Aeromotive stealth efi in tank fuel pump install
_valenciahatch_
Posted 25 October 2014 - 06:56 PM
P.s will upload pics at home, phone is being a sod
Posted 26 October 2014 - 01:50 AM
Have a look at these threads.
http://www.gmh-toran...oject/?p=737938
http://www.gmh-toran...-in-tank-setup/
Posted 26 October 2014 - 12:05 PM
I'm looking at doing the same, where did you locate it? In the forward right corner?
Posted 26 October 2014 - 05:55 PM
At the front, slightly offset to the drivers side, the deepest part of the tank.
You will need to bend the original pickup tube slightly to move it out of the way. Blank it off as well as it is no longer needed.
_valenciahatch_
Posted 30 October 2014 - 12:45 PM
sorry lads, got caught up with work, more pics available if more info needed, as you probably cant see in these pics, when i drilled the hole to fit the pump, the breather tube runs to the back of the tank (i didnt realise this before i got carried away with the hole saw, a block of wood was used to knock it across 10mm or so so i could fit the mounting plate from inside the tank. other than that it was a piece of piss, i didnt require bending my sender tube in my case though. will add some pics of my build progress to my other post.
_valenciahatch_
Posted 30 October 2014 - 12:50 PM
sorry, bigger pics here
_valenciahatch_
Posted 30 October 2014 - 01:21 PM
also peoples, heres the link to my build. not sure where im meant to post it so am just adding to my introduction page??
http://www.gmh-toran...howdy/?p=866884
Posted 06 September 2022 - 10:30 PM
Awesome,
wondering how you go with the clearance between the tank and underside of the boot.
Posted 07 September 2022 - 11:08 AM
Posted 12 September 2022 - 04:52 PM
I run a in Phantom intank setup also.
I bonded some 25mm thick rubber style strips to the tank (Strips are made from a slightly compressable material like they use for a gym floor)
Works ok. It does impact the position of the fuel filler a little though.
Posted 15 September 2022 - 09:06 AM
I used 2 pieces of 25mm RHS to space my tank down for clearance. Sika'd them to the top of the tank with some insertion rubber between them and the floor. You will also need to modify the straps. I cut my filler tube and used a piece of rubber pipe and a couple of clamps to add about 25mm to the length. You can't see the join.
