Aussiespeed Krogdahl Head for Holden 6
2 replies to this topic
#1 _Sir LC_
_Sir LC_
Posted 10 November 2014 - 10:53 PM
Saw this about 1-2 weeks back and thought it may be of interest to some...some great things are being done for the old Holden 6.
More info can be found on Aussiespeed's website; http://www.aussiespe...d-new-products/
KROGDAHL HEAD MORE INFO.
November 4, 2014
When we got to actually see our first Krogdahl cylinder head in the flesh we were kinda blown away that something we here at Aussiespeed had discussed had been done before many years ago. We were not going to go the exact way that the Krogdahl was developed. We were and still are looking at an over head valve cylinder head that could be used on a mild street engine through to a competition engine.
aussiespeed-krogdahl-head-2014-300x225.j
The cylinder head has 2 spark plugs per cylinder, an engine with twin plugs is what is used in the aviation industry. Bob told us that the engine can idle as low as 600 rpm and was much smoother when run with a twin ignition system. A distributor is fitted in the valley of each of the camshafts and is timed to fire on the compression stroke. Later model Krogdahl cylinder heads went to computer controlled ignition.
krogdahl-holden-cylinder-head-300x225.jp
The port design was very much the same as later model cylinder heads the shape of the port and runner was being used back when we were still  young boys. The head is symmetrical and  either side can be used for intake or exhaust manifolds.
The raw casting could have been machined with cylinder head bolts and water passages to suit either Holden or Ford 6 cylinder. The early pre crossflow mustang and falcon engine was a candidate for the cylinder head. The internal core box to make the water passages has gone missing and unfortunately is a major part in casting the cylinder heads.
One of the proto type engines. The fuel injection manifold has twin electronic injectors and with 6 throttle bodies and 2 injectors per port the engines fuel requirements could be handled better at high rpm and when used with a quality computer the fuel curve could be adjusted to deliver optimum performance.
The camshaft drive belt as used on the Krogdahl engine incorporated its own belt tensioner. A timing cover was also cast to suit the Ford 6 engine that made up part of the cam drive.
engineTamworth-Jan-08-Mackay-mid-2008-17
Different styles of valve covers were cast for the Krogdahl engines, these ceramic coated headers were also designed and built to suit the Krogdahl head to fit Falcon and Mustang body styles. As you can see the picture was taken in 2008.
An old picture of Bob with the Ford EA to AU style SOHC engine fitted with a DOHC head fitted to a Falcon engine a few years before he retired , Bob had traveled over 250,000 KM with the engine in one of his own cars.
HOLDEN KROGDAHL HEAD
November 8, 2014
A very short video of a triple weber Holden 202 fitted with a Krogdahl cylinder head, be sure to turn up the volume they sound different.
A prepped Holden 6 cylinder engine That was fitted with a DOHC cylinder head, extensive work is carried out on the oil galleries to keep the bottom end oil flow up.
Early engines used a modified stock Holden timing cover, yes the standard cam is still fitted to the block, lets just say the cam under goes some modification.
A crank trigger is used to fire the ignition system, note the fuel pump drive in the distributor hole.
Engine and belt covers were manufactured to give the factory look, the great thing with the head design was it could be used on a mild street engine right up to an all out racing engine with a reduction in valve size and camshaft lift.
Notice the adapter on the front of the crank, some of the Krogdahl engines were run without harmonic balancers or flywheels. A crank hub with an alloy drive pulley and an automatic flexplate with the rotating assembly balanced and a reduction of the bobweights on the crank.
#2 Potta
Posted 11 November 2014 - 01:23 AM
That is frikkin cool
#3 _duggan208_
_duggan208_
Posted 29 November 2014 - 12:31 AM
I remember reading about these heads in a Street Machine Magazine. I might try and find it.
regards
