
ben23
  • 237 posts
  • Name:Ben
Posted 10 March 2016 - 11:05 PM
Well we got some more done this arvo, plenum not far from being finished.
10464357_10208096960077068_6066549687317
12806257_10208096960397076_3956672869221
12801203_10208163504460636_4433420476343
Heres those doors I bought. Paid a bit for em but they are practically rust free.
943819_10207759144711895_100798876780050
UPC 287mm twin piston brake kit, 1/2" studs on HQ pattern, AUII Falcon PBR caliper.
12360221_10207478275650344_9092148875637
Got my subframe stripped ready for me to clean it all up at some stage and reassemble with all new bits
12592751_10207852884095321_3251396374591
#87 _74LH_
_74LH_
Posted 11 March 2016 - 03:36 PM
That's it mate. Keep going, don't let it get the better of you.
And whenever the time comes (whether it's months or even years) when you open your garage and see the finished product you'll thank yourself for sticking with it.
#88 ben23
ben23
  • 237 posts
  • Name:Ben
Posted 13 March 2016 - 08:30 PM
picked up a healthy donor today, 95 VR Caprice with a solid 5 litre and auto!
10329215_10208190155886905_6377566097816
#89 SmacT
SmacT
  • 977 posts
  • Name:Sam
Posted 13 March 2016 - 09:13 PM
Perfecto! Having the factory wiring and computer makes it a snack to get going in the Torrie, once you have sorted out the fuel pump and return line.
#90 ben23
ben23
  • 237 posts
  • Name:Ben
Posted 13 March 2016 - 09:36 PM
yeah theres a few mobs around that do fuel tank mods, gonna get mine enlarged another 20L or so and see if the entire pump cradle and swirl pot can be fitted
#91 SmacT
SmacT
  • 977 posts
  • Name:Sam
Posted 14 March 2016 - 07:50 PM
I had a custom drop tank made for mine, using a VT fuel pump assembly/surge pot in the tank . Works so far, but the car hasn't driven yet.
#92 ben23
ben23
  • 237 posts
  • Name:Ben
Posted 14 March 2016 - 08:56 PM
Yeah see I don't particularly want the drop tank look, if I can get another 20L out of my tank and fit the fuel pump setup I'll be happy 👌
#93 SmacT
SmacT
  • 977 posts
  • Name:Sam
Posted 14 March 2016 - 09:28 PM
Yeah, fair enough. In that case, there's this option, which just fits into a standard tank - Derrin71 did it in his awesome hatch build, how he did it here. Might work for you, with some extra room for those extra 20 liters?
You owe me an hour after I just re-read Derrin's build thread... :-)
#94 ben23
ben23
  • 237 posts
  • Name:Ben
Posted 15 March 2016 - 06:45 PM
See that was my plan to run one of those but they are pretty pricey. If I can adapt the caprice setup and throw a new pump at it that's another part I can use off the car
#95 ben23
ben23
  • 237 posts
  • Name:Ben
Posted 15 March 2016 - 10:19 PM
Well got a little more done today my good friend Dee Man the boily is helping me along with the welding so tonight we have welded up more holes that wont be needed and fitted the battery tray. KBS coated inside the chassis rail before the tray went in. Tomorrow should be getting close to getting the lower plenum finished and the upper plenum prepped and ready to go back in. After that it will be plating up the firewall and bonnet hinges. Little bit to repair in the lower rad support but other than that pretty much covers the front end repairs. Few rivet holes to weld up in the floorpan and then its rust around the rear windscreen and the beaver panel behind the bumper.
11813238_10208211893750338_2297606790152
10330385_10208211893830340_7689025446739
#96 ben23
ben23
  • 237 posts
  • Name:Ben
Posted 21 March 2016 - 07:24 PM
Stripping the parts car ft. reciprocating saw
10400966_10208245891080250_6368053719683
All the rusty bits cut out so far
11701026_10208279521400987_7433973642532
Underside of upper plenum treated with KBS Aquakleen and rustblast. Etched up real nice.
10600653_10208279523081029_4224685704598
And coated with KBS rust seal!
12063854_10208279523761046_1517744011521
Bonnet hinges plated up
12832574_10208279522761021_5882285477856
#97 ben23
ben23
  • 237 posts
  • Name:Ben
Posted 14 May 2016 - 10:11 PM
painted up the K-frame
12932632_10208517957681745_5413386956817
got the 5 litre and 4L60-E out
12439271_10208380009633130_2999519346465
Thats all for now!
#98 Covert
Covert
  • 1,987 posts
  • Car:LH
Posted 14 May 2016 - 10:44 PM
nice work Ben, gotta love that KBS, great stuff
#99 ben23
ben23
  • 237 posts
  • Name:Ben
Posted 14 May 2016 - 10:58 PM
Mate I'm stoked with it, sets hard as a rock. Everything hidden and out of site will be lathered in the shit.
#100 ben23
ben23
  • 237 posts
  • Name:Ben
Posted 28 June 2016 - 12:29 AM
Not a great deal has been happening on the body so I started playing with things that I actually know how to do, like rebuilding the wiper motor. Not that it needed it, but figured id grease her up and clean her out while it was sitting around. Oh, and if anyone has an SLR cluster they would like to sell to me for less than my weekly wage I'd love to hear from you :)
Also tagged with one or more of these keywords: LXTorana, 2850, first, build, rust
