Hi guys,
a long while ago my Trimatic leaking symptoms were that of a bad O Ring on the filler tube (No leak when being used but let it sit for a day or two and pool of fluid). I replaced it with a generic O Ring from a multiple pack and some sealant. However after refilling the trans it leaked the same.
I have since got myself a new O Ring from an Auto specialist to put in but before I do that I degreased the trans and went looking for any other leaks.
It seems there is a leak from the kickdown plug. Would this cause the same leak I mentioned?
Also it looks like the cork pan gasket has been overtightened and one corner is split - so that needs fixing anyway.
And the yoke welsh plug must be gone too - there is a leak there.
The modulator is dry with a new gasket, the selector shaft is dry. Even the filler tube is dry.
