* * * * * 1 votes
Project SLR5000 replica / LX Torana Sedan 77
1102 replies to this topic
#1026 _livo74_
_livo74_
Posted 03 February 2018 - 03:20 PM
All cables now run in split conduit, and now have wired thermo fan and alt sensor thru the new fuse box
(mounted to the right of battery)
Got to test it early, too.  (an individual led goes ON if a fuse is blown.)
Looked up what my thermo fan was rated at, and info said "less than 10amps"
so... chucked in a 10.
blew as soon as thermo kicked in at temp.
Now have a 20amp in there, and working fine. (but, don't i know what am doing, so ..will keep an eye on it.)
Attached File  IMG_3634l.JPG   78.32K   5 downloads
Attached File  IMG_3635l.JPG   94.05K   7 downloads
Edited by livo74, 03 February 2018 - 03:21 PM.
#1027 Bigfella237
Posted 03 February 2018 - 04:31 PM
Depending on the fan(s) a 20A fuse might even be cutting it fine, do you have anything like a LED / light in the car to tell you they're working?
I think you kept the factory temp "idiot light" in the dash working anyway didn't you (I recall you wrestling with 3 different senders in the manifold)? That will hopefully warn you if the fans don't cut in.
You will iron-out all these bugs over time anyway, just carry some spare fuses in the glove box.
Just 2 tiny things to add to your list too...
For rego they will probably want to see rubber grommets around the brake lines where they run through the inner guards.
And for the sake of a few bucks it would be worth getting those plastic separators for the spark plug leads, something like these...
https://www.ebay.com...5.c100005.m1851
You're not supposed to cable tie high tension wires together like that because it can cause misfires (the spark travelling through one wire induces voltage into another), brand new leads aren't as bad for this as older leads but for a few bucks it's better safe than sorry.
Edited by Bigfella237, 03 February 2018 - 04:33 PM.
#1028 _livo74_
_livo74_
Posted 03 February 2018 - 04:52 PM
cheers for info as always andrew!
have bigger fuses on hand, and may just go to a 25amp for safety's sake. kinda don't want my fan to stop lol
yes, kept the factory idiot temp, as well as the added interior gauges/temp  (so sill keep an eye on whilst in car)
fan's so bloody noisy can tell when its not working too ;)
rubber brake line grommets, gotcha!
and will add those separators too, cheers!
(new leads, but still don't want to cause unnecessary issues)
thanks for the link! cheap!
Edited by livo74, 03 February 2018 - 04:53 PM.
#1029 _GMH-001_
_GMH-001_
Posted 04 February 2018 - 01:05 AM
you may already have this covered but... make sure your wiring for the fan is rated at a higher amperage than the fuse you use. If not the wire can melt, catch fire, and bring a sudden end to a good day
#1030 Bigfella237
Posted 04 February 2018 - 06:46 AM
Good point Tony, but looking at the picture above it all looks like 50A wire to me. so I assume it'd be okay (but you know what they say about assumption)... ;)
EDIT: BTW, that negative battery lead isn't looking all that flash either, Mat?
Edited by Bigfella237, 04 February 2018 - 06:48 AM.
#1031 _livo74_
_livo74_
Posted 04 February 2018 - 08:50 AM
I certainly DON"T have that covered tony, so is best and appreciated that people feel free to do double checking.
I OFTEN put this car together with whatever parts i could get for free or scrap laying around and just hoped it would be ok, nor do i really know anything about rated wires etc..
so.. the wire you are looking at is household 2.5mm elec wire, and as thought by andrew.. a tad overkill, if anything??
will try and clean up the negative.. or buy a new clamp (from memory, it may not be "adjustable" one)
cheers!
#1032 Rockoz
Rockoz
  • 4,031 posts
  • Name:Rob
Posted 04 February 2018 - 10:57 AM
The fuse is there to protect nothing but the wires.
It isnt there to protect the fan.
The wire is protected so that it doesnt overheat and cause lots of smoke to come out of lots of wires.
Motors can typically draw 3 to 4 times their rated current and more when they start up.
Thats why you use a bigger fuse.
Rate the fuse to the size of the wire. Nothing else.
The bigger the wire the bigger the fuse you can use.
#1033 _livo74_
_livo74_
Posted 04 February 2018 - 12:16 PM
thanks rob! know nothing of the maths involved in what i am doing.
(if took to heart all that i don't/didn't know about cars the project would never of been started. wishful thinking, luck, and the guidance of forum members got this car to where it is.)
figured a fuse was to protect the "motor/part" from a problem caused by that or another "part" .. sending a surge???, and not there to protect the wires!
whoda thunk it!?
(people with heads on their shoulders, probably! ;) )
and no wonder andrew says might want to go higher than the 20amp.
3-4 times on start up of fan motor could be an issue.
Edited by livo74, 04 February 2018 - 12:18 PM.
