Battery Operated Rattle Gun
86 replies to this topic
#1 71Ranger
71Ranger
  • 267 posts
  • Name:Brian
  • Car:71 LC
Posted 26 December 2014 - 08:33 AM
Merry Christmas all,
Im in the market for a new battery operated rattle gun after some low life scum lifted mine from my boot when I stopped to help a breakdown. :mellow:
My original was an 18V Bosch that did the job really well, but as it was 20 months or so old Im sure technology has moved on.
So any ideas about the latest and greatest would be appreciatted.
Its for home use.
Cheers Brian
#2 _judgelj_
_judgelj_
Posted 26 December 2014 - 09:54 AM
Well do you have other bosch batteries/tools? If you do i'd just buy the latest bosch skin. If not, Milwaukee make some great products. Their big rattle gun is plenty powerful, but can be a bit heavy. They also have a smaller one the size of an impact driver, but its a 1/2" socket drive. That's pretty powerful too and will easily do wheel nuts. The only real advancement these days is probably the brushless motors. I would suggest a 4.0ah battery if you didnt already have one.
If you want to stay on the cheap side buy a 1/2" ryobi impact gun. Its pretty cheap and plenty of power does my hilux wheel nuts without a problem.
Edited by judgelj, 26 December 2014 - 09:55 AM.
#3 fatslr
fatslr
  • 1,247 posts
  • Name:Garth
Posted 26 December 2014 - 09:56 AM
We use Bosch onsite at work they are given a fair flogging by the fitters and hold up well.There are replacement brushes readily available and cheap.
#4 _Skapinad_
_Skapinad_
Posted 26 December 2014 - 10:37 AM
Agre with Jacob, if you have the batteries and charger just get anothr bosch skin..... They are pretty cheap compared to having to buy another charger and batteries.
I have quite a few of the bosch 18v range, they are great tools, but i only use them for light home use...
#5 _mello92_
_mello92_
Posted 26 December 2014 - 10:38 AM
Brushless Milwaukee gear is fantastic, been using them at work for a few months and can't fault them.
#6 LJ RB30
LJ RB30
  • 1,038 posts
  • Name:Trevor
Posted 26 December 2014 - 12:05 PM
I bought a Milwaukee set, grinder, drill, small 1/2" impact gun about 12 months ago after using some on a job.
The impact gun onsite was the larger one & they are heavy especially when used with extended arm as we were uncrating container size packing crates!
 But grunt galore! It snapped several 16mm stainless bolts!! (that then taught the kids how to remove broken bolts ! HAHAHA)
I bought my set to replace an old ryobi 18v drill (stuffed batteries & wobbly chuck) & to get the grinder & rattler!
The little rattle gun gun struggles with tight wheel nuts! Less than 50% success recently on tight but lubed wheel nuts.  :(
Am abit disapointed with it on wheels but for general stuff its ok!
Grinder & drill are brilliant!
Have a look at Sydney tools. i bought my set from there delivered with a bag cheaper than i found over here!
Oh i now charge the batteries monthly & dont leave them on the drill etc in an attempt to make them last longer as i think lack of use killed the ryobi ones as they were almost always flat when i wanted it !
Edited by LJ RB30, 26 December 2014 - 12:13 PM.
#7 Bullet
Bullet
  • 217 posts
  • Name:Mark
  • Car:LC 2 Door S
Posted 26 December 2014 - 12:47 PM
I've had my Hitachi 1/2" rattle gun for over 5 years now, I'm a diesel fitter so it gets a hidding, lived in my tool bag the hole time, been wet heaps, dropped several time off 2500 digger, CAT 785 trucks and still goes. They haven't got as much balls as the bigger ones like Milwalkie etc but are smaller and get into tighter spots so can use them more often. You should never trust any rattle gun that it has done up a bolt tight enough, seen many guy's come unstuck doing this over the years.
Cheers Bullet
#8 dattoman
  • 16,487 posts
Posted 26 December 2014 - 02:36 PM
This is mine
Cheap and cheerful
http://www.tradequip...&product_id=451
#9 71Ranger
71Ranger
  • 267 posts
  • Name:Brian
  • Car:71 LC
Posted 26 December 2014 - 03:14 PM
Hi,
Thanks for all the replies, the scum bag that stole mine took the case so both batteries and charger are gone. Im after something that will primarily undo car wheel nuts first and foremost followed by suspension engine mounts and other rattle gun type stuff etc.
