Project SLR5000 replica / LX Torana Sedan 77
#451
_livo74_
Posted 06 March 2017 - 09:34 AM
Sounds good!
As for those caps, had zero knowledge of uni's till now, and imagine not supposed to fall off if butterfly lands on them. Will "affix" for now, work out later
#452
_livo74_
Posted 06 March 2017 - 02:26 PM
part lists! yay!
parts have=
-all glass
-old roof lining (a stunning creme and dirt color! paint black fabric dye )
-all interior (paint black with vinyl dye)
wtb list=
-new front and rear seat belts (retractable)
-new rubber kit (minus boot rubber, pinch welds, lock grommets)
-charcoal canister mount
-brake lines
-v8 trimatic/th400 tbar selector rod and plate
-v8 wiring harness
-new carpet (black)
-engine mount bolts
-water pump bolts x2
-acc pedal and kickdown (cook having a check if has one can buy!)
-v8 trimatic tailshaft (same!)
-trans fluid lines (or just using hose)
-85 amp alternator
-?? and a zillion things cant think of
-a completed torana. so.. if you have a spare one laying around, cheers!
please msg me if have anything here i that i might be able to buy off you, if not too much hassle k!
or know of things i forgotten to list!
__________
*certainly not as long a list as when i started, that's for sure! hahaha
Edited by livo74, 06 March 2017 - 02:36 PM.
#453
_livo74_
Posted 06 March 2017 - 03:24 PM
Edited by livo74, 06 March 2017 - 03:26 PM.
#454
Posted 06 March 2017 - 07:31 PM
Where do we start ?
The engine mount bolts should not be a problem , (presuming they are the ones that hold the mount to the bracket on the K frame), a local bolts and nuts shop should have a couple that will do the job with a flat and spring washer/s and nuts , not sure what grade they were but they don't really do much and were a bit of overkill considering their size , grade 5 or even 3 should do job for probably less than $10 ?
If you have an existing wiring harness that is in a reasonable condition , meaning that most have had the fair share of butchering over the years but the basics are
still there then that can be got around when the time comes.
For the trans. cooling lines , just run the rubber tube , pretty sure more than one have done this in past with little trouble.
Should be able to pick up a t-bar shift at reasonable cost these days , just make sure that when you get one that it has the lever on the correct side (some were left some were right ) so you will need to know what side of the trans the shift linkage is on.
Personally i don't know too much about the emission control that LX had but EGR just seemed to be an abortion of a system that fed shit back into the intake to satisfy tail pipe readings and reduce power and increase emissions , the basic principles of PCV and (if fitted) the canister should just work as basic system without all the other crap that does nothing other than complicate a once simple system of the internal combustion engine ?
#455
Posted 06 March 2017 - 08:16 PM
Wiring can make your own harness...owning a holden you'll have to learn basic electricals anyway
Might have engine mount bolts if get despo.
Put up ad in WTB section not just here.
#456
Posted 06 March 2017 - 08:19 PM
I really shouldn't even mention this since you're already running around like a head with it's chook cut off but...
I just spent the last hour or so going through Hardy Spicer catalogs looking for a conversion uni joint from 6 cylinder to V8, but it just wasn't meant to be. Still, it was an interesting exercise!
All Torana 6 cylinders take a 17R series joint, whereas all Torana V8's take a 2R series, both have the same diameter caps (25.4mm) but the 17R is only 43.64mm circlip to circlip, whereas the 2R is 59.53mm.
They make five different conversions from the 17R series, and ten different conversions from the 2R series (including Holden V8 to Ford 9"), but there's none that even come close to converting from a 6 cylinder diff to V8 tailshaft. I guess the difference in strength must be too much?
#457
_livo74_
Posted 06 March 2017 - 08:34 PM
heya eunuch,
engine bolts am considering sourcing but didn't want to underestimate. will look into
have a six harness, but pretty scrappy and want a fresh 8 one so easier to install and rely upon. ebay about $140 delivered
trans cooler lines... rubber is intent, but just thought put it out there that if metal are available..
have shifter, just need the selector and plate, and the handle too, darn it!
egr's probably going to be blocked off. got the plate for it.
#458
_livo74_
Posted 06 March 2017 - 08:39 PM
heya gtr,
harness am buying, but think correct about having understanding a good thing.
but one step at a time
..or 19, like i'm attempting at the moment haha
bolts no stress, really. probably more of hassle for you to send than me to source those. as eunuch said just buy decent enough ones and should be fine
and aargh! meant to duplicate and post ad, cheers!
#459
_livo74_
Posted 06 March 2017 - 08:46 PM
"spent the last hour or so going through Hardy Spicer catalogs looking for a conversion uni joint from 6 cylinder to V8"
muchos gracias for effort and trying andrew!
am starting to think people who have done this conversion just drive around with a six barely sticking in the trans.
(..or replacing rear of diff to an 8/bigger and then able to use v8 tailshaft?)
re: "17R is only 43.64mm circlip to circlip, whereas the 2R is 59.53mm."
hmm, so cant fit standard v8 tail in my diff end(with 6cyl u-bolts), and just call the excess coming out the sides "overkill"??
