I may have been thinking of another model? It could possibly have been the early Commodores that had a common harness with a jumper connector?
I've had so many different cars over the years and they all tend to blur together after a while!
Posted 15 May 2017 - 02:39 PM
Posted 15 May 2017 - 04:24 PM
no blurring together for me, that's for sure!
___________
see that wasn't so hard was it!?
Edited by livo74, 15 May 2017 - 04:25 PM.
Posted 15 May 2017 - 05:31 PM
So... only the kickdown switch to go then?
You can't be too far away from a test fire?
Posted 15 May 2017 - 06:07 PM
Posted 15 May 2017 - 09:56 PM
Grey illumination light can tap into other grey wire in harness to dash lights?
So when turn headlights on dash & selector light all come on together
Where you done purple wires can also put relay near it later on if it doesn't push enough voltage to crank or even remote alarm.
Check selector rod adjustment for correct position ie P R N D 2 1...hook up a battery & crank sucker over.
Or should we show ya how to do hotwire/dodge start to hear it running?
Posted 15 May 2017 - 10:48 PM
heya andrew, didn't have wire long enough to do kickdown so still to do. might have it done by tomorrow.
and not long till ..attempt.. to start her!
_______________
cheers trevor! she's coming along now and thanks to forum members have learnt a lot i had ABSOLUTELY no clue about
___________
heya gtr, grey i "think" i have tapped out of the grey, it's got it's own terminal.. but that is on the same ??"bridge" as the existing grey illumination wire.
so should come on with all others. ..i think
relay later may take you up on. don't know about voltages to crank etc so if problem arises i will be asking a few questions.
nothing out of the ordinary there;)
now.. as for "hook up battery".. car didn't come with any of that cabling, so have to put some scraps together from an ef falcon battery leads and terminals.. or start from scratch.
if anyone has got a couple of pics of their engine/cables showing where running from/to??? positive to alt? starter?, ?? (i have NO idea)
and where the neg goes.. would be most handy.
would rather have that setup than hot wire if poss, and gives me time to try and give tank a clean out first
and maybe get an alternator,
and.. put in some exhaust piping like you warned me about.
and ATTEMPT to take ignition barrel apart and put in my new one, like have already done with doors and boot. been slack/avoiding that job.
and havent done modulator pipe. could just hook up temp hose till buy/bend pipe.
and,
i THINK i got the selector rod in position, cars up on blocks and stands right now, since put in, so hard to be doubley sure till can roll her.
and 37 things i've forgotten lol
____
still,
bit scary now. close!
Edited by livo74, 15 May 2017 - 10:56 PM.
Posted 16 May 2017 - 12:04 AM
~ as for "hook up battery".. car didn't come with any of that cabling, so have to put some scraps together from an ef falcon battery leads and terminals.. or start from scratch. ~
Does your engine have the steel tube that runs down the side of the block to the starter motor?
If so then your thick battery positive cable runs from the battery (+) terminal, through that tube and connects to the outside "bolt" terminal on the starter solenoid. The purple starter wire from the engine loom also runs through that tube.
You may also need to run a not-quite-so-thick red wire from the "bolt" terminal on the alternator back to the battery (+) terminal, unless that was included in the wiring loom you bought, I can't remember?
This wire should have some kind of heavy duty fusible link in it too, rated slightly higher than whatever your alternator is rated at (so 100 amp alternator requires say 120 amp fuse).
Then you need a thick earth cable between the battery (-) and the engine block, just make sure to scrape any paint, grease, oil or rust off before attaching to the block so it makes a good contact.
Lastly you need an earth from the battery (-) to the body, this one is important because it will earth all the lights, heater. stereo etc., if you don't have this connected all kinds of strange things happen!
~ATTEMPT to take ignition barrel apart and put in my new one ~
Do you have the key for the old barrel, or are you able to turn it without they key?
It makes it much easier to remove if you can turn it from "LOCK" to "OFF", otherwise you have to start smashing things apart and it's highly likely you'll damage the "coffee pot" in the process.
You just need to remove the steering wheel, turn to key and depress the little tab on the barrel through a slot in the alloy, then it should just pull straight out.
Although if the ignition barrel has never been out before, there is quite often a thin piece of alloy casting still blocking the slot, but it usually takes very little effort to break through that and release the barrel.
Posted 16 May 2017 - 05:29 PM
champ! thanks andrew.
if you or anyone has thoughts on where purple plugs in, would be great!
..cus my old version has 3 points on offer for the engine loom Purple.
_________
and
nope, i dont have a pipe to run cables through.
do have corrugated conduit on the thick positive..
and "shielding" on the purple and fusible to starter..
was just gonna run thru engine mount so away from engine and moving parts
?? no idea really.
