Hi guys, can someone tell me what model Holden the engine prefix/number might be out of?
VT 446895
Posted 24 January 2015 - 03:34 PM
VT 446895
Posted 24 January 2015 - 03:52 PM
Edited by Bigfella237, 24 January 2015 - 04:00 PM.
Posted 24 January 2015 - 04:05 PM
It's not necessarily a Blue motor. They can be Red, Blue or Black.
A VT prefixed block is any 308/5.0 from any Commodore from VB to mid-VK except for the rare VZ performance versions.
Dr Terry
Posted 24 January 2015 - 04:11 PM
Cheers Bigfella.
Exactly the info I wanted plus a little more ... was wondering if it may have been out of a HDT or not
And Dr Terry
Posted 24 January 2015 - 04:42 PM
Edited by Bigfella237, 24 January 2015 - 04:56 PM.
Posted 25 January 2015 - 07:44 AM
I think you'll find HG had the most engine options, but probably correct that the most variations probably are in VK but LH has 3 x 5.0L engines too (HQ style, HJ style, L34) plus A/C versions (different rockers).
Posted 25 January 2015 - 09:00 AM
It does depend on how you count those engines. If you want to be pedantic some late Commodores have a multitude of minor variants each one varying by a few kW. Changes were generally limited to cam timing & ECU mapping.
As HK1837 has said, HG has the most variants (in real terms) at 15, where the VK had 13, however LC & LJ series Toranas had 14 each.
Andrew if you have a copy of my 60 years book, you will see them all listed in table format for each model series.
Dr Terry
Posted 25 January 2015 - 10:37 AM
^ Gratuitous plug for ones own book
Posted 25 January 2015 - 11:48 AM
Absolutely !!
Dr Terry
Posted 25 January 2015 - 06:35 PM
It does depend on how you count those engines. ~
Dr Terry
I actually included a copy of your book in my letter to Santa last year but he messed that up as well... ("...ya worn-out geriatric fart, you forgot me f#%kin bike...")
In this context I was referring to variations in engine number prefixes for the 308 block only for identification purposes, but I take your point, I should have clarified.
Around early 1985, Holden seem to have thrown the book out the window and started again with engine number prefixes (specifically the second letter), before that a ?T was the standard 308 and a ?Z was the high output version (and of course there were a myriad of others for different capacity engines), but I guess it was either that or use a different system entirely.
Edited by Bigfella237, 25 January 2015 - 06:38 PM.
Posted 25 January 2015 - 07:54 PM
They had to re-use letters as they'd run out. They added V for the low comp 308 late in the 70's and Y and Z were already gone. They re-used K for the EFI 3.3 in VK as it was no longer used (last used in LC) and I guess as the high output Holden 6 K made sense (186K, CK), and VZ for the higher output 308 (as in last used as HZ in LH L34) but must have decided to go back to A again in 1985 as QA or CA hadn't been used since around 1975, same with B, C etc
Posted 25 January 2015 - 10:15 PM
The "VK" prefix was reused yet again for the VN Group A (4-bolt main) blocks (I don't think anyone could confuse them with an EFI six).
The other prefix reused in Commodore was "VP", used on the VL Group A (4-bolt main) 304ci blocks and again on the (L98 option) VT HSV (sequential injection roller cam/lifter) 355ci stroker blocks. (Or were they were both cast from the same mould?)
The latter not to be confused with the LS2-based "L98" 6.0L engine from the much later VE Commodore.
