LC CHEV 307 CONVERSION - STEERING QUERY
CHEV 307 V8 LC
13 replies to this topic
#1 _CHIEF383_
_CHIEF383_
Posted 08 February 2015 - 06:26 PM
Hi Guys,
Im getting through my LC 307 CHEV conversion and am hitched up on one issue. Does anyone know the steering knuckle and shaft configuration for the conversion? I have heard two knuckles from a LH/LX and have also heard three Knuckles. If you have done a SBC conversion could you please post some info or photos on how its done?
Cheers in advance!!
#2 TOERUNNER
TOERUNNER
  • 630 posts
  • Name:RODNEY
  • Car:73 lj gtr 73 lj 2 dr S
Posted 08 February 2015 - 07:20 PM
scallop the front end, shorten the rack input shaft, move bottom of steering column to the right about 20 or 30 mm (can't remember exactly) and fit 2 unis
cheers Rodney
#3 _judgelj_
_judgelj_
Posted 08 February 2015 - 07:28 PM
Have also seen 3 uni setup to clear
#4 _CHIEF383_
_CHIEF383_
Posted 08 February 2015 - 07:43 PM
cheers Rodney
Thanks for that Rodney. Are the knuckles and shaft standard LX LH?
I'd like to see the three knuckle setup as that's what I originally had in mind!
Edited by CHIEF383, 08 February 2015 - 07:43 PM.
#5 _judgelj_
_judgelj_
Posted 08 February 2015 - 08:12 PM
There is a picture of it floating around somewhere here just dont remember where.
the knuckles are lh lx rare spares do a repro
#6 gtrboyy
gtrboyy
  • 3,209 posts
Posted 08 February 2015 - 08:50 PM
Probably crs kit..google image search should do the trick.
I'm curious what knuckles get used these days as lh lx fairly old now & rare spares ones I used as replacements were horrible,hopefully they have improved.
#7 _CHIEF383_
_CHIEF383_
Posted 08 February 2015 - 09:07 PM
Crs do a kit but it sets you back about $480
#8 WhaleOilBeefHooked
WhaleOilBeefHooked
  • 1,671 posts
  • Car:LJ GTR
Posted 08 February 2015 - 09:36 PM
I used 2 x LH knuckles & 1 x intermediate shaft, After cutting a small length from the rack shaft and also another cotter pin seat near end of it... I don't see the need to cut K-frame, But have seen plenty done like this over the years......
  • Attached File  2y.JPG   139.54K   25 downloads
#9 Bigfella237
Posted 09 February 2015 - 02:09 AM
Then you'd have to support at least one of the intermediate shafts with bearings mounted back to the chassis or down to the K-Member rear leg wouldn't you? Otherwise the centre uni of the three would look like a skipping rope when turning.
#10 TOERUNNER
TOERUNNER
  • 630 posts
  • Name:RODNEY
Posted 09 February 2015 - 06:57 AM
http://www.ebay.com....=item3cc99a4486
I used 1 lx uni and 1 of these ,the ebay one won't work with the original shaft as the groove is too deep and the cotter pin pulls through.
A shallower groove in the intermediate shaft and rack shaft and these unis work fine
#11 _CHIEF383_
_CHIEF383_
Posted 09 February 2015 - 12:30 PM
What shaft do you use and where do you yet them from? How do you get them to size?
#12 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 09 February 2015 - 12:48 PM
It says in the eBay link the hole size is 14.3mm. You can buy a 300-400mm length from CRS.
#13 TOERUNNER
TOERUNNER
  • 630 posts
  • Name:RODNEY
Posted 09 February 2015 - 01:31 PM
i just used the shaft that i cut from the steering rack when i shortened  the input, just need to notch the shortened input shaft and cut the offcut to length and notch one end of it for the cotter pins, being careful not to go too deep otherwise the cotter pins will pull through when you tighten them.
cheers Rodney
Edited by TOERUNNER, 09 February 2015 - 01:37 PM.
#14 _procharged lj_
_procharged lj_
Posted 11 May 2015 - 05:38 AM
Go with the two knuckles and a reduction starter motor. I live in sydney too, I have two lj's set up for chevs here If you would like to have a look I'll try to take some photos and post them for ya.
Mark.
Also tagged with one or more of these keywords: CHEV, 307, V8, LC
