Carby spacer question
_parsons5000_
Posted 11 January 2015 - 07:25 AM
Posted 11 January 2015 - 08:04 AM
Providing it's just a spacer and not an adapter it should be okay but you will probably have to swap out the studs for shorter ones as well.
Once you get the spacer off, sit the carby on the manifold and make sure the throttle butterflies and linkages don't foul on anything, you don't want to find out they bind on full throttle during the test drive!
You will probably drop a couple of horses from what the dyno said due to the slightly reduced intake runner volume but such is life.
Posted 11 January 2015 - 08:26 AM
Good advice stated above.
_HRG735_
Posted 27 January 2015 - 11:16 AM
Hi Ryan. New member, however lots of experience with Torana bonnet clearance issue's. If you haven't already solved your problem I used to cut the base (downward flange), off the air cleaner. This would usually provide 15-20 mm extra clearance without upsetting the intake set up. You never have much clearance in a Torana to begin with. The underside of my bonnet used to show the markings from the various air cleaners I tried. As Andrew stated it is important to establish whether it is an adaptor or spacer. If it's an adaptor then a change to the correct base carb will automatically provide you with the clearance. A dual-plane manifold usually provides more low-down torque and driveability, where as spacers usually assist with higher rpm power (I did say usually). I am interested to know what you are using in your set up? Regards, Scott
_parsons5000_
Posted 29 January 2015 - 11:40 AM
I took spacer which was 1 inch off and ran a 1 inch drop base with 3 inch filter x 14
_HRG735_
Posted 29 January 2015 - 01:14 PM
Thats worked out well. Sounds like you have a good balance with very good power thats useable and driveable on the street. What you lost with the spacer (if any), should be better for street use. Them putting the spacer on sounds a little bit like Macca's on-selling - "do you want fries with that? You probably don't need it, but the offer makes you think you do! Did they alter the carb specs from standard during the dyno tuning?
_greenmachine215_
_parsons5000_
Posted 30 January 2015 - 07:06 AM
air cleaner out of the bonnet looks rude IMO , im gonna call dyno shop to see if its cool with not running spacer after everything was tuned with it on
