Aeromotive stealth efi in tank fuel pump install
10 replies to this topic
#1 _valenciahatch_
_valenciahatch_
Posted 25 October 2014 - 06:56 PM
Gday guys. Haven't posted much lately on the project but it coming along pretty well. I decided to go efi with my engine setup and wanted to go for a cost effective,simple, reliable setup that didn't crowd under the car with external pumps and surge tanks etc. This is what I came up with. It's a aeromotive stealth kit which is all in tank with a surge tank area that can basically be adapted to fit any tank. I was stand off ish to start with as the lx tank is very shallow and there is not alot of area to mount it. Anyway here's a few pics for a bit of reference for anyone looking to do the same..
P.s will upload pics at home, phone is being a sod
#2 ls2lxhatch
  • 5,332 posts
Posted 26 October 2014 - 01:50 AM
Have a look at these threads.
http://www.gmh-toran...oject/?p=737938
http://www.gmh-toran...-in-tank-setup/
#3 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 26 October 2014 - 12:05 PM
I'm looking at doing the same, where did you locate it? In the forward right corner?
#4 derrin71
derrin71
  • 491 posts
  • Name:Derrin
Posted 26 October 2014 - 05:55 PM
At the front,  slightly offset to the drivers side, the deepest part of the tank.
You will need to bend the original pickup tube slightly to move it out of the way. Blank it off as well as it is no longer needed.
#5 _valenciahatch_
_valenciahatch_
Posted 30 October 2014 - 12:45 PM
sorry lads, got caught up with work, more pics available if more info needed, as you probably cant see in these pics, when i drilled the hole to fit the pump, the breather tube runs to the back of the tank (i didnt realise this before i got carried away with the hole saw, a block of wood was used to knock it across 10mm or so so i could fit the mounting plate from inside the tank. other than that it was a piece of piss, i didnt require bending my sender tube in my case though. will add some pics of my build progress to my other post. :)
#6 _valenciahatch_
_valenciahatch_
Posted 30 October 2014 - 12:50 PM
sorry, bigger pics here
#7 _valenciahatch_
_valenciahatch_
Posted 30 October 2014 - 01:21 PM
also peoples, heres the link to my build. not sure where im meant to post it so am just adding to my introduction page??
http://www.gmh-toran...howdy/?p=866884
#8 Antman
Antman
  • 26 posts
  • Name:Anton Mann
  • Car:Torana Hatchback
Posted 06 September 2022 - 10:30 PM
Awesome,
wondering how you go with the clearance between the tank and underside of the boot.
#9 Heath
  • 18,385 posts
Posted 07 September 2022 - 11:08 AM
Hi Anton, that post was 8 years ago, and the member is no longer active. Don't hold your breath for a reply from him! Haha.
#10 BENN0
BENN0
  • 80 posts
Posted 12 September 2022 - 04:52 PM
I run a in Phantom intank setup also.
I bonded some 25mm thick rubber style strips to the tank (Strips are made from a slightly compressable material like they use for a gym floor)
Works ok. It does impact the position of the fuel filler a little though.
#11 derrin71
derrin71
  • 491 posts
  • Name:Derrin
Posted 15 September 2022 - 09:06 AM
I used 2 pieces of 25mm RHS to space my tank down for clearance. Sika'd them to the top of the tank with some insertion rubber between them and the floor. You will also need to modify the straps. I cut my filler tube and used a piece of rubber pipe and a couple of clamps to add about 25mm to the length. You can't see the join.
