Hi all,
Will both 9 and 12 port heads fit onto a 3.3L 6 cylinder out of a VK Commodore without any modifications.
Posted 04 February 2015 - 04:22 PM
Hi all,
Posted 04 February 2015 - 04:31 PM
Hi Glenn,
You will need to drill and protect the block from metal material,
for the 9 port water jacket holes being drilled into the 3.3,
using a 9 port head gasket as a template.
The 3.3 water jacket holes will be covered by the 9 port head gasket.
Hi all,
Will both 9 and 12 port heads fit onto a 3.3L 6 cylinder. - Yes.
Posted 04 February 2015 - 04:41 PM
Thanks for that Dave. So I need to drill the 3.3 block right? Should I weld the 12 port head holes in the 3.3 block or is it fine to cover them with the head gasket. Water leaks?
Also, while your here. Will 202 pistons fit into a 3.3 Blue block. And I assume the 202 had the 9 port head.
Edited by glennhailstone, 04 February 2015 - 04:49 PM.
Posted 04 February 2015 - 04:47 PM
The gasket will seal OK as this mod has been done already.
and a very good question about the pistons, as I will guess and say, all pistons will fit the bore diameters suited.
so a 202 bore is the same as a 3.3 standard
Posted 04 February 2015 - 04:48 PM
Posted 04 February 2015 - 05:31 PM
Ok thanks : )
Posted 04 February 2015 - 05:56 PM
Thats good Bomber, thanks for that.
I shouldn't need to worry about my push rod lengths ect should I, I was just going to take everything out of my 186 and put it into the 3.3. The only thing I should have to do is drill those holes right?
Posted 04 February 2015 - 06:02 PM
You will use the pushrods to suilt whichever cylidner head you use.
Posted 05 February 2015 - 02:09 PM
Sorry to sound dumb, but if Im using my 9 port head and my 3.3 block can I use my push rods out of my 186.
Posted 05 February 2015 - 04:35 PM
That would imply your using the pushrods to suilt whichever cylinder head you use....IE yes, the 186 ones.
Posted 05 February 2015 - 06:59 PM
Ok thanks Bomber. I will just put my 9 port head my 3.3 block, done!
Thanks very much.
Posted 05 February 2015 - 07:04 PM
Definitely the smarter way to go.
You asked above about welding up the holes, well firstly you wouldn't weld them, drill and tap them and fit a grub screw would be a lot better, but I see no need. In the Holden six cylinder head 101 thread i put a fair few picks up of the differences. Whether you drill the block or the head depends on what gasket you get IMO. Generally it would be better to drill the head if the block is a complete short assembly, as metal filings will be easyer to remove from a cylidner head than from a short motor.
Posted 05 February 2015 - 10:52 PM
Is it often done this way ?
I have only seen tutorials for drilling the block.
Posted 05 February 2015 - 11:01 PM
If you have both parts in front of you, im pretty sure you will find there is little difference.
Posted 05 February 2015 - 11:11 PM
I could imagine making a 3.3 block match the 9 port 202 head water jacket holes,
or the 202 block matching the 3.3 head water jacket holes,
by making either head water jacket holes match their final destination.
I am learning too.
but if we can do the reverse, that will be great news.