#1034 Shiney005
  • 9,586 posts
  • Car:Toyota Mirai
Posted 04 February 2018 - 01:32 PM
I never thought of it that way Rob. Great bit of info there.
#1035 _livo74_
_livo74_
Posted 05 February 2018 - 04:01 PM
finally got around to correcting my mistakes with "blackouts"
surrounds the doors in black, in all the exposed areas and gaps now.
Attached File  IMG_3637.JPG   72.57K   4 downloads
Attached File  IMG_3639.JPG   66.78K   5 downloads
#1036 koalasprint
koalasprint
  • 297 posts
  • Name:Steve
  • Car:LX SS Hatch
Posted 06 February 2018 - 06:17 AM
Now you are getting to a more enjoyable stage. Car is running and getting onto those little jobs. It actually never ends you know.....
Anyway I thought I could help with the fuse/wire size thing.
Cable size Rating in Amps 1mm - 15.5A, 1.5mm - 20A, 2.5mm - 27A, 4mm - 37A.
Cheers, Steve.
Edited by koalasprint, 06 February 2018 - 06:21 AM.
#1037 Rockoz
Rockoz
  • 4,031 posts
  • Name:Rob
Posted 06 February 2018 - 09:02 AM
Would consider those slightly high in their ratings Steve.
But near enough to not confuse the issue.
The longer the run of wire, the bigger you should make it.
If you fit relays, they get best effect when mounted as close as possible to the part they are powering.
Relays can be considered to fall into 2 broad types.
1. Taking the load off the switch that operates the part.
Micro switches are great for being built into smaller assemblies, but cant handle much current.
So the micro switch operates a relay using low current. The relay does the high current switching.
2. Reducing voltage drop on high current parts with long wiring lengths.
Ideally the relay is supplied with a larger than required wire. The relay is placed as close to the part as possible.
A smaller wire can then be used from the relay to the part without having voltage drop issues.
An extreme example of bad relay placement would be having the relay next to the battery supplying a high current drawing part on the other side or end of the car.
A lot of the relays in modern cars are to take the load off the switch, which may actually be the computer in many cases.
#1038 _livo74_
_livo74_
Posted 06 February 2018 - 12:22 PM
"It actually never ends you know....."
suspected as much! hahaha
which scares me. i put this car together... so am aware (and forgetful !!) of the million individual steps that can fail and have to be searched through to find the culprit!
and am praying that my wiring just works rob
..so i don't have to get my head around all those laws! lol
#1039 Rockoz
Rockoz
  • 4,031 posts
  • Name:Rob
Posted 06 February 2018 - 02:09 PM
Electrics are a magic art.
All electricals work on internal smoke principles.
Rule 1. Dont let the smoke out.
Auto electrics on the old girls is actually pretty simple.
Earths will always be the number1 problem. Bad earth connections that is.
These days some of the glass fuses are a problem. Bad manufacture where the fuse wire doesnt always connect to the end caps.
The fuse panels will sometimes give dramas with corrosion on the clips that hold the fuses in place.
The old grey ink eraser is good for cleaning them up.
Some of the cars will have had some atrocious add ons over the years.
Twist and tape isnt a great way of connecting things up.
Insulation tape unravels over the years.
The harness connectors are usually okay except near the battery, where the acid environment doesnt do them many favours.
A 3 buck test light will help solve 90% of problems.
If you have dramas just ask.
I can work most issues out by asking a few questions.
I usually give a few things to check. Others do too. Im not alone in knowledge.
Follow the tests and nothing else and report back your findings.
Hope you dont have too many dramas anyway.
#1040 _livo74_
_livo74_
Posted 06 February 2018 - 03:39 PM
much appreciated info and help rob!
and may just try the ol' eraser trick, as i did clean/scour my fuse clips but wasn't entirely confident that it was as clean as could be.
did replace all the fuses though, seem an ok batch as yet
have not used insulation tape as securing method, all done with connectors (...because had learnt from past efforts ;) )
and i ran an extra ground into chassis, as was advised earlier that it can be a problem.
don't have a test light, as bought a decent tester so could check voltage etc too
has been a god send
cannot complain of TOO many dramas, a... few, as many that have helped me can attest to ;)
which is good, but
main lingering problem is MY F@#KIN" SHIFTER !
1. pressing the button takes a sledge hammer, (like it's jammed???)
and 2. it's still not the right amount of "throw"
am taking apart and gonna try again, on a hoist this time though, with a second person underneath the car
hopefully will have a positive result
#1041 Bigfella237
Posted 06 February 2018 - 04:53 PM
Fix the linkage problem underneath first, there's a good chance that will take the pressure off the shifter detent and solve your button problem as well?
#1042 Rockoz
Rockoz
  • 4,031 posts
  • Name:Rob
Posted 06 February 2018 - 05:04 PM
What sort of connectors did you use?
Have found with a lot of connectors that if they arent secured, the weight of them and a bit of vibration ends up with the wire breaking at the connector.
By far the best way to join wires in a car is soldered and heatshrinked.