Mark I haven't really looked at Hitachi - what model is yours (nothing like a recommendation from someone who has used one in anger).
Dattoman, does that thing really work? I have never heard of them.
Cheers Brian
#10 Bullet
Bullet
  • 217 posts
  • Name:Mark
  • Car:LC 2 Door S
Posted 26 December 2014 - 03:22 PM
Mines an old 18 volt job with the 3ah battery that pushes up into the handle, the newer models are 4ah or more and battery slides in from the front.
They will still undo car and 4WD wheel nuts ok, use mine on Hilux and cruisers all the time. Most fitters I've come across use Hitachi.
Cheers Bullet
#11 dattoman
  • 16,487 posts
Posted 26 December 2014 - 03:38 PM
Cheers Brian
Yup works a treat
Handy at the track for changing wheels for transport
I've been using it abit in the shed for pulling engines apart too
I must admit I bought it cheap on clearance and the normal price is alot more than it should be
I actually bought 5 of them @$75 each. Sold 4 off which more than paid for mine. :)
#12 _LHSL308_
_LHSL308_
Posted 26 December 2014 - 05:45 PM
Whats the normal price on those Datto?
#13 dattoman
  • 16,487 posts
Posted 26 December 2014 - 08:12 PM
Depends where you shop I guess
https://www.toolmart...tools/9831.html
#14 rodomo
  • 18,039 posts
Posted 26 December 2014 - 08:19 PM
If you need one of those you're a gurl...............just sayin...........
#15 _2ELCS_
_2ELCS_
Posted 26 December 2014 - 08:25 PM
They just make life easier for us old blokes DAMMIT???
#16 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 26 December 2014 - 08:26 PM
Wayne has an electric winch mounted to his zimmerframe so he can use his.
#17 rodomo
  • 18,039 posts
Posted 26 December 2014 - 08:32 PM
I'm just over the young whipper snippers at work breaking nuts, bolts, studs with all these gizmo's and I have to spend time drilling, tapping, ezy-outing all their mistakes cos they hay no clue about this stuff.
#18 _2ELCS_
_2ELCS_
Posted 26 December 2014 - 08:37 PM
Your supposed to teach them the right way Hotrod ?
#19 rodomo
  • 18,039 posts
Posted 26 December 2014 - 08:52 PM
New manager told me he wanted me to quality control every job before it left...............
I just laffed..........
Wipper snippers know it all and I refuse to get involved.
#20 ben23
ben23
  • 245 posts
  • Name:Ben
  • Car:'77 LX 2850 sedan
Posted 26 December 2014 - 08:57 PM
I use the ryobi 13mm drill, impact driver, rattle gun and angle grinder as an auto sparky, and they hold up really well and perform great for the price! Rattle gun will whip off alternator pulley nuts on big truck alts no problem, which is the reason I got it. two 4.0ah batteries and a 1.5Ah battery hold up well.
#21 Bigfella237
Posted 26 December 2014 - 11:39 PM
All my cordless gear is Dewalt XRP stuff (including a ½" drive rattle gun) and I couldn't be happier, it's been dropped from great heights, under water several times, kicked around in the dirt & mud and it's still going strong.
#22 N/A-PWR
  • 9,639 posts
Posted 27 December 2014 - 11:47 AM
and a Happy New Year Brian too,
So Datto's Gun has 450nm,
which is the key for rattling power,
so make sure you get 450nm at least in your Gun, so those wheel nuts come off.
Like-wise, we need reliability, which this thread is great for comparisons.   :spoton:
Here is a link to a few ebay Guns and Prices:-
Rattle Guns
#23 _LS1 Hatch_
_LS1 Hatch_
Posted 27 December 2014 - 11:55 AM
http://www.amazon.co...19645029&sr=8-1
Bit of grunt to these..
I have a bunch of the M18 Milwaukee stuff and it's awesome.
#24 _Skapinad_
_Skapinad_
Posted 27 December 2014 - 01:14 PM
But Datto's gun is ugly....
#25 _LHSL308_
_LHSL308_
Posted 27 December 2014 - 02:00 PM
I'll be in the market for one but never had one before so dont know much about them.
Milwaukee and Dewalt stuff have always been good but cost a fortune.
I'm just after something that will give me the most bang for buck while being reliable when needed.
