no power to either purple at trans
also, checked "continuity" of trans switch in "park". no continuity
wiggled, no change.
so apart from no power being sent through purples on trans loom.. it "appears" my shifter switch is no good.
so..
i then go backwards and check my connection (where i cut the original ignition switch loom purple) to see if power there.
none.
(well, ".21" volts when turn ignition on. hmmm??)
so, i have no power being fed through from main red (which DOES have power! i checked.) out to the purple when turn key.
_________
so.. as have a spare parts column.. took the ignition switch from that and swapped it over onto car.
and...
STILL no power to the purple when turn key.
yup. (read: F@#K)
____________
TWO broken ignition switches.
bloody doubt it.
something ive done? mmmmost likely.
Edited by livo74, 30 May 2017 - 04:55 PM.
