have had to concentrate on other things so not much happening on project.
did find time to install spacer on drivers side, as was 18mm lower than passenger.
(springs "seemingly" bedded properly, not sure of cause.)
used a 10mm one, and raised car 17mm to almost perfectly match now.
IMG_2673.JPG 118.85K
9 downloads
(if knew better.. would of realised could of been done WITHOUT taking off rotor)
also, remembered to put in shims finally, so have better negative camber.
also, bought a few cheap things to carry on with project till find money to pay someone to fix my brakes/calipers/lines/booster
..whatever is causing ??vacuum leak
horns
the SINGLE rear brake line hose
(was expecting needing 2. only now realised is not the case)
steering wheel (as needed a horn button anyways)
if anyone knows how to wire a horn button to horn, would be appreciated.
i have ONE wire inside steering wheel cavity for a horn button,
(seems to be a GROUND??)
but the steering wheel button comes with TWO possible terminals underneath?? i think.
and, so do the horns, (TWO terminals each) when "seemingly" i only have ONE dark green ?positive wire.
(which i will run to one horns POSITIVE, tap out and then run to the other horn)
imagine i just have to rig up a grounded black and hook up to neg terminals.
(figured attaching bolt would be a ground? anyways, will just use terminals.)
IMG_2731.JPG 122.63K
6 downloads
Edited by livo74, 23 September 2017 - 10:03 AM.
