heya andrew,
knew meant disconnect one of the "brake switch" reds,
did it, and lights went off.
also... pulled brake pedal hard up against switch... and it went off.
yay! (may have to adjust when have "plumbed" brake lines etc)
went to repco, only sell fuses in bulk and as am broke will wait till wednesday to buy few sets to replace all.
as for "wedge bulbs", he asked what ones.. and i said don't have a clue.
will take apart dash and buy replacements on wednesday too.
same goes for ALL bulbs in car.
________
know NOW, about twist n pull for park brake. didn't then, hence oops.
(mine didn't have the better" twist n pull" logo for learners.)
was wrong, brake lights don't get brighter when i turn on the headlights. (twas optical illusion/camera playing tricks)
... but, found i don't have tail lights at all. only brake lights.
thankyou for info on the turn of keys steps.
had no idea.
still.. am NOT brave enough to turn to "start"
will wait till have few more things connected and primed.
and come to think of it, my heater lines are disconnected so as to make room for dizzy removal/install
hope to be doing over the weekend.
(although.. have bought some fluids. EXCITING! A FIRST!
coolant and 20-60 oil with ??zinc"
repco guy said might be good idea. )
after have changed all the bulbs, will go and check all connections aren't corroded and give a good scratching
Well done Matt. Great to see you have been able to breathe some life into the old girl. Keep at it. Cheers Ron
cheers cook! bloody exciting times i tells ya!
Edited by livo74, 26 May 2017 - 06:18 PM.
