Hello,
Currently working on a LH 4 door turbo 304 V8.
After any information on what other have done with turbo placement, manifold and exhaust.
Thanks Adam
Posted 20 January 2015 - 03:47 PM
Hello,
Thanks Adam
Posted 20 January 2015 - 04:13 PM
Air pump on valley cover might save some plumbing woes,still need to lower the comp. either way and the square cut gears sound
ok if they still use them.Cost might be the same or lower than twin turbo's as well ?
Posted 20 January 2015 - 09:35 PM
Most of the turbos are set up in the battery or opposite front pocket, exhaust for single turbos brought forward and under the balancer at sump level.
Posted 20 January 2015 - 10:16 PM
If the car is to be street registered, have you checked with the relevant authorities as to whether you can actually do this legally and get it on the road?
if not, lots of time and money wasted on a track only car.
Posted 20 January 2015 - 11:53 PM
To expand on Bomber's comment...
The heaviest tare weight of an LH sedan was an L34 weighing in at 1306kg, as per table LA1 from NCOP3_Section_LA:
Table LA1.JPG 95.52K 4 downloads
1306 x 3 = 3918cc max capacity for a turbo'd engine so I think you're SOL... unless you go ICV
BTW, I note that chart says "Recommended Maximum Engine Capacity" but I've been told recently that those figures are a "line in the sand" and there is no tollerance even if you're within a few cc's?
Posted 21 January 2015 - 07:22 AM
Posted 21 January 2015 - 09:42 AM
Ring Jake Edwards.
Posted 21 January 2015 - 07:39 PM
If you are going to turbo charge a 304 I would do a twin turbo set up
Posted 22 January 2015 - 12:30 PM
After from photo of what poeple have done with the dump pipe. Going 3", Single turbo over the battery tray
Posted 23 January 2015 - 07:18 PM
i have a turbo 304 in a commodore.no need to drop the compression.its not 1984 any more.
single turbo is way easier and cheaper.plus less heat less piping etc.
Posted 27 January 2015 - 11:50 AM
Posted 27 January 2015 - 12:47 PM
injected
Posted 28 January 2015 - 01:12 AM
Posted 28 January 2015 - 01:09 PM
Any one have any photos of a turbo setup?
Posted 30 January 2015 - 10:49 PM
Posted 02 February 2015 - 01:37 PM
Thanks Green Machine 215 Ill also look into the ECU settings.
Posted 05 February 2015 - 03:28 PM
How much would it cost to put a 304 into a torana and turbo charge it with the standard injection.
Could anyone give me a brief run down please? Interested in this combo for my own torana.
Posted 05 February 2015 - 05:07 PM
Edited by Dustings, 05 February 2015 - 05:08 PM.
