triple weber manifold holden 202
_datpsi_
Posted 10 March 2015 - 09:31 PM
Posted 11 March 2015 - 04:37 AM
Posted 11 March 2015 - 12:42 PM
Even the warneford manifolds with the kicked outside runners flow well after a few small tweaks.
The air is moving so slow through the two runners that the bends don't affect outright flow much.
My best weber manifold, a marshals intake with the divider kicked back an inch drops 3cfm on a 212cfm cylinder head.
Posted 12 March 2015 - 05:13 PM
Hi Kevin what do you mean by the divider kicked back an inch ???
Posted 12 March 2015 - 05:37 PM
Posted 12 March 2015 - 06:40 PM
So cut back an inch at manifold to head face ! What does this do ? Does it improve things ? thanks
Posted 12 March 2015 - 08:50 PM
Its allowing the air to straighten out from the runner on the other side of the port.
No back to back testing on an engine unfortunately
Edited by greens nice, 12 March 2015 - 08:50 PM.
Posted 12 March 2015 - 09:15 PM
3cfm for half hours work is pretty huge really.....Particularly on a 212 cfm head....
_Smarty_
Posted 02 April 2015 - 08:36 PM
Hi Datpsi., when purchasing your manifold be careful to check the casting carefully as manifolds can vary in thickness and quality greatly. I bought one a while ago and after looking hard at it there was no meat in it to allow for porting and matching work. I returned it and explained why. Ended up with a redline one. nice thick casting around mount bolts/studs, nice wall thickness to allow for porting and clean up. Tip. mark out manifold to head and drill for 2 small roll pins on front and rear ports to enable perfect alignment every time it's fitted. get help if not confident with this. good luck.
_datpsi_
Posted 03 April 2015 - 11:37 AM
_datpsi_
Posted 10 July 2015 - 11:22 PM
Edited by datpsi, 10 July 2015 - 11:34 PM.
