Hey guys, i have alot of different answers so i was hoping you guys could clear it up... THE QUESTION: How man kw's is a Blue 308 5L engine. ( NOT RED)
Posted 22 January 2015 - 04:20 PM
Posted 22 January 2015 - 04:33 PM
not much more than a healthy 202
Posted 22 January 2015 - 04:42 PM
hahahahha, well i researched then and looks to be around 120, my uc hatchback kerb weight is like 1157, so canculations =
120 / 1157 = 0.1037165082, than multiply by 1000 to get tones, = 103.7165. so im well under the 130kw per tone limit! NO 202
Posted 22 January 2015 - 04:53 PM
253 red was claimed 180(5)HP(135kw),308 red claimed was about 240 BHP(180kw), blue and efi were probably not too much higher?
180kw or 240 BHP for 308 rings a bell,although the efi may have been 185?
Posted 22 January 2015 - 04:58 PM
yeah i know that blue and black 308 are less kw than red, red is alot higher im prety sure?
Posted 22 January 2015 - 05:01 PM
This motor here is like my exact one .. if it helps
Posted 22 January 2015 - 05:17 PM
cant' see why they would have went backwards to less HP out of 308 in blue/black to less than that of a 253, but who knows?
180/1157=155
even if the 5L was only 150,just scrape in with those numbers.
Posted 22 January 2015 - 07:11 PM
Posted 22 January 2015 - 07:38 PM
oh ohk, thanks guys
Posted 22 January 2015 - 07:41 PM
Posted 22 January 2015 - 07:43 PM
I don't think anyone is trying to put you off the idea of V8 option considering the UC did not come from factory with a V8.
But with the "rules" that have been made regarding "P" platers make some sort of sense considering that "power and acceleration" do play a part with
"lead foot because it there to be used" in written people and cars
Mind the public,i see "P" platers in 4 cylinder stuff doing stupid shit that could just as well get us killed,not good considering it sounds like you have
put a lot of effort into what you intend drive around.
Not so much the "power"..more of how you use it.
So they did go backwards in power,no wonder they went broke
Posted 22 January 2015 - 08:05 PM
Emissions control gear mostly mate.
Posted 22 January 2015 - 08:12 PM
Posted 22 January 2015 - 09:12 PM
Posted 22 January 2015 - 09:22 PM
yeah alright, thanks for the comments guys, and dont worry i wont be driving stupid, i put way to much effort and time into this car
Posted 22 January 2015 - 09:37 PM
1157 kg's kerb weight will be with a 6 cyl & I stated before my UC was 1340 kg's with a V8 & I still had a std diff.
You mention before that your UC has a 9 inch. So that is a much heavier diff the same go's for the V8 compaired to a 6 cyl so all these mods are adding more weight to the car. So there is a lot stuff the engineer will be lookig at. Like the motor, the drop tank, the diff & he required a brake upgrade. So I think you should ponder it for a while because it'll cost a bit of coin.
Im not fluent with NSW rules but im pretty certain the weights they gather for P plate legalities and the like will be factory specified weights, the same thing they use in other states to base modification guideliens on.
Just the same as the engine output they use will be whatever they have on there records, regardless of what the engine actually makes.
Posted 22 January 2015 - 10:11 PM
Edited by imj411, 22 January 2015 - 10:12 PM.
Posted 22 January 2015 - 10:20 PM
Posted 23 January 2015 - 08:32 AM
but there was a rta person that told me a engine mod, is just a modification done directly to the motor, to enhance the engines preformance, which the 308 has had nothing done. Will be finding out this aftertoon and getting a definet answer fingers crossed!
Posted 23 January 2015 - 09:12 AM
You might be in for some hoop jumping, there is also a power restriction on P1 and P2 and under 25yrs of age at the time.
The power to weight is one aspect that you might get a away with.
The others that might not be so easy are "an engine with 8 or more cylinders" and "an engine with a power output of more than 210kw".
Even though you may be "ok" power output wise and power to weight, it might be a different story with the number of cylinders involved, unless there is some loophole that exempt's you from the 8 cylinder rule taking into account the power output.
Edited by EunUCh, 23 January 2015 - 09:12 AM.
Posted 23 January 2015 - 09:27 AM
Posted 23 January 2015 - 10:52 AM
yeah what bomber said^, i have now talk to a person high up in the rta and said it is 50/50 so shes going to call back later, and i also now have a guys email who can give me a definet answer, BUT i just need to give him my engine number now buty cant find it!, i found this engraved inbetween the pistons and under the air filter: 1278 4563. it also had FIRING ORDER and GM there. is this it?????
Posted 23 January 2015 - 10:55 AM
Posted 23 January 2015 - 11:02 AM
oh ohk thanks, so i read a thing online and said i need to get under the car with a spotlight? sorry i dont even know what the blocks deck face is haha, im still 17 and learning :/
Posted 23 January 2015 - 11:09 AM
Holden Tech →
General Questions and Help →
What colour red is this car "Whos up"Started by LE38OY , 24 May 2022 ![]() |
Holden Tech →
Engine →
Some Advice Re 202 Blue .Started by mandytory , 14 Apr 2022 ![]() |
Holden Tech →
Engine →
202 very rough idle at lights while in DStarted by avoidev , 19 Jan 2022 ![]() |
Holden Tech →
Engine →
2600N engineStarted by stealthxu1 , 28 Jul 2021 ![]() |
General →
Torana Trivia and Memorabilia →
Bathurst A9X Torana's: A Photographic HistoryStarted by LX2DR , 23 Nov 2020 ![]() |