_______
no key for old barrel, but does turn thankfully.
will attempt tomorrow using your guide,
might have kickdown done hopefully too.
Edited by livo74, 16 May 2017 - 05:35 PM.
Posted 16 May 2017 - 06:09 PM
Purple wire to the male spade fitting. The idea of the metal tube was to protect the wires from exhaust heat, so you will have to watch where you route them.
Posted 16 May 2017 - 06:35 PM
By the looks of it, that loom you bought may have a big red alternator wire already included (the one with the fusible link)?
Can you confirm that the wiring loom has a thick red wire at the alternator already? If so then you don't need to add another, but I would be pulling it out of the tubing and running it direct to the battery rather than the starter, no sense exposing more wires to the exhaust heat if you don't have to.
Hard to find a definitive answer on the rating for the fuse wire, but one website I looked at says 1mm2 is rated at 160 amps for 30 sec or less, or 270 amps for 5 sec or less, if that's accurate then I'd say it should be okay with an 85A alternator?
With that purple starter wire, it connects to the blade terminal on the starter solenoid. I can't remember exactly but I'd guess it's the single terminal at the top (number 1 in your photo)? Doesn't matter if it's wrong anyway, it won't hurt anything, just swap it to the other terminal if the starter doesn't work.
EDIT: I forgot to say, make sure those threaded battery hold-down rods don't hit the bonnet when you close it? They look pretty long.
Edited by Bigfella237, 16 May 2017 - 06:39 PM.
Posted 16 May 2017 - 06:56 PM
it has bloody 3 male spade fittings, just to be tricky!
as andrew says below, possibly top one to give a go first.
and.. will now be careful where running wires, away from exhaust, cheers laurie!
Posted 16 May 2017 - 07:00 PM
Should be fine with that fusible link...most are tiny anyway.....it's main purpose is to blow first to protect wiring harness
I'd try position no.1 on that funky old starter ...can test it anyway with wire from battery to each spot..whichever gets it to spin is the winner.
Cable from alternator to battery is fine for 85A...only if you go bigger alternator you need beefy cabling.
Factory metal that battery cable runs through is simplest/easy way to fit but I have fitted them through engine mount or along sump with p clamps when hiding wires.
Edited by gtrboyy, 16 May 2017 - 07:05 PM.
Posted 16 May 2017 - 07:02 PM
heya andrew,
no red on my new loom to alternator, only the brown.
so going by what you said initially, and also the "lx wiring diagram" i added,
i do need the "thinner" red from battery to alternator,
and the thin "fusible" (from engine loom) goes to the starter, along with the purple..
from what i can read from diagram anyways! lol
__
and your checking out of fusible ratings sounds good to me!
Edited by livo74, 16 May 2017 - 07:04 PM.
Posted 16 May 2017 - 07:10 PM
"whichever gets it to spin is the winner."
hahaha! andrew agrees, gtr
so that's the process i'm taking.
and it'll be a surprise!
_______
and as for "fusible".. better to blow than not to blow, from what are saying.
bloody thin wire, the black, so won't be too hard i reckon. ??
______
and damn! thought the cable i used was pretty darn chunky.
still, now will remember to upgrade if going higher amp alt.
Posted 16 May 2017 - 07:24 PM
85a is best value for coin....after see the price tag of a vt v8 120 or converted ls1 140A...unless you're silly like me who run thermofans,f/pumps,efi + cdi etc save ya money.
If fusible link blows..saves the car from melting harness...seen a lot of people not replace or even fit them which is silly although I do like expensive circuit breakers that you can reset 'cos can double as a kill switch lol
You'll want to build another car after this one now you've learnt so much.
Posted 16 May 2017 - 08:30 PM
it was you that put me onto the 85.
but thermos for me only for now hahaha
i don't know about even wanting to build a sandcastle after this lol
not true maybe?!
hq utes are pretty cheap and can look friggin beautiful, or a vh with vc bodykit
hmmm
what really may be next.. is my neighbor has got the bug after seeing mine happening,
and said to me ... "ya made me realise, ya gotta have a racecar in the garage, don't cha! give me a hand turning my immaculate stock standard XE ive had shedded for 15 years into a v8 "greens tuf" replica would ya"
i said yep. let's fookin do it!!
(he knows full well i am a novice, but will be using me for motivation and a hand where needed)
should be fun:)
Posted 16 May 2017 - 09:33 PM
so i do need the "thinner" red from battery to alternator,
Yep, looks like you will need to run your "thinner" red between the "bolt" terminal on the alternator and the battery (+) then after all.
Note that this wire should have a fusible link near the battery as well (although I've seen people do it without).
I know your loom was designed to have that fusible link connected to the starter, but I'd say that's mainly for cars with the battery in the boot, with your battery up front I would definitely be connecting that fusible link to the battery itself.
