Lx Gurus Help
75 replies to this topic
#26 bullitA9X
bullitA9X
  • 4,168 posts
Posted 21 November 2014 - 12:58 PM
So mick would I be right in saying it should have the rubber grommets and not the metal clips then being a 14/10/76 build
#27 _sstorana_
_sstorana_
Posted 21 November 2014 - 02:33 PM
I will check some paperwork that I have here to see if it will shed any light but from what I have seen, it's around that time frame.
Maybe if people with stock cars that are 10/76 - 12/76 could let us know what they have.
Mick
#28 bullitA9X
bullitA9X
  • 4,168 posts
Posted 21 November 2014 - 02:47 PM
Mick
Thanks mick good point anybody out there that has a 10-12 month 76 that can shed any light would be much appreciated....
#29 _sstorana_
_sstorana_
Posted 22 November 2014 - 11:04 AM
I have just had a look at some old service bulletins and Holden did a running change on the Torana's in Aug/Sep 1976 to the PBR Lightweight Brake Calliper.
I would say that the change from clip to grommet happened at the same time.
Mick
#30 bullitA9X
bullitA9X
  • 4,168 posts
Posted 22 November 2014 - 11:13 AM
Mick
cheers mick thank you very much for your time will be in touch for parts for my sons lx hatch as we are finally getting back into it after a looooooooooooong break from it he wants it at toranafest next year shit im going to have my work cut out lol....
#31 Dr Terry
Dr Terry
  • 3,325 posts
Posted 22 November 2014 - 11:15 AM
RTS badge for 10/76 model is correct.
Mick
Mick, LX Torana (6/V8) didn't get RTS until  March 77. The Sunbird got it in Oct/Nov 76. The badge would be correct for a 10/76 Sunbird but the dash finish should be timber tone. Also there were no LX Sunbird hatchbacks in 1976
The change to the brake pipes occurred it the same time the larger cast iron master was introduced. Also at this time the PBR alloy calipers & 2-pin brake switch were introduced. This was all part of ADR31.
There are several things not quite correct on that car. The rear demister switch should be on the console & there's no radio. An SS had a radio as standard, but it could have been optioned with 'radio delete' but why would you ?
The brake master cylinder & washer bottle are aftermarket & the fuel line to carby has been butchered. Also the anti-run-on solenoid is missing from the carb. Oil filler cap is chrome & the heat riser tube is missing.
The stripes look correct, but the 'Torana' nose badge should be diecast, not a sticker.
Dr Terry
#32 bullitA9X
bullitA9X
  • 4,168 posts
Posted 22 November 2014 - 11:22 AM
Dr Terry
thanks dr terry so all in all its very minor things to get it 100% correct....
#33 _sstorana_
_sstorana_
Posted 22 November 2014 - 12:09 PM
Thanks Dr Terry,
yeah I did correct myself ref the RTS Badge..
Shouldn't be any Torana badge on the nosecone for an SS..
Just to add with what Terry has spotted;
The Radio Fascia is one of mine as I checked the car out at Toranarama. Thought it was an interesting way that he had installed it using the screws. LOL!
Running a four barrel manifold and a Rochester carby, and
Wrong fan shroud type.
Mick
#34 bullitA9X
bullitA9X
  • 4,168 posts
Posted 22 November 2014 - 12:45 PM
Thanks Dr Terry,
Mick
Yes mick it only needs some very minor stuff to get it back to the way it should which my mate will do and the stuff thats missing would you have any of it...
#35 slr5640
slr5640
    XA9X
  • 798 posts
  • Name:Brian
Posted 22 November 2014 - 12:49 PM
hello
11/76 253 4 speed engine bay
It has the rubber grommets in the inner guards
I seem to have a different master cylinder ..not sure if mine is correct ...
Edited by slr5640, 22 November 2014 - 12:56 PM.
#36 bullitA9X
bullitA9X
  • 4,168 posts
Posted 22 November 2014 - 01:33 PM
hello
Thanks mate for that pic and info....
#37 tuxedoss
tuxedoss
  • 1,027 posts
  • Car:ss
Posted 22 November 2014 - 08:33 PM
With all the minor details that have been pointed out I think your mate can rest easy, the car Is almost 40 years old and chances are a few things might have got fiddled with. I'd say the demister switch is in the dash to fill a hole from a car alarm light, every car had one in the 80s. The radio was long ago removed for a stereo but the last owner removed it and put a new faceplate in, the screws are a bit rough though. The nose cone got a sticker because everyone thinks all toranas had one, surprised it doesn't have an SS emblem on the steering wheel as everyone also seems to think its not an SS without one
#38 bullitA9X
bullitA9X
  • 4,168 posts
Posted 22 November 2014 - 10:35 PM
yes mate totally agree....
#39 _imj411_
_imj411_
Posted 23 November 2014 - 12:09 AM
I never mentioned the the fuel system details as it says it has been changed in the listing and the oil cap is obvious too every one. I doubt it had a alarm light It is most likely that the dash is out of a SLR as it is not out of that car with a rts badge and switch. It is a lovely car not much wrong with this one. Most of the SS hatches left are far from correct and there authentistity is questionable, cheers Aaron.
#40 _LS1 Taxi_
_LS1 Taxi_
Posted 23 November 2014 - 06:04 AM
The stripes may be correct but IMHO they are so wrong. Very nice car regardless
#41 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 23 November 2014 - 06:21 AM
The centre colour of the stripe should line up with the door handle or not?
Not a good picture
deba6828a3b3109fc976e9fc24339a89_zpsfe3e
#42 _sstorana_
_sstorana_
Posted 23 November 2014 - 08:04 AM
Yeah, I agree with the stripes,
Only just noticed it. They are sitting too low along the whole body..
Mick
#43 bullitA9X
bullitA9X
  • 4,168 posts
Posted 23 November 2014 - 09:07 AM
Not a good picture
thanks lakeside can see what you mean now mate i wonder if they are painted on or vinyl either way they can and will be fixed...
#44 S pack
  • 15,726 posts
Posted 23 November 2014 - 10:07 AM
I've got the original pic from Motor Manual, December 1976 and it is much clearer that the red centre stripe does not line up with the door handle.
It appears to sit, by (approximation only) with the bottom edge of the red stripe positioned around 6mm below the bottom of the handle and the top of the red strip about 10mm below the top of the door handle.
IMHO the position of the striping on the hatch that is for sale looks ok just the colours look faded.
#45 bullitA9X
bullitA9X
  • 4,168 posts
Posted 23 November 2014 - 10:29 AM
S pack could you post up the pic for me please if you can...
#46 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 23 November 2014 - 10:32 AM
Found the same hatch on Australian muscle sales
http://australianmus...na-hatchback-2l
#47 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 23 November 2014 - 10:37 AM
Same car
7ffbf12ba22cba1d2677d9b5c693ab68_zps52b1
#48 bullitA9X
bullitA9X
  • 4,168 posts
Posted 23 November 2014 - 10:54 AM
sure is the same car lakeside...
#49 S pack
  • 15,726 posts
Posted 23 November 2014 - 11:24 AM
Looking at the pics on Aussie muscle car sales it is obvious the side stripes are not original GMH transfers.
#50 Ice
  • 15,202 posts
Posted 23 November 2014 - 11:30 AM
Either way Daz your mate got a bloody good car all the things that are wrong are not worth losing sleep over
