Convo pro setup help
15 replies to this topic
#1 LOOKING4HATCH
LOOKING4HATCH
  • 68 posts
  • Name:Scott
  • Car:LX hatch
Posted 09 March 2015 - 12:21 AM
Hi guys.
I'm looking into setting up my brakes / hub / rim choice.
I have a LX hatch unflared.
I want to have all 4 wheels / tyres the same size and as wide as I can fit.
I'm guessing I will be going ha pattern but if I have better option will commodore then I can do that.
What rim size and back space should I go for ?
Thanks heaps
#2 _Mint_
_Mint_
Posted 09 March 2015 - 01:10 PM
Hi Scott, this is the same question ive been trying to answer..i have a flareless hatch diff(borg warner) has been shorten slightly about 15-20 mm each side and guard lips rolled flat.I have 265x50 x14 tyres on back now which just fit..i borrowed a mates 15x 7 convos to get some idea which fit easily but I want 8 1/2"s from what have worked out the 3 3/8" backspace wont fit unless you have 50+ mm narrowed diff otherwise rim n tyre will be right out to the guard lip.
The 5" backspace(8 1/2) might fit with a spacer maybe 10-12mm or the tyre would be to close to the shock and inner guard..so that's probly where im heading with a 235x60x15 tyre I have another mate lol who has this combo I can try.
Nobody makes a 235-245 or 255 in 50 series tyre in 15's unless a semi slick tyre tho you can get 265-275-295 in 50 x 15's
im only going a 6" rim on the fronts
hope that helps
#3 _parsons5000_
_parsons5000_
Posted 09 March 2015 - 01:34 PM
Hey guys I have a 8 inch rear my diff was shortened 14 mm each side I think fits nicely with no lipped gaurds , the fronts are abit tricky I have 6 on fromt , back wheels are 4.25 or 4.5 backspace
Tire rear is 225/60/15
#4 rexy
rexy
  • 3,716 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 09 March 2015 - 02:14 PM
Obviously you will be limited by what you can get on the front if you want front and back to be the same. 15x7 with 225/50/15 will probably be as big as you can go without cutting things.
#5 Redslur
Redslur
    Has been Torana owner
  • 3,536 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 09 March 2015 - 04:36 PM
Agree with rexy.  Be looking at 225's all round I reckon and if you don't get the offset right on the front, the wheel/tyre combo will foul the guards for sure!
#6 _Mint_
_Mint_
Posted 09 March 2015 - 05:13 PM
15x7 convos only have 1 backspace which is 3 3/8" they do a 7 1/2" rim but only 5" backspace
#7 LOOKING4HATCH
LOOKING4HATCH
  • 68 posts
  • Name:Scott
  • Car:LX hatch
Posted 09 March 2015 - 09:36 PM
Thanks guys. Lots of info. So the 225/50/15 on the front will fill the guards. Will the rears have the same clearance or will there be more room.
Really looking for the clean look tyres filling the guards the same front and rear
#8 _Mint_
_Mint_
Posted 09 March 2015 - 09:55 PM
nup it wont look the same the rear will have quite a bit more space and the front will be a close fit specialy the bottom front lip of the guard when you turn the wheel
#9 LOOKING4HATCH
LOOKING4HATCH
  • 68 posts
  • Name:Scott
  • Car:LX hatch
Posted 09 March 2015 - 10:43 PM
Hmmm so might have to rethink it. Might have to look into just filling out the guards equally. So maybe 245/50/15 on the rear
#10 Redslur
Redslur
  • 3,536 posts
  • Name:Gerry
Posted 10 March 2015 - 11:33 AM
In my experience, a 205 tyre is best suited on the front of a non flared LH/X Torana. Not saying others won't fit/work. It is what I have always run, and currently do.  As for the rear, there are many options to run fatter tyres. I currently have 17 X 8.5 rims with 245/40 17 inch tyres and they fit easily without any rubbing or touching.  But I have a 3 inch shortened diff and 3.5 inch rear backspace.  So it all depends on your setup. I also have a set of Weld Stars which I run for the drags with the similar offset as convos, and they are 15 x 7  front with 4.5 inch b/s and 15 x 8.5 with 3.5 b/s. Front tyres for those are 205/55R 15.
Do your homework first or you may regret it later :-)
#11 SmacT
SmacT
  • 971 posts
  • Name:Sam
  • Car:LX 4dr 383, TKX, BW
Posted 10 March 2015 - 01:05 PM
I recommend building yourself a jig or fake wheel out of cardboard to the dimensions you want. You can get circumferences and widths of tyres of the web easy enough, then play with what fits, measure it and you're away. Better and cheaper than buying wheels and tyres until it fits, anyway. :-)
I did this as I ran a shortened BW on my flared four door and the 9.5s at the back fit spot on.
#12 _Mint_
_Mint_
Posted 10 March 2015 - 07:50 PM
well for me some good news I tried my mates 15x8 1/2" convo with 5" backspace and a 245x60x15 and an 8mm spacer it fits real good
#13 _parsons5000_
_parsons5000_
Posted 30 March 2015 - 09:09 AM
hey mate which spacer did u buy ??
#14 _Bomber Watson_
Posted 30 March 2015 - 09:50 AM
Don't expect them to stay on to long running wheel spacers.
#15 _Mint_
_Mint_
Posted 01 April 2015 - 06:28 PM
its not ideal Bomber but its gunna have to do for the moment...I have the local Tafe machining some dedicated on hub spacers for me for free
#16 _ryan350_
_ryan350_
Posted 11 April 2015 - 08:55 PM
Not saying it's right bomber but i have run wheel spacers (around 8-10mm) with no problems what so ever , used the car as a daily driver for 2 years plus! like said not saying it's right i would not do it these days unless for a emergancy but it does work!