#460
Posted 06 March 2017 - 09:08 PM
~ and just call the excess coming out the sides "overkill"??
No I wouldn't recommend it!
Yes the proper way to do it is to swap the yoke on the diff for a V8 one and use a V8 tailshaft, correct length, correct uni joints, all good.
How have you got the car jacked up at the moment? If you have axle stands under the diff then the rear suspension is somewhere near ride-height, but if you were to jack up the body and let the diff hang down, then the 6 cylinder tailshaft may well just fall out of the transmission?
That would be bad, like major damage bad if you're driving down the road at the time, at the very least you would likely bend the tailshaft and flog the hell out of the floor, and that's if you're lucky!
Edited by Bigfella237, 06 March 2017 - 09:08 PM.
#461
_livo74_
Posted 06 March 2017 - 10:43 PM
"Yes the proper way to do it is to swap the yoke on the diff for a V8 one and use a V8 tailshaft, correct length, correct uni joints, all good"
never done before, shock horror!
as easy as changing a spark plug..?
car is jacked on two stands, about a third from front.
now... it would be GREAT if i dropped on floor and found yoke went an inch further in
..and
then i jacked up rear... and let diff/wheels hang...
and found yoke about as in as is now
could get away with that maybe..
though,wishful thinking i suspect
anyways, for another day,
as gtr said, just use as test tailshaft for now, fix later.
as for.. "major damage bad if you're driving down the road at the time.."
yup.
not that i really think it wouldn't bend before sending me ass over tit.
(rightly or wrongly, to me my 6 tailshaft feels like light, flimsy crap to be honest, can't believe they don't twist even under normal load. )
Edited by livo74, 06 March 2017 - 10:44 PM.
#462
_livo74_
Posted 07 March 2017 - 02:30 PM
here is link to my what still to buy Ad
http://www.gmh-toran...needed-lx-tory/
and as i feel have taken up.. well enough!!.. of peoples valuable time lately,
and thanks to everyones' taking that time to advise of just how to go about it, i have enough to go on with for quite a bit,..
so will try to knock off 3-5 of the 3,016 things left to do that have been given answers for.. and get back with the progress shortly
..and be back with more questions!
wish me luck, as i just may need it..? hahaha
#463
_76lxJAS_
Posted 07 March 2017 - 03:37 PM
#464
Posted 07 March 2017 - 03:43 PM
Its actually great you are asking questions.
Even better that you are taking the advice.
There have been some who ask questions, get answers and then do something totally different.
Lots of good stuff being covered here too.
#465
_livo74_
Posted 07 March 2017 - 03:45 PM
cheers jas!
in part, just a tad fearful if try to take in any more information i think my brain will explode.
and up and running would just be freakin sweet!!
have half a chance with everyones help given!
i've been guilty of that, rockoz!
not intentionally, just forgetful and mixing info accidentally
#466
_livo74_
Posted 07 March 2017 - 09:22 PM
(eunuch, gtr, andrew.. have annoyed the crap out of you three especially!
so.. do be so kind as to tick "follow" my thread, so i can show you the fruits of your labor just as soon as i post em.* )
#467
Posted 07 March 2017 - 09:36 PM
All good will be checking in...when not you'll know I'm back into house reno or hiding in garage lol
Bit envious of your enthusiasm mate.
#468
Posted 07 March 2017 - 10:17 PM
All good , one step at a time , bit by bit , try not to get caught up in trying to think of the system as a working unit because there is a lot of bits that make up the working system , in other words it will come together
no , have not pissed anyone off , it's just the way things are when questions are asked and replies are given , so ask as many questions as you like , there will be many replies concerning what can be done to make things a bit easier...that's the good thing about this place ..
#469
_livo74_
Posted 07 March 2017 - 10:50 PM
cheers guys!
have about 9 pages of work to do!
#470
Posted 20 March 2017 - 01:09 PM
Hi Matt,
I've got the tailshaft and kickdown switch if you are still interested. Cheers Ron
#471
_livo74_
Posted 20 March 2017 - 01:12 PM
hell yeah ron! will msg ya
#472
_livo74_
Posted 19 April 2017 - 03:42 PM
nothing to report of great note, no vids of her firing up that's for sure!
..darn it.
thought would post my mischief that i've have been up to, anyways
got my coil for my hei dizzy
not going to even attempt fitting by myself till have someone next to me making sure "top dead centre", from what i've read anyways
#473
_livo74_
Posted 19 April 2017 - 03:45 PM
heater hoses chopped and lowered.
and a brandnew wiring harness, as my "6" was old and tattered.
got the "post poll" one, just in case need later.
as you can clearly see... i don't have a clue what the wires are for basically
the 9 has been run thru engine mount to starter
as for "7".. there is no "7", oops!
Edited by livo74, 19 April 2017 - 04:11 PM.
#474
_livo74_
#475
_livo74_