Before someone goes off about standard connectors, they generally have a few extra wires in the connector that offer a degree of support.
A single connector left dangling is likely to cause future problems.
#1043 _livo74_
_livo74_
Posted 06 February 2018 - 05:20 PM
will try andrew,
will hope and curse and try lol!
and rob, you have reminded me of something i found out i needed to do, but forgot.
i used all proper "crimp"ed auto connectors.
thought.. good job!
then went and fiddled with one.. and one of the wires just fell out/apart. so planned to go back and solder, as soon as buy one and learn how to again.
youtube, here i come; again.
#1044 Rockoz
Rockoz
  • 4,031 posts
  • Name:Rob
Posted 06 February 2018 - 06:01 PM
Mat
Ive crimped countless thousands of joins.
Even the most practised person will stuff up one every now and then.
My last one, and first one I didnt notice for years, happened to be on my own fridge I was fixing.
Problem had me scratching my head for ages.
Found it by accident looking for something else.
With solder and heatshrink you know you have done a good job before you move on.
#1045 _livo74_
_livo74_
Posted 06 February 2018 - 06:16 PM
will do!
already bought heatshrink, just need to get a soldering iron (and not forget again haha)
#1046 Shiney005
  • 9,586 posts
  • Car:Toyota Mirai
Posted 07 February 2018 - 08:49 AM
I've used a few soldering irons over the years,(including the ones you heat up with an oxy) but I recently purchased a Weller Pyropen and it is brilliant. It doesn't matter how cold or windy the day is. It just does the job every time. It may be overkill for what you are doing Matt, because you can buy much cheaper ones, but I reckon mine will do me for life.
Attached File  WPA2_1.jpg   84.61K   7 downloads
A couple of questions for you Rob.  What do you think of the Narva connectors that have the solder built into heat shrink?
                                                         And is there a way that you can treat old discoloured wire so that solder will stick to it?
#1047 _livo74_
_livo74_
Posted 07 February 2018 - 09:17 AM
think i've seen that tool before..
believe it was being used on the space shuttle
jeezus!
Edited by livo74, 08 February 2018 - 08:44 PM.
#1048 Rockoz
Rockoz
  • 4,031 posts
  • Name:Rob
Posted 07 February 2018 - 10:00 AM
Had never seen that before. Heatshrink with solder.
Looking at it I personally would steer clear of it.
I like having a look at my solder joints when done.
Those gas soldering irons are great but be careful where you store them.
Ive used one on and off for years and they are great for a quick job.
But if I am doing any large amounts of soldering I will plug in an electris one every time.
An electric one maintains heat a lot better, and for people just learning to solder that has ita own advantages.
Solder joints in wires need to have mechanical as well as electrical strength.
The wires should be well twisted together to gain the mechanical strength, and then the solder gives them the electrical strength.
If you have a join where the wires are just laid side by side, you can end up with problems if the wire has a tendency to get hot.
The solder can soften, the wires pull slightly apart, and if vibration i present it may become what is called a dry joint.
The solder will look dull, and the surface will take on an appearance sort of like what happens if you try to use bog that has almost gone off.
You get the lumpy sandy kind of look.
For joining wires that have become oxidised, gone all dark coloured there are ways of fixing it.
Because of the age of the cars we play with, it will be common to find, and not likely to be because of anything bad. Acid etc.
A lot of the time, cutting a few inches back will get you to bright copper, which will solder normally.
But knowing the old cars, that sometimes isnt feasible because you dont have much spare length to play with, or the wire will be like it the entire length.
Acid will clean up the wires, but really not the best way.
I would fall back to the old grey part of the rubber for this.
Perhaps using two with the wire in between might be easier. Splay the individual strands out first.
Bit of wet and dry and give each strand a rub will do the trick too.
There is no point soldering unless the wires are clean. It just wont work.
Some may be better off having crimp joins done and heatshrink. Prefer non insulated crimps because they dont have the thick plastic insulator.
If you search around specialty electrical suppliers you can get them down to really small sizes.
Not always an easy job though.
A stainless wire brush on a dremel will help.
The corrosion on the wire doesnt seem to have much effect on the conductivity of the wire, but you wont get solder to stick.
#1049 _livo74_
_livo74_
Posted 07 February 2018 - 07:30 PM
like the idea of non-insulated with heatshrink. will be using them in future. cheers!
have taken apart my console and shifter. am extending the rod tomorrow, and will post the results.. positive hopefully.
Edited by livo74, 07 February 2018 - 07:30 PM.
#1050 _livo74_
_livo74_
Posted 08 February 2018 - 08:42 PM
a new/replica tbar handle was the culprit and causing the grief to press the button.
had a second old/original one on hand and now shifts/presses fine.
and, extended the rod by 2 inches and now shifter works and is positioned great!
...well, compared.
if i put it into "low" the button pops out/free
..and... my "park" is good for neutral only. doesn't seem to lock the gearbox/wheels. darnit!