That wire powers EVERYTHING in the car, if it melts from the exhaust then you're stuck where ever it happens!
Posted 16 May 2017 - 09:55 PM
putting a fuse on alt's thinner red sounds good to me, but do you mean like the "fusible link" as shown,
or an inline normal "fuse" like i'm used to seeing. (with the same wire either side of it)
(or is inside that "black tablet joiner thingy" a normal fuse. or is it the black wire that actually "gives" ??)
and for either, what rating?
the oldschool "lx diagram", and the black and white diagram also
show the engine loom "fusible" running to starter
?? is it not necessary
do all cars have the pipe protection?
i spose as connected to the "thick" red there on starter,.. it doesn't actually care where it touches/connects 'back' to the battery.
don't care to burn thru while driving myself, so happy to re-route.
(that said, only at the section where loom ends and becomes the purple and fusible.. does it begin to have this different "shroud/tube" it runs in, so ...imagine specific for heat protection.. i... ?guess)
Edited by livo74, 16 May 2017 - 10:06 PM.
Posted 16 May 2017 - 10:42 PM
Whether that red wire/fusible link goes to the starter or the battery doesn't make much difference, it's connected to the positive power either way.
I'm just saying it's pointless to risk running it past the exhaust if you don't have to.
Posted 16 May 2017 - 11:25 PM
am happy to run it to battery, better safe than sorry later that's for sure. but means will have to chop off the protective shroud that protects the purple as is. oh for a factory pipe!
Posted 17 May 2017 - 12:08 AM
Ah okay, now I see what you're saying, I thought it was just that convoluted flex tubing (which is split down the side) but now I see it's a little more substantial.
Anyway, six of one, half a dozen of the other. If you can keep it away from the exhaust then I guess it doesn't matter either way?
The list left before fire-up must be getting pretty short now? Did you say you were still waiting on an alternator bracket or something?
You could probably start it without the alternator or fan belt so long as you don't run it more than a minute or so. You'll still need to fill the radiator though, as well as make sure the engine and trans fluids are topped up.
If the engine has sat around for a while you might have trouble getting oil pressure too, this a very common for Holden V8s, most of the time you can prime the oil pump by unscrewing the oil pressure sender/switch and filling the pump with oil that way, just remember to reinstall the sender before you attempt another start or you'll have a big-ass mess to clean up!
Posted 17 May 2017 - 01:27 AM
According to diagram fusible link is 12v ignition power...instead of at battery terminal like later holdens it's at starter...earlier models are worse they have it at dash switch
black fusible link to starter
purple to solenoid <^ these 2 go up engine to join body harness
Thick red from + battery terminal to starter stud
Thinner red follows ^ to head then goes left across engine to alternator stud
Brown wire (alt charge light) goes back across engine
Green,blue & brown wires together run along manifold/rocker cover to join body harness.....google image factory engine bays you'll get the idea.
Yes still agree 85A is good value...just hurting for when I buy bigger alternator lol
Posted 17 May 2017 - 05:40 PM
very close to fire up! but just want to get few more things before do, like the alt and fan belt, so can run as long as want.
goodness willing, that is!
and yep, fluids all need filling/checking.
like many things.. will be my first time doing that, looking forward to it
had been told previously to make sure i prime her and read up about it. had no idea needed to or how so much appreciated info.
gather would be VERY dry inside engine,
..and wet outside if forget to reinstall sender seems lol!
Posted 17 May 2017 - 05:50 PM
have done as much as can,and what are saying have done some,
will be fitting off starter wires tomorrow.
(i have a few loose wires that are for post pollution, numbered 2, 5 and 6.
my fault, asked for post pollution loom so have if needed.
will be just black taping them too hide if not needed. )
am going to get a 85 amp alt, hook it up,
get key barrel in,
kickdown done,
.. and do the priming and fluids,
and,
still to get dizzy and coil in.
will be getting someone else to do, as would prefer no mistakes with top dead centre.
might be the bloke i bought car off, he told me to buzz him and happy to help get started...
TWO YEARS AGO!
he might have a little less interest in coming over so far since sale haha
though, has dropped over twice to check progress, and bought a few more parts off him since,
so.. might be up for it, for enough beers!
Edited by livo74, 17 May 2017 - 05:52 PM.
Posted 17 May 2017 - 06:49 PM
Try to get genuine bosch item...basically they punch 30-40 amps just above idle where as 'bosch style' crap on ebay do half that unless rev bejesus out of them.
Other than that white wire for v8 85A is load-sensing goes to + terminal & brown you already know
C'mon man have a crack at dissy!!!!
Old points still in there?
If so we can guide you to tdc no.1
Edited by gtrboyy, 17 May 2017 - 06:52 PM.
