will my after market 186 cam fit my 3.3L engine
_glennhailstone_
Posted 08 February 2015 - 06:46 PM
I am putting all my 186 parts onto a 3.3L blue block. I am using the blue crank and pistons, but Im wondering if I can use my 186 cam. It is after market street/race spec.
_Muzzy_
Posted 08 February 2015 - 07:20 PM
_Bluejinx202_
Posted 08 February 2015 - 08:13 PM
_glennhailstone_
Posted 09 February 2015 - 04:01 PM
Ok thanks, I'll have to look into that.
_threeblindmice_
Posted 09 February 2015 - 05:08 PM
_Muzzy_
Posted 09 February 2015 - 06:15 PM
Are the cam gears the same ?
Std one is fibre cam gear
Preferred is alloy cam gear
The crank is steel regardless
Don't use straight cut
Posted 09 February 2015 - 06:26 PM
Pfft, straight cuts rule
and don't try to mix and match imperial and metric gear pitch,if they still make both?
ie,make sure the gears are a set...new or used.
Posted 09 February 2015 - 06:39 PM
Make sure it isn't actually a proper 186 cam or the 202 rod bolts will hit the cam. Has to be a cam designed for a 202 to fit in a 202, which most aftermarket cams have been since the 70's.
Posted 09 February 2015 - 06:50 PM
TMK all aftermarket alloy cam timing gears are the same for 138, 149, 161, 173, 179, 186, 202. Note: Straight cut timing gears not included.
Edited by S pack, 09 February 2015 - 06:52 PM.
_threeblindmice_
Posted 09 February 2015 - 07:41 PM
Posted 09 February 2015 - 07:48 PM
Thanks Dave , it was just something a railway mechanic said to me thirty years ago , about the late ones being different , and it is one of the things I never forgot .
I don't know if Red, Blue & Black genuine GMH cam gears are the same so they may be a different kettle of fish to aftermarket gears.
Edited by S pack, 09 February 2015 - 07:48 PM.
Posted 09 February 2015 - 08:28 PM
They look the same at a quick glance, though i've never actually thought to check them really closely, and all the stock cams i've come across that had fibre gears on them are currently in landfill so cant check....
_oldjohnno_
Posted 09 February 2015 - 08:53 PM
If I wanted to listen to an incessant whining noise I'd bring the missus along....
Posted 09 February 2015 - 09:40 PM
Posted 09 February 2015 - 10:17 PM
I have no missus, so its an occasional/recreational thing
Posted 10 February 2015 - 10:24 AM
Posted 10 February 2015 - 11:20 AM
_Lazarus_
Posted 10 February 2015 - 12:10 PM
I had a missus with straight cut gears once.
Ended up getting some earplugs.
_LS1 Taxi_
Posted 11 February 2015 - 12:06 AM
It sounded nothing like other straight cuts I've heard...
#21
_glennhailstone_
Posted 11 February 2015 - 02:12 PM
Oh so your still alive oldjohno, I was a bit worried about you for a minute there.
#22
Posted 11 February 2015 - 07:55 PM
Must be pressing the end of his years surely.....
#23
_glennhailstone_
Posted 12 February 2015 - 03:26 AM
hahaha
