Triple carb identification - Help Please
6 replies to this topic
#1 LHSL
LHSL
  • 995 posts
  • Name:Phillip
Posted 15 February 2015 - 08:40 AM
Hi All,
I am trying to help a friend of mine. He recently purchased the set and wants to know if they are genuine XU-1 or not. I know the manifold is genuine LC XU-1 but the carbies I cannot see any serial numbers on them.
Can someone help please on where do I find the serial numbers?
Phillip
#2 S pack
  • 15,693 posts
Posted 15 February 2015 - 08:56 AM
Remove the entire air filter assy from the carbs. There should be a code number stamped into the face of the carby air cleaner mounting flanges.
#3 LHSL
LHSL
  • 995 posts
  • Name:Phillip
Posted 15 February 2015 - 08:59 AM
Thanks Dave I will pass on info. I removed air filter but not the base.
Phillip
#4 LHSL
LHSL
  • 995 posts
  • Name:Phillip
Posted 15 February 2015 - 10:07 AM
A128 on the two he checked so I guess he is right they are from a LC XU1.
Thanks for your help.
#5 S pack
  • 15,693 posts
Posted 15 February 2015 - 10:37 AM
In theory there should be two A coded carbs and one B coded or two B coded and one A coded. I think the jury is still out on which combination is correct.
Dave.
Edited by S pack, 15 February 2015 - 10:37 AM.
#6 LHSL
LHSL
  • 995 posts
  • Name:Phillip
Posted 17 February 2015 - 12:32 PM
Dave if anyone is taking count the third carby came back with B128.
Thanks for your input on this.
Phillip
#7 S pack
  • 15,693 posts
Posted 19 February 2015 - 11:04 PM
Your welcome Phillip.
Theoretically if there are two A coded and one B coded then the  B coded carb should have the fitting for the vacuum advance pipe. The two A coded carbs should have their vacuum ports plugged.
Dave.
